PIC24FJ256GB406 - ICD-U64 programming error
Goto page Previous  1, 2
charliumi
to gaugeguy
PostPosted: Wed Dec 14, 2016 6:38 am     Reply with quote
Could you share the Fuses configuration as you mentioned you successfully make it work ?
I found out today that there's a message on CCSLoad indicating that PCI25FJ256GB406 is not Yet supported.
Could someone from CCS shim in and give an official answer ?
newguy
PostPosted: Wed Dec 14, 2016 7:08 am     Reply with quote
No one from CCS monitors these forums. If you have a question for CCS, you have to ask them yourself.
gaugeguy
PostPosted: Wed Dec 14, 2016 7:54 am     Reply with quote
I tested with the PIC24FJ256GA406-I/PT
I am not sure if there would be any difference in the programming of the 'B' USB version, but I wouldn't expect any. Below are the configuration fuses from the list file.
Configuration Fuses:
   Word  1L: FCBF   NOWRTB NOBSS NOBS NOWRT PROTECT WPCFG PROTECT_CFG NOAIVT
          H: 0000
   Word  2L: FFFF
          H: 0000
   Word  3L: FFFF
          H: 0000
   Word  4L: FFFF
          H: 0000
   Word  5L: FFFF
          H: 0000
   Word  6L: 7FFF
          H: 0000
   Word  7L: FFE3   PR_PLL PLL4X IESO
          H: 0000
   Word  8L: FF1D   XT NOOSCIO SOSC_SEL PLL_FROM_PRIMARY NOIOL1WAY CKSFSM
          H: 0000
   Word  9L: F7FA   WPOSTS11 WDT128 WDT WINDIS WDTWIN_25% NOWDTCMX WDTCLK_LPRC
          H: 0000
   Word 10L: FFFF   BROWNOUT NOLVR
          H: 0000
   Word 11L: FFDF   ICSP1 NOJTAG NODEBUG NOBTSWP
          H: 0000
   Word 12L: FFFF   DSWDTCK_LPRC DSBOR DSWDT
          H: 0000
   Word 13L: FFFF   NOALTCMPI NOTMPRPIN NOTMPRWIPE VREFNORM
          H: 0000
[/code]
PostPosted: Wed Dec 14, 2016 10:11 am     Reply with quote
Just as a comment, the GA, and the GB chips use the same programming data sheet & algorithm. So the only difference will be the device ID probably not being supported...
charliumi
Conclusion - PCHWHD is buggy
PostPosted: Fri Dec 23, 2016 12:51 pm     Reply with quote
The issue was linked to the version of the compiler I used, which were not generated the appropriate set of instructions. I upgraded to the latest version (5.066), with same configuration and same board and the problem is gone. It works fine with both ICD64 and ICD80.
I found others issues since but I will share this on a separate thread.
Page 2 of 2
