wake-up PIC12f615 don't Work
Goto page Previous  1, 2, 3
Roberto da Rivoli
PostPosted: Sun Jan 22, 2017 1:08 pm     Reply with quote
I inserted a DELAY exaggerated 1s to avoid taking the second front of the OFF-ON-OFF button as I analyze the state in the "while" loop, but I did not get improvements.
void read_Puls(void)
   if(READ_HALL==0){
     if(old_HALL==1){
         if(stato==0){
           set_pwm1_duty(1000);  // OFF *********1000**************
           stato=1;
           delay_ms(200);
           Stato_Sleep=1;
         else if(stato==1){
//port_a_pullups(0x20);  // Enable pullups on pins GP5
I have to keep this line commented in "while" loop otherwise the program crashes
   if(Stato_Sleep==1){
  delay_us(10);
   disable_interrupts(GLOBAL);  //so no handler is needed
    temp8=input(PIN_A5);         //ensure this pin is read
    clear_interrupt(INT_RA);     //This is where 'RA' without the mask is used
    enable_interrupts(INT_RA5);  //now enable on the one pin
    sleep();
    delay_cycles(1);             //The instruction after a sleep should be a NOP
    Stato_Sleep=0;
  read_Puls();
PostPosted: Sun Jan 22, 2017 1:30 pm     Reply with quote
I'm not at a place where I have my hardware test setup. I'll try working
on it in hardware later, in the evening.
PostPosted: Mon Jan 23, 2017 1:24 am     Reply with quote
I got it to apparently work OK. It goes through the states repeatedly and
reliably. All state changes occur only on the down-press of the button.
It goes to sleep and stays in sleep until the button is pushed again.
I don't guarantee this is the best way to do. I just made it work.
I used a 12F615 on the Microchip Low Pin Count board for this test.
Pin A2 is connected to LED C0. This is the PWM LED.
Pin A4 is connected to LED C1. This is the Sleep LED. "On" = sleeping.
#include<12F615.h>
#FUSES INTRC                    //Internal RC Osc
#FUSES NOPUT                      //Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES IOSC8                    //INTOSC speed 8MHz
#FUSES NOWDT
#use delay(int=8M)
#use pwm(CCP1,TIMER=2,FREQUENCY=20000,DUTY=100)
//#use rs232(baud = 115000, xmit=PIN_A4)
#define uint8     unsigned int8
#define sint8     signed   int8
#define uint16    unsigned int16
#define sint16    signed int16
#define uint32    unsigned int32
#define sint32    signed int32
#define SEL_1                   PIN_A4
#define SEL_2                   PIN_A0
#define SEL_3                   PIN_A1
#define HALL                    PIN_A5
#define PWM                     PIN_A2
#define SLEEP_LED  PIN_A4
#define READ_SEL_1   input(SEL_1)
#define READ_SEL_2   input(SEL_2)
#define READ_SEL_3   input(SEL_3)
#define READ_HALL    input(HALL)
void Set_PORT(void);
void read_Puls(void);
uint8 Stato_Sleep=0;
int8 button_state = 1;
#int_ra
void ra_isr(void)
button_state = input(HALL);
if(button_state == 0)  // If button is down, disable IOC interrupts
   disable_interrupts(INT_RA5);
uint8 old_Hall = 1;
uint8 stato = 1;
int8 current_Hall;
current_Hall = input(HALL);
// If button is down, execute this block.
if(current_Hall == 0)
   if(old_Hall == 1)
      if(stato == 0)
         set_pwm1_duty(100);  // Bright LED shows in state 0
         stato = 1;
         Stato_Sleep = 1;
      else if(stato == 1)
         set_pwm1_duty(0);   // LED off shows in state 1
         stato = 2;
      else if(stato == 2)
         set_pwm1_duty(5); // Dim LED shows in state 2
         stato=0;
old_Hall = current_Hall;
delay_ms(10);
uint8 temp8=0;
Set_PORT();
   read_Puls();
   if(Stato_Sleep == 1)
      output_high(SLEEP_LED);   // Show we're in sleep code
      while(input(PIN_A5) == 0);  // Wait until switch is released
      delay_us(10);
      sleep();
      delay_cycles(1);
      Stato_Sleep=0;
      output_low(SLEEP_LED); // Show that we woke up from sleep
void Set_PORT(void)
output_a(0x00);
output_float(PIN_A5);
delay_us(20);
PostPosted: Mon Jan 23, 2017 3:22 am     Reply with quote
It is a little pointless to use the actual interrupt call, but the key thing is that he is using this to disable the IOC from actually happening on the key 'release'. If the key is down, he turns off the IOC in the handler, and he makes sure the sleep is not actually called until the key is released.
Key point is understanding that the interrupt is 'on change', so that it'll happen twice (at least - more with key bounces), on every key operation, and that you can't really go to sleep till the key is in the released position.....
Roberto da Rivoli
[SOLVED] Pic12f615 sleep dont Work
PostPosted: Mon Jan 23, 2017 12:52 pm     Reply with quote
With the solution proposed by "PCM programmer" seems to work properly, I introduced some modifications to match the applications.
Thanks "PCM programmer" and other programmers for support.
Page 3 of 3
