Posted: Sat Jul 09, 2016 11:19 pm |
Deep breath.
You say that you are sending:
"!160707,16,1,0.35,10".
Your receive code though is looking for a null terminator.
You do realise, that if you send a string, _the null terminator does not get sent_.
The null terminator, is used inside C to mark the end of a string. When a string is printed, the print stops when it gets to this character.
This is why when sending the standard is to use your own character as a terminator. Very commonly the line feed. Then the receive code looks for the line feed, and substitutes the terminator. |
BLL
Joined: 11 Nov 2006 Posts: 181 Location: Birmingham, UK
Posted: Sun Jul 10, 2016 4:01 am |
Hi Ttelmah
Thanks for that. I hadn't thought of that.
I am pleased to say that the serial routines from SeeCwriter work flawlessly, so I have abandoned the ex_sisr methods.
I have been trying the checksum facility, which is new to me.
I see that he gets the checksum value by XORing the variable with each byte of the message, from the last to the first character. In his routines, it has a value of 16 for the string I am sending. However, when I try and do the same to generate the checksum at the transmit program, I get a value of nearly 90,000, so I'm foxed!!
Brian |
Joined: 01 Jul 2010 Posts: 9632 Location: Greensville,Ontario
Posted: Sun Jul 10, 2016 5:19 am |
re:
If you mean from the PI.. maybe it's cause the PI declare integers as 16 bits not 8 bits? or you don't clear out the checksum variable before doing the calculation ? Come to think of it 90,000 is even bigger than 65535( 16 bits) so 'something' is weird.
Jay |
Posted: Sun Jul 10, 2016 5:36 am |
| The Pi uses int32 as standard (it is a 32bit processor). You need to & the result with 0xFF. |
BLL
Posted: Sun Jul 10, 2016 8:03 am |
Thanks for that.
The other problem now!
I can send one of 2 strings, one sets the RTC and starts with a ?. The other clears the internal eeprom and sends a *.
(Each includes <STX> and <ETX>)
On first powering up, sending either string does as expected. However, if say I have sent the RTC string and the clock has set and then I send the reset string, it sets the time and day again. Sending the reset string again causes a reset.
Similarly, sending reset works, but then sending RTC resets again. The next sending of RTC string sets the RTC. I am using ResetMsg(&msg) each time.
Oh dear!!
Brian |
Posted: Sun Jul 10, 2016 8:33 am |
Whatever 'flag' you are setting to say 'I have found this particular message', is not being reset when you finish parsing the message.
Down to how your parser is written..... |
BLL
Posted: Sun Jul 10, 2016 11:02 am |
I am obviously misunderstanding what is going on and it's driving me nuts!
As I understand it, once the msg.done flag is set, the received message is in msg.ch.
I pass to my processing routine a pointer to msg.ch. It processes the data into an array, rcvData. As soon as I have used the info in rcvData, I clear it.
However, when the next message arrives and I process msg.ch, I get the same data as before, as rcvData gets filled with the same info.
This is what I don't understand. I have tried to clear msg.ch, but no difference. I don't know what else I am supposed to do!
Oh to see the wood for the trees!
Brian |
Posted: Sun Jul 10, 2016 11:32 am |
Your approach sounds far too complex.
Simply send your original string, with a line feed after it.
Then in the receive code, use:
//your header for processor
#use rs232(UART1, baud=9600, ERRORS)
#define BUFFER_SIZE 32
char buffer[BUFFER_SIZE][2];
int8 in_use=0;
int1 have_line=FALSE;
#define READ_BUFFER &buffer[0][in_use^1]
//This gives the address of the 'out of use' buffer
#int_rda
void serial_isr(void)
int8 t;
static int8 next_in=0;
t=getc();
if (t=='\n')
buffer[next_in]='\0';
next_in=0;
in_use ^=1; //toggle buffer
have_line=TRUE;
buffer[next_in][in_use]=t;
if (++next_in==BUFFER_SIZE-1)
next_in--; //lock at end of buffer
//This uses two 'line' buffers, instead of a circular buffer.
//When a line feed is seen, it terminates the current one, sets the
//flag 'have_line', and starts using the second buffer.
//Then you need a function 'process' defined, expecting a pointer
//to a character array.
//Then in your main
enable_interrupts(INT_RDA);
//and anything else you need
while (TRUE)
if (have_line)
have_line=FALSE;
process(READ_BUFFER);
Then 'process', receives the address of the start of a line containing your data. Terminated with a null (so string functions etc., will work), and this will stay unchanged, till the next line is complete. Since you only call it when a line is seen, no need to clear things etc. etc.. The buffer will stop filling when it gets full (31 characters max). |
BLL
Posted: Sun Jul 10, 2016 1:31 pm |
Hi Ttelmah, Thanks for the code.
I have set it up but the compiler is complaining on the line:
buffer[next_in] = '\0';
saying "Expecting LVALUE such as variable name or *expression!
Do I presume correctly that it should read buffer[next_in][0] = '\0'; ?
Brian |
BLL
Posted: Sun Jul 10, 2016 3:03 pm |
Hi Ttelmah, The program is working but I am getting gibberish!
If I send just an * plus\n, I get **,,1100,,,610,700.83,,
sending a string as ?YYDDMMhhmmss plus \n, I get something like:
?*1166007711,,1100,,,610,700.83,,
I'm sure it's me! Here's the listing:
| Code: | #include <18LF4620.h>
#FUSES H4
#use delay(clock=40MHz,crystal=10MHz)
#include <Flex_LCD420.c>
int8 in_use = 0;
int1 have_line = FALSE;
char rcvData[30][12];
void process(char *p);
#int_rda
int8 t;
static int8 next_in = 0;
t = getc();
if(t == '\n')
next_in = 0;
in_use ^= 1; //toggle buffer
have_line = TRUE;
buffer[next_in][IN_USE] = t;
if(++next_in == BUFFER_SIZE - 1)
lcd_init();
lcd_load_custom_chars();
if(have_line)
have_line = FALSE;
delay_ms(300);
void process(char* p)
int i=0, j=0;
while(*p != '\n')
if(*p != ',')
rcvData[j][i] = *p;
i++;
}//end if *p..
rcvData[j][i] = '\0';
i = 0;
j++;
}// end else
p++;
}//end while
lcd_putc("\f");
//printf(lcd_putc,"items %u", j+1);
lcd_gotoxy(1,2);
for(i = 0; i < j;i++)
printf(lcd_putc,"%s,", rcvData[i]);
for(i=0;i!=30;i++)
for(j=0;j!=12;j++)
rcvData[i][j] = '\0';
Brian |
Posted: Mon Jul 11, 2016 6:44 am |
| BLL wrote: | Hi Ttelmah, Thanks for the code.
Brian |
No, it needs to write to the in_use buffer. So:
read buffer[next_in][in_use] = '\0';
Otherwise it'll alternatively terminate the wrong buffer!.
This would probably give your garbage....  |
BLL
Posted: Mon Jul 11, 2016 12:25 pm |
Hi Ttelmah, Thanks for the correction, but it still gives gibberish! I did find that my parsing routine was not bomb-proof and rewrote it in a simple test program:
//test decoding of data strings from RasPi
#include <Decoder.h>
#include <string.h>
int8 j = 0;
char info[30];
char rcvData[20][40];
void process(char*);
int8 i;
lcd_init();
memset(rcvData, '\0', sizeof(rcvData));
strcpy(info, "?16,07,11,14:20:30\n");
//to be valid, data must end in an LF and not only be an LF
//jump over command char at info[0]
if(info[strlen(info)-1] == '\n' && strlen(info) > 1)
process(&info[1]);
for(i = 0; i < j + 1; i++)
printf(lcd_putc,"%s,",rcvData[i]);
lcd_putc("\b");
lcd_putc(' ');
int8 i = 0;
do
if(*p != ',')
rcvData[j][i] = *p;
i++;
}//end if *p..
i = 0;
j++;
}//end else
p++;
}while(*p != '\n');
return(j);
With this, only a string with one or more characters before a LF is processed. The processing is done correctly, regardless of the string length.
I incorporated just the function into your code, so process(READ_MESSAGE); calls my function. It doesn't work correctly.
If I put a printf line at the start of process, to read just the 0th character, this reads correctly.
It is interesting to note that sending a string starting with ?160711 shows as ??116600771111. The characters are there but duplicated! This must shed light on the problem, but I can't fathom it.
Brian |
jeremiah
Posted: Wed Jul 13, 2016 8:52 am |
I tried your process function and found it still had quite a few holes and led to some gibberish outputs when hitting edge conditions.
Last night I took some time to lay out some functions to do the work load. I went back to a same old circular buffer implementation and did the line acquiring and parsing in two separate main functions.
Note that I don't have the same CHIP or LCD as you so I had to test with what I had, but the following code worked for me rather well and handled all the edge conditions I could come up with in a short time. Note that my LCD functions are a bit different so you will have to adjust to your liking. I didn't have a \b character implemented, so I just left the trailing ',' characters. Also, I didn't put in any code to handle an input where a \n follows a ',' (neither did your old code).
Compiled with 5.059 and tested on my dev board with LCD
#include "pic.h" //my FUSES, #use delay(), #use rs232(), pin defs, etc.
#include "lcd.h" //my lcd driver...different than yours
#include <string.h>
// Interrupt driven serial routines
#define BUFFER_SIZE 255
volatile BYTE buffer[BUFFER_SIZE];
volatile BYTE next_in = 0;
volatile BYTE next_out = 0;
#if BUFFER_SIZE >= 256
#error Size of buffer ( BUFFER_SIZE ) is too large for the index type
#int_rda
void serial_isr() {
BYTE temp_next;
BYTE temp_char;
temp_char = getc();
temp_next = next_in + 1;
//Wrap index if it reaches buffer size
if(temp_next >= BUFFER_SIZE){
temp_next = 0;
//if there is space, the add character
if(temp_next != next_out){
buffer[next_in] = temp_char;
next_in = temp_next;
#define bkbhit (next_in != next_out)
BYTE bgetc() {
BYTE c;
BYTE temp_next;
temp_next = next_out + 1;
temp_next = 0;
while(!bkbhit) ;
c=buffer[next_out];
next_out = temp_next;
return(c);
// Data processing routines
#define DATA_ROWS 20
#define DATA_COLS 40
#define TERMINATOR '\n'
#define SEPARATOR ','
#define END_OF_STR '\0'
//I use this type to easily pass a 2D array by reference
typedef struct{
char rx_data[DATA_ROWS][DATA_COLS];
} rx_data_t;
unsigned int8 process
(char * input,
rx_data_t * output,
unsigned int8 max_rows,
unsigned int8 max_cols)
unsigned int8 row = 0;
unsigned int8 col = 0;
if(max_rows == 0 || max_cols == 0){
return 0;
while(*input != TERMINATOR){
switch(*input){
//catches case where \0 happens before a , or \n
case END_OF_STR:
output->rx_data[row++][col] = END_OF_STR;
return row;
//finish current row and start another
case SEPARATOR:
if(row >= max_rows){
return row;
col = 0;
//normal character copy
default:
output->rx_data[row][col++] = *input;
if(col >= max_cols){
output->rx_data[row++][col-1] = END_OF_STR;
return row;
input++;
//last character finished so convert \n to \0
return row;
BOOLEAN wait_on_line(char * buffer, unsigned int8 size){
BYTE index = 0;
if(size == 0){
return FALSE;
while(index < (size-1)){ //need room for \0
if(bkbhit){
buffer[index] = bgetc();
switch(buffer[index++]){
//catches if '\0' happens inadvertantly
case END_OF_STR:
return FALSE;
//found an line so done
case TERMINATOR:
buffer[index] = END_OF_STR; /***********IMPORTANT************/
return TRUE;
default:
//never found a line and ran out of space
buffer[size-1] = END_OF_STR; /***********IMPORTANT************/
return FALSE;
// Main program
BYTE data[BUFFER_SIZE];
int8 i,numRows;
rx_data_t rcv_data;
lcd_init(); //default pin settings
delay_ms(1000); //need time for the LCD to powerup ok
lcd_powerOn(); //send configuration commands
lcd_clear(); //clears the display and sets cursor to 0,0
enable_interrupts(int_rda);
enable_interrupts(global);
printf("\r\n\Running...\r\n");
// The program will delay for 10 seconds and then display
// any data that came in during the 10 second delay
printf("\r\nBuffered data => \r\n");
do {
if(wait_on_line(data,sizeof(data))){
if(strlen(data) > 1){
lcd_clear();
memset(&rcv_data, '\0', sizeof(rx_data_t));
numRows = process(data,
&rcv_data,
DATA_ROWS,
DATA_COLS);
printf("Data: %s => ", data);
for(i = 0; i < numRows; i++){
printf(lcd_putc,"%s,",rcv_data.rx_data[i]);
printf("%s,",rcv_data.rx_data[i]);
printf("\r\n");
}else{
printf("Empty String\r\n");
}else{
printf("Error waiting on line\r\n");
} while (TRUE);
#include "lcd.c"
BLL
Posted: Wed Jul 13, 2016 9:06 am |
Hi Ttelmah
I have finally got the code working, although I don't understand why the problem and why the solution works!
I confirmed that buffer was getting 2 of everything. So, if I sent ?160713,
buffer contained ??116600771133. I don't see why.
The only cure was to copy the contents of buffer to a string:
| Code: | //this eliminates the double characters!
char data[BUFFER_SIZE];
for(l=0; l < BUFFER_SIZE-1; l++)
data[l] = buffer[l][!IN_USE]; |
I then passed this string to the process function and all was fine.
It now works as expected, but I would like to know why the buffer problem and why the solution works!!!
Thanks for your help.
Brian |
BLL
Posted: Wed Jul 13, 2016 9:11 am |
Hi Jeremiah
Thank you so much for taking the time to produce the code. I shall study it and try it.
You have probably seen my post to Ttelmah, saying that his code is now working fine after a very strange problem.
Considering, I am only sending short strings of data very infrequently, I have been surprised at the problems I have had.
So far, I am not getting any bad data and all is fine.
Thank you for your help.
Brian |
