PWM from the data sheet
Goto page Previous  1, 2
johnl
PostPosted: Wed Feb 24, 2016 3:48 pm     Reply with quote
Ttelmah wrote:
You'd tried to use #use PWM. With a period of 32MHz...
Oh no no no.. That was only in a comment in the code I labelled "Source A" from a previous post. Sorry for leaving that in and causing confusion.
Actually, that is the code ("A") that seems to be reliable. Every time I build and program a chip with it ,PWM works.
Just tried another experiment with "Source B" (your code). Two out of three chips did not work, but one did. I read the code from all three and the checksums all match. Now I'm really confused.
PostPosted: Wed Feb 24, 2016 5:08 pm     Reply with quote
hmm...might be a hardware issue, are all three tried on different PCBs or the same one ?
Jay
johnl
PostPosted: Wed Feb 24, 2016 5:23 pm     Reply with quote
Jay
All three in the same socket one at a time on the same board which is only a perf board wired to a bypass cap and a power supply. Only Vdd and ground connected. Nothing else. The output on C3 always works, so I know the chip is executing. Just the PWM output on C2 is the problem.
Here's the thing:
Code "A" (using the registers directly and only the duty cycle CCS function) works every time.
Code "B" (using the CCS functions) works only some times.
Silicon or compiler bug?
PostPosted: Wed Feb 24, 2016 5:44 pm     Reply with quote
1. Does this mean the bypass cap is close to the power supply ?
Is there a 100 nF bypass cap from the Vdd pin on the PIC to ground ?
Is the cap very close to the Vdd pin on the PIC ? You need this.
2. Is there a pull-up resistor (to Vdd) connected to the MCLR pin ?
johnl
PostPosted: Wed Feb 24, 2016 6:08 pm     Reply with quote
1. The 0.1 uF cap is across pins 1 and 14. Also there is a second cap of 0.47uF across the pins. Both mounted as close as they can be to the pins.
2. No. Datasheet says a PU is there for MCLR. Also voltage on the pin measures Vdd (5v) so I think it is working.
Edit: I should mention that the project has just changed and I'll be using a 16F1788 instead. So solving this problem isn't critical now, but I am very curious why it happens. Thanks much.
johnl
PostPosted: Thu Feb 25, 2016 11:45 am     Reply with quote
In case anyone is interested...
Here's the assembly listing for the "B" code (the one with the CCS functions that doesn't work all the time.)
.................... #fuses INTRC_IO,NOWDT, PUT, MCLR, NOPROTECT,NOBROWNOUT, NODEBUG, NOLVP
.................... #fuses NOPPS1WAY
.................... #use delay(INTERNAL = 32000000)
0003:  MOVLW  02
0004:  SUBWF  26,F
0005:  BTFSS  03.0
0006:  GOTO   014
0007:  MOVLW  20
0008:  MOVWF  05
0009:  MOVLW  06
000A:  MOVWF  04
000B:  MOVF   00,W
000C:  BTFSC  03.2
000D:  GOTO   014
000E:  GOTO   012
000F:  GOTO   010
0010:  GOTO   011
0011:  NOP
0012:  DECFSZ 00,F
0013:  GOTO   00F
0014:  MOVLP  00
0015:  GOTO   05C (RETURN)
.................... #PIN_SELECT PWM5=PIN_C2 //select the PWM 5 pin
.................... void main(void)
0016:  MOVLW  55
0017:  MOVLB  1C
0018:  MOVWF  0F
0019:  MOVLW  AA
001A:  MOVWF  0F
001B:  BCF    0F.0
001C:  MOVLW  10
001D:  MOVLB  1D
001E:  MOVWF  22
001F:  MOVLW  55
0020:  MOVLB  1C
0021:  MOVWF  0F
0022:  MOVLW  AA
0023:  MOVWF  0F
0024:  BSF    0F.0
0025:  MOVLW  F0
0026:  MOVLB  01
0027:  MOVWF  19
0028:  MOVLB  03
0029:  CLRF   0C
002A:  CLRF   0E
002B:  MOVLB  02
002C:  CLRF   12
002D:  CLRF   13
002E:  CLRF   11
002F:  MOVLW  04
0030:  MOVWF  10
0031:  MOVLB  00
0032:  CLRF   20
0033:  CLRF   21
....................    port_a_pullups(0xFF); //8 bit mask required
0034:  MOVLW  FF
0035:  MOVLB  04
0036:  MOVWF  0C
0037:  MOVLB  01
0038:  BCF    15.7
....................    port_c_pullups(0xFF);
0039:  MOVLB  04
003A:  MOVWF  0E
....................    set_tris_c(0);
003B:  MOVLW  00
003C:  MOVLB  01
003D:  MOVWF  0E
....................    setup_pwm5(PWM_STANDARD | PWM_CLK_FOSC | PWM_CLK_DIV_BY_1);
003E:  MOVLB  1B
003F:  BCF    1B.7
0040:  MOVLB  01
0041:  BCF    0E.2
0042:  MOVLB  1B
0043:  CLRF   20
0044:  CLRF   5F
0045:  CLRF   5C
0046:  CLRF   1E
0047:  MOVLW  80
0048:  MOVWF  1B
....................    set_pwm5_period(0x3FFF);
0049:  MOVLW  3F
004A:  MOVWF  16
004B:  MOVLW  FF
004C:  MOVWF  15
004D:  BSF    1F.7
....................    set_pwm5_duty(0x1FFF);
004E:  MOVLW  1F
004F:  MOVWF  14
0050:  MOVLW  FF
0051:  MOVWF  13
0052:  BSF    1F.7
....................    while(TRUE)
....................       output_toggle(PIN_C3);  //chip is alive. Instruction clock = 8 MHz
0053:  MOVLB  01
0054:  BCF    0E.3
0055:  MOVLW  08
0056:  MOVLB  02
0057:  XORWF  0E,F
....................       delay_us(125);
0058:  MOVLW  7D
0059:  MOVLB  00
005A:  MOVWF  26
005B:  GOTO   003
005C:  MOVLB  1B
005D:  GOTO   053
005E:  SLEEP
Configuration Fuses:
   Word  1: 39C4   INTRC_IO NOWDT PUT MCLR NOPROTECT NOBROWNOUT NOCLKOUT IESO FCMEN
   Word  2: 1EFB   NOWRT NOPPS1WAY ZCDDIS NOPLLEN STVREN BORV19 NOLPBOR NODEBUG NOLVP
johnl
PostPosted: Thu Feb 25, 2016 11:47 am     Reply with quote
... and the listing for the "A" code (the one that works all the time.)
.................... #fuses INTRC_IO,NOWDT,PUT,MCLR,NOPROTECT,NOBROWNOUT, PLLEN,NODEBUG,NOLVP,
.................... #use delay(clock = 32000000)
.................... #byte PWM5PRH       = 0xD96
.................... #byte PWM5PRL       = 0xD95
.................... #byte PWM5DCH       = 0xD94
.................... #byte PWM5DCL       = 0xD93
.................... #byte PWM5CON       = 0xD9B
.................... #byte PWM5CLKCON    = 0xD9E
.................... #byte RC2PPS        = 0xEA2
.................... #byte PWM5PHL       = 0xD91
.................... #byte PWM5PHH       = 0xD92
.................... #word PWM5DC = getenv("SFR:PWM5DCL")
.................... ////#use pwm(pwm5, output=PIN_C2, period=32000000,pwm_on)
0003:  MOVLW  F0
0004:  MOVLB  01
0005:  MOVWF  19
0006:  MOVLB  03
0007:  CLRF   0C
0008:  CLRF   0E
0009:  MOVLB  02
000A:  CLRF   12
000B:  CLRF   13
000C:  CLRF   11
000D:  MOVLW  04
000E:  MOVWF  10
000F:  MOVLB  00
0010:  CLRF   20
0011:  CLRF   21
....................    int X;
....................    port_a_pullups(0b11111);
0012:  MOVLW  1F
0013:  MOVLB  04
0014:  MOVWF  0C
0015:  MOVLB  01
0016:  BCF    15.7
....................    port_c_pullups(0b11111);
0017:  MOVLB  04
0018:  MOVWF  0E
0019:  MOVLW  00
001A:  MOVLB  01
001B:  MOVWF  0E
....................    setup_adc(ADC_OFF);
001C:  BCF    1D.0
.................... PWM5PRH       = 0x3F;
001D:  MOVLW  3F
001E:  MOVLB  1B
001F:  MOVWF  16
.................... PWM5PRL       = 0xFF;
0020:  MOVLW  FF
0021:  MOVWF  15
.................... PWM5DCH       = 0; //0x1F;  // 1FFF ----> 50% DC
0022:  CLRF   14
.................... PWM5DCL       = 0xFF;
0023:  MOVWF  13
.................... PWM5CON       = 0x80;
0024:  MOVLW  80
0025:  MOVWF  1B
.................... PWM5CLKCON    = 0x0;    // Fosc source
0026:  CLRF   1E
.................... RC2PPS        = 0x10;   //PWM5 out on C2
0027:  MOVLW  10
0028:  MOVLB  1D
0029:  MOVWF  22
.................... PWM5PHL       = 0x0;
002A:  MOVLB  1B
002B:  CLRF   11
.................... PWM5PHH       = 0x0;
002C:  CLRF   12
.................... set_pwm5_duty(7000);
002D:  MOVLW  1B
002E:  MOVWF  14
002F:  MOVLW  58
0030:  MOVWF  13
0031:  BSF    1F.7
....................   while(1)
0032:  MOVLB  01
0033:  BCF    0E.3
0034:  MOVLW  08
0035:  MOVLB  02
0036:  XORWF  0E,F
....................    delay_cycles(250);
0037:  MOVLW  53
0038:  MOVWF  77
0039:  DECFSZ 77,F
003A:  GOTO   039
....................    delay_cycles(250);    delay_cycles(250);    delay_cycles(250);
003B:  MOVLW  53
003C:  MOVWF  77
003D:  DECFSZ 77,F
003E:  GOTO   03D
003F:  MOVLW  53
0040:  MOVWF  77
0041:  DECFSZ 77,F
0042:  GOTO   041
0043:  MOVLW  53
0044:  MOVWF  77
0045:  DECFSZ 77,F
0046:  GOTO   045
0047:  MOVLB  1B
0048:  GOTO   032
0049:  SLEEP
   Word  2: 1EFF   NOWRT PPS1WAY ZCDDIS NOPLLEN STVREN BORV19 NOLPBOR NODEBUG NOLVP
asmboy
PostPosted: Thu Feb 25, 2016 12:15 pm     Reply with quote
hoping to be helpful with one thing:
you use set_tris();
thus you ought to read about
#USE FAST_IO
for it's implications to coding
PostPosted: Thu Feb 25, 2016 12:27 pm     Reply with quote
first programs fuses....
second programs fuses....
NOT the same ! Don't know if it's important but not apples vs apples
haven't checked anything else as this 'bothers' me...
Jay
johnl
PostPosted: Thu Feb 25, 2016 12:41 pm     Reply with quote
Nope. I commented out #fuses NOPPS1WAY on the B version and it still didn't work (2 out of three chips had no PWM output.)
PostPosted: Thu Feb 25, 2016 1:40 pm     Reply with quote
I looked at the asm but you actually have some thing different so I can't compare 'apples to apples'.
Hate to be 'nitpicky' but it'd be nice if they were apples and apples.
I know the 'LED function doesn't really matter but......
things like setting up port a might....
Jay
Page 2 of 2
