Target halts prematurely
Goto page Previous  1, 2
PostPosted: Fri Apr 14, 2017 12:04 pm     Reply with quote
What silicon revision is reported by MPLAB when the Pickit 3 connects
to the 16F1783 ?
JerryR
PostPosted: Fri Apr 14, 2017 12:10 pm     Reply with quote
OK. More news. Code seems to run fine (been here before, however) using a ICD3 debugger. Tested the PICKit3 on another target on another project using a PIC18F87J60 and it works fine. I wonder if there might be an issue with the PICKit3 on the PIC16F1783?
Stay tuned
Thanks!
JerryR
PostPosted: Fri Apr 14, 2017 12:50 pm     Reply with quote
PICkit 3 detected
Connecting to PICkit 3...
Firmware Suite Version...... 01.28.56
Firmware type......................Enhanced Midrange
PICkit 3 Connected.
Target Detected
Device ID Revision = 00000008
Programming...
Programming/Verify complete
Going to take a late lunch. Thanks for your help. I'll be back tonight.
PostPosted: Fri Apr 14, 2017 4:20 pm     Reply with quote
That's silicon revision B4, which is the latest one. The errata for that
revision doesn't list any CPU bugs. There are some quirks, but you're
not doing any of the things listed in the errata that could cause them.
http://ww1.microchip.com/downloads/en/DeviceDoc/80000541D.pdf
Look at the Pickit 3 settings and make sure you haven't set it a manually
restricted range of PIC addresses. You should select the following
option. It's the default:
Allow PICkit 3 to select memories and ranges
JerryR
PostPosted: Fri Apr 14, 2017 5:29 pm     Reply with quote
Yes, everything is pretty simple. I remember also having strange issues using the PICKit3 with another PIC16F device. I'll keep the group posted.
Thanks again for your help!
Page 2 of 2
