Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
BH1750 Digital Light Sensor / Lux Meter Chip Driver
Post new topic   Reply to topic    CCS Forum Index -> Code Library
sshahryiar
PostPosted: Tue Apr 30, 2013 9:02 pm     Reply with quote
BH1750.h
#use I2C (Master, SDA = PIN_A0, SCL = PIN_A1)
#define  BH1750_address_w 0x46
#define  BH1750_address_r 0x47
#define  power_down 0x00
#define  power_up 0x01
#define  reset 0x07
#define  cont_H_res_mode1 0x10
#define  cont_H_res_mode2 0x11
#define  cont_L_res_mode 0x13
#define  one_time_H_res_mode1 0x20
#define  one_time_H_res_mode2 0x21
#define  one_time_L_res_mode 0x23
void BH1750_init();
void BH1750_write(unsigned char cmd);
unsigned long BH1750_read_word();
unsigned long get_lux_value(unsigned char mode, unsigned long delay_time);
BH1750.c
#include "BH1750.h"
void BH1750_init()
   BH1750_write(power_down);
   I2C_start();
   I2C_write(BH1750_address_w);
   I2C_write(cmd);
   I2C_stop();
   register unsigned long value = 0;
   unsigned char lb = 0;
   unsigned char hb = 0;
   I2C_start();
   I2C_write(BH1750_address_r);
   hb = I2C_read(1);
   lb = I2C_read(0);
   I2C_stop();
   value = make16(hb, lb);
   return value;
   register unsigned long lux_value = 0;
   BH1750_write(power_up);
   BH1750_write(mode);
   lux_value = BH1750_read_word();
   delay_ms(delay_time);
   return lux_value;
https://www.facebook.com/MicroArena
SShahryiar
mstbzr
PostPosted: Fri Jan 02, 2015 3:05 am     Reply with quote
Rica etsem örnek bir kod yazmanız mümkün mü?
Is it possible to write a sample code please?
scanan
PostPosted: Tue May 26, 2015 8:00 am     Reply with quote
Here is an application that I did with PIC18F6310 and works quite well
luxmeter.h
#include <18F6310.h>
#device *=16
#FUSES INTRC_IO                       //High speed osc with HW enabled 4X PLL
#FUSES NOBROWNOUT
#FUSES PUT                    //No Power Up Timer
#FUSES NOSTVREN                   //Stack full/underflow will cause reset
#FUSES NOFCMEN                    //Fail-safe clock monitor enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOLPT1OSC
#FUSES NOMCLR
#use delay(clock=16000000)
#use rs232(baud=57600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,FORCE_SW)
#use I2C (Master, SDA = PIN_F3, SCL = PIN_F2,FORCE_SW)
struct IOpins {
           BOOLEAN unused00;        //A0
           BOOLEAN unused01;        //A1
           BOOLEAN unused02;        //A2
           BOOLEAN Aled2;           //A3
           BOOLEAN Aled1;           //A4
           BOOLEAN unused03;        //A5
           BOOLEAN unused04;        //A6
           BOOLEAN unused05;        //A7
           BOOLEAN unused06;        //B0
           BOOLEAN unused07;        //B1
           BOOLEAN unused08;        //B2
           BOOLEAN unused09;        //B3
           BOOLEAN unused10;        //B4
           BOOLEAN unused11;        //B5
           BOOLEAN comLED;          //B6
           BOOLEAN unused12;        //B7
           BOOLEAN cpuLED;          //C0
           BOOLEAN unused13;        //C1
           BOOLEAN unused14;        //C2
           BOOLEAN unused15;        //C3
           BOOLEAN unused16;        //C4
           BOOLEAN unused17;        //C5
           BOOLEAN rs232Tx;         //C6
           BOOLEAN rs232Rx;         //C7
           BOOLEAN unused18;        //D0
           BOOLEAN unused19;        //D1
           BOOLEAN unused20;        //D2
           BOOLEAN unused21;        //D3
           BOOLEAN unused22;        //D4
           BOOLEAN unused23;        //D5
           BOOLEAN unused24;        //D6
           BOOLEAN unused25;        //D7
           BOOLEAN unused26;        //E0
           BOOLEAN unused27;        //E1
           BOOLEAN unused28;        //E2
           BOOLEAN unused29;        //E3
           BOOLEAN unused30;        //E4
           BOOLEAN errorLED;        //E5
           BOOLEAN unused31;        //E6
           BOOLEAN unused32;        //E7
           BOOLEAN addr;            //F0
           BOOLEAN unused33;        //F1
           BOOLEAN SCL;             //F2
           BOOLEAN SDA;             //F3
           BOOLEAN unused34;        //F4
           BOOLEAN unused35;        //F5
           BOOLEAN unused36;        //F6
           BOOLEAN unused37;        //F7
           BOOLEAN emergencyLED;    //G0
           BOOLEAN unused38;        //G1
           BOOLEAN unused39;        //G2
           BOOLEAN unused40;        //G3
           BOOLEAN unused41;        //G4
           //BOOLEAN unused42;      //G5
           //BOOLEAN unused43;      //G6
           //BOOLEAN unused44;      //G7
} IOpin;
#byte IOpin=0xF80
#define  reset 0x07
unsigned int16 lightintensity=0;
void BH1750_init();
luxmeter.c
#include "luxmeter.h"
void BH1750_init()
   I2C_start();
   I2C_write(cmd);
   I2C_stop();
   I2C_start();
   hb = I2C_read(1);
   lb = I2C_read(0);
   I2C_stop();
   return value;
   BH1750_write(mode);
   return lux_value;
set_tris_a(0x00);
set_tris_b(0x24);
set_tris_c(0x80);
set_tris_d(0x00);
set_tris_e(0x15);
set_tris_f(0x58);
set_tris_g(0x10);
   setup_wdt(WDT_OFF);
   setup_adc(ADC_OFF);
   setup_adc_ports(NO_ANALOGS);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   setup_timer_2(T2_DISABLED, 0xFF, 0x10);
   setup_timer_3(T3_DISABLED);
   setup_vref(FALSE);
   setup_oscillator(OSC_16MHZ);
   clear_interrupt(int_ext1);
   clear_interrupt(int_ext2);
IOpin.cpuLED=0;
IOpin.errorLED=0;
IOpin.comLED=0;
IOpin.emergencyLED=0;
// set BH1750 address to 0x23 when low
// set BH1750 address to 0x5C when high
IOpin.addr=0;
EXT_INT_EDGE(1,L_TO_H);
enable_interrupts(INT_EXT1);
enable_interrupts(INT_EXT2);
disable_interrupts(INT_LOWVOLT);
disable_interrupts(INT_TIMER0);
disable_interrupts(INT_TIMER1);
disable_interrupts(GLOBAL);
BH1750_init();
IOpin.addr=0;
   for(;;)
      lightintensity=get_lux_value(cont_H_res_mode1,1000);
      printf("lux value:%f \n\r",(float)lightintensity/1.2);
      IOpin.cpuLED=1;
      delay_ms(10);
      IOpin.cpuLED=0;
Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
sshahryiar
PostPosted: Fri Jul 07, 2017 8:37 pm     Reply with quote
Example Code
#include <16F87.h>
#device *= 16
#fuses INTRC_IO, PROTECT, NOWDT, BROWNOUT, NOWRT
#fuses NODEBUG, NOIESO, PUT, NOMCLR, FCMEN, CPD
#use delay (internal = 4MHz)
#include <lcd420.c>
#include "BH1750.c"
void setup();
      unsigned long lux = 0;
      setup();
         lux = get_lux_value(cont_H_res_mode1, 180);
         lcd_gotoxy(6, 2);
         printf(lcd_putc, "%05lu    ", lux);
void setup()
   disable_interrupts(global);
   setup_oscillator(OSC_4MHz);
   setup_WDT(WDT_OFF);
   setup_SPI(SPI_disabled | SPI_SS_disabled);
   setup_timer_0(0 | 0 | 0);
   setup_timer_1(T1_disabled);
   setup_timer_2(T2_disabled, 255, 1);
   setup_CCP1(CCP_off);
   set_timer0(0);
   set_timer1(0);
   set_timer2(0);
   BH1750_init();
   lcd_init();
   lcd_putc("\f");
   lcd_gotoxy(1, 1);
   lcd_putc("Ambient Light/lx");
SShahryiar
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
