How to Name a Pin
sobinstn
How to Name a Pin
PostPosted: Thu Mar 02, 2017 1:12 pm     Reply with quote
How do I name a pin in PIC ccs compiler? Example name RB0 to Enable, so that I can use enable=1 for high and enable =0 for low?
jeremiah
PostPosted: Thu Mar 02, 2017 3:55 pm     Reply with quote
Usually in CCS you would use the following paradigm:
#define ENABLE PIN_A7
output_low(ENABLE);
output_high(ENABLE);
output_toggle(ENABLE);
...etc.
You can go:
#byte PORTB = <address or getenv() call>
#bit ENABLE = PORTB.0
ENABLE = 1;
But that is usually more hackish and used to work around bugs or unsupported functionality.
sobinstn
Thank you.. This is working..
PostPosted: Fri Mar 03, 2017 12:12 am     Reply with quote
output_low(ENABLE);
...etc.
You can go:
ENABLE = 1;
