Compiler issue: Wrong value in variable
Goto page Previous  1, 2
AHCCS
PostPosted: Wed Nov 16, 2016 6:26 am     Reply with quote
Not sure If this helps in identifyng the problem. I directly tried loading it using CCSLoad software and I found this issue
[img]
https://www.dropbox.com/sh/uz5799i7ebx3kev/AABZYL9bk0N2Zz-Y0ukm5LmBa?dl=0
[/img]
For some reason its always saying my Hex file is corrupt with 16 bytes out of range
Novice User
PostPosted: Wed Nov 16, 2016 9:10 am     Reply with quote
As I said:
"Does it behave the same without the debugger?"
I'm currently having to program chips with a Mach-X, and debug separately. The current releases of code for the debugger don't seem to properly support programming!...
Talk to CCS. A couple of other users have also reported problems. Seems to be with certain chip types.
Page 2 of 2
