PIC18F45K40 PORTD pullups
RicSToz87
PostPosted: Sun Feb 19, 2017 4:50 pm     Reply with quote
Hello!
I’m trying to set the internal pull-ups on PORTD in a PIC18F45K40. In the other ports I used port_x_pullups(), but in PORTD this function is not implemented. Verifying the PIC datasheet I found that PORTD have internal pull ups. How I can set this pull-ups?
Ricardo
PostPosted: Sun Feb 19, 2017 5:06 pm     Reply with quote
Always post your compiler version......
PostPosted: Sun Feb 19, 2017 5:11 pm     Reply with quote
Add this code above main(). Then you can use the function.
#byte WPUD = getenv("SFR:WPUD")
#define port_d_pullups(x) WPUD = x
Usage:
port_d_pullups(0xFF);  // Enable pull-ups on all PortD pins
Also, this needs to be reported to CCS support so they can add it.
RicSToz87
PORTD Pull-ups
PostPosted: Mon Feb 20, 2017 5:17 am     Reply with quote
SOLVED!!
Thanks PCM!
Ricardo
