rs232 - Hardware or software SOLVED
Goto page Previous  1, 2
PostPosted: Tue May 31, 2016 4:51 pm     Reply with quote
One thing to consider is that this pin may have several other uses and nornally you have to specifically 'disable' those functions. Perhaps this is part of the problem?
As an example...some PICs have the 'comparators' defaulted on and you MUST specifically disable them.
just an idea..
Jay
gjs_rsdi
PostPosted: Tue May 31, 2016 11:05 pm     Reply with quote
Thanks temtronic
Will go again true the data sheet and the LST, will post the findings if I will have some results
Best wishes
Joe
PostPosted: Wed Jun 01, 2016 12:26 am     Reply with quote
Have you turned off TXEN?.
Otherwise it will be driven high by the UART.
gjs_rsdi
PostPosted: Wed Jun 01, 2016 1:35 am     Reply with quote
Hi Ttelmah
if you mean:
disable_interrupts(INT_TBE);
Yes. Also in the LST don't have routine for tx
Best wishes
Joe
PostPosted: Wed Jun 01, 2016 1:55 am     Reply with quote
No.....
Read the thread I pointed to.
To use the TX pin as a normal pin, you have to disable the TXEN bit. The thread shows how to do this.
gjs_rsdi
PostPosted: Wed Jun 01, 2016 3:50 pm     Reply with quote
Thanks again Ttelmah Smile
I wish CCS was giving such information (or maybe I miss it)
It works perfect!!!
Even the RX pin works fine, should I do the same thing for it?
#bit RXEN=getenv("BIT:RXEN")
& in the main
RXEN=FALSE;
Best wishes
Joe
Page 2 of 2
