bootloader
Goto page Previous  1, 2, 3  Next
davidd
PostPosted: Thu Jan 28, 2016 12:58 pm     Reply with quote
ok
try placing some activity in application() like a blinking LED, then start from scratch and load only the bootloader. then reset and let it ride.
if application runs it means bootloader is working and all your fuses are correct etc...
SeeCwriter
PostPosted: Thu Jan 28, 2016 2:03 pm     Reply with quote
If I add any code to application() I get a compiler error about the code overrunning the segment. If I increase the end address of the #org statement to increase the size of the segment, I compiler error Invalid ORG range.
davidd
PostPosted: Thu Jan 28, 2016 6:15 pm     Reply with quote
You should be able to put something there.
Double check bootloader asm file and make sure no address is greater than 0x500.
edit: is there an #ORG range for application() ? maybe you have to change that.
SeeCwriter
PostPosted: Thu Jan 28, 2016 7:48 pm     Reply with quote
This is application:
#org LOADER_END+2, LOADER_END+4
void application(void) {
  while(TRUE) {
      //output_high( HEARTBEAT_LED );
      //delay_ms(100);
      //output_low( HEARTBEAT_LED );
      //delay_ms(100);
If I change the end address, I get a compiler error "invalid ORG Range."
The segment appears to be only 2-byte long. According to the list file it's address range is 0x500 - 0x502.
davidd
PostPosted: Thu Jan 28, 2016 7:51 pm     Reply with quote
increase loader_end+20, see what happens...
SeeCwriter
PostPosted: Fri Jan 29, 2016 9:38 am     Reply with quote
Compiler output with "loader_end+20":
Line 31: More info: Segment at 00000-00502 (0000 used)
Line 31: More info: Segment at 00504-0FFFE (0000 used) Priv
Line 31: More info: Segment at 10000-1FFFE (0000 used) Priv
Line 31: More info: Attempted to create: 00500-00512 for #org
Error 126 "gatrBL.c" Line 31: Invalid ORG range
davidd
PostPosted: Fri Jan 29, 2016 9:43 am     Reply with quote
Can you please post the asm file?
SeeCwriter
PostPosted: Fri Jan 29, 2016 10:06 am     Reply with quote
Because there was a compiler error a list file was not created. But here is the list for the last good compile from yesterday at 3pm:
CCS PCH C Compiler, Version 5.054, 26313               28-Jan-16 15:00
               Filename:   C:\Projects\Pic\GATR\gatrBL.lst
               ROM used:   922 bytes (1%)
                           Largest free fragment is 65536
               RAM used:   73 (2%) at main() level
                           128 (3%) worst case
               Stack used: 2 locations (1 in main + 1 for interrupts)
               Stack size: 31
00000:  GOTO   0322
.................... #include <gatrBL.h>
.................... #include <18F67K22.h>
.................... //////////// Standard Header file for the PIC18F67K22 device ////////////////
.................... ////        (C) Copyright 1996, 2014 Custom Computer Services          ////
.................... //// This source code may only be used by licensed users of the CCS C  ////
.................... //// compiler.  This source code may only be distributed to other      ////
.................... //// licensed users of the CCS C compiler.  No other use, reproduction ////
.................... //// or distribution is permitted without written permission.          ////
.................... //// Derivative programs created using this software in object code    ////
.................... //// form are not restricted in any way.                               ////
.................... #device PIC18F67K22
0001E:  DATA 0D,0A
00020:  DATA 53,65
00022:  DATA 72,69
00024:  DATA 61,6C
00026:  DATA 20,42
00028:  DATA 6F,6F
0002A:  DATA 74,6C
0002C:  DATA 6F,61
0002E:  DATA 64,65
00030:  DATA 72,20
00032:  DATA 76,31
00034:  DATA 2E,30
00036:  DATA 0D,0A
00038:  DATA 00,00
0003A:  DATA 57,61
0003C:  DATA 69,74
0003E:  DATA 69,6E
00040:  DATA 67,20
00042:  DATA 66,6F
00044:  DATA 72,20
00046:  DATA 64,6F
00048:  DATA 77,6E
0004A:  DATA 6C,6F
0004C:  DATA 61,64
0004E:  DATA 2E,2E
00050:  DATA 2E,00
00052:  TBLRD*+
00054:  MOVF   FF5,F
00056:  BZ    007A
00058:  MOVFF  FF6,49
0005C:  MOVFF  FF7,4A
00060:  MOVFF  FF8,4B
00064:  MOVF   FF5,W
00066:  BTFSS  F9E.4
00068:  BRA    0066
0006A:  MOVWF  FAD
0006C:  MOVFF  49,FF6
00070:  MOVFF  4A,FF7
00074:  MOVFF  4B,FF8
00078:  BRA    0052
0007A:  RETURN 0
000EA:  MOVF   FF2,W
000EC:  MOVWF  03
000EE:  BCF    FF2.7
000F0:  BSF    F7F.7
000F2:  BSF    F7F.2
000F4:  MOVLB  F
000F6:  MOVLW  55
000F8:  MOVWF  F7E
000FA:  MOVLW  AA
000FC:  MOVWF  F7E
000FE:  BSF    F7F.1
00100:  NOP
00102:  MOVF   03,W
00104:  IORWF  FF2,F
00106:  MOVLB  0
00108:  RETURN 0
0010A:  BSF    FD0.6
0010C:  BCF    F7F.6
0010E:  MOVF   FF6,W
00110:  ANDLW  7F
00112:  MOVWF  00
00114:  MOVLW  80
00116:  ANDWF  FF6,F
00118:  TBLRD*-
0011A:  MOVFF  77,01
0011E:  TSTFSZ 00
00120:  BRA    0130
00122:  MOVFF  FEE,FF5
00126:  MOVF   01,F
00128:  BZ    0132
0012A:  TBLWT+*
0012C:  DECF   01,F
0012E:  BRA    0136
00130:  DECF   00,F
00132:  TBLRD+*
00134:  TBLWT*
00136:  MOVLW  7F
00138:  ANDWF  FF6,W
0013A:  XORLW  7F
0013C:  BNZ   011E
0013E:  BSF    F7F.4
00140:  RCALL  00EA
00142:  RCALL  00EA
00144:  TSTFSZ 01
00146:  BRA    011E
00148:  CLRF   FF8
0014A:  GOTO   0300 (RETURN)
.................... #list
.................... #device ADC=16
.................... ** These fuses must match the fuses in the main application.
.................... #FUSES PUT
.................... #FUSES HSM
.................... #FUSES NOWDT        // Enable Watch Dog Timer
.................... #FUSES WDT512       // Watch Dog Timer uses 1:512 Postscale for 2-sec timeout.
.................... #FUSES BORV30            // Brown-out Reset at 3.0V.
.................... //#define BOOTLOADER_AT_START
.................... #define BOOTLOADER_STREAM COM1
.................... //#use delay(clock=40000000,crystal=10000000)
.................... #use delay(clock=64000000,internal=16000000,restart_wdt)
.................... #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=BOOTLOADER_STREAM)
0007C:  BTFSS  F9E.4
0007E:  BRA    007C
00080:  MOVWF  FAD
00082:  RETURN 0
.................... #define _bootloader
.................... // NOTE - User must include bootloader.h in application program
.................... #include <bootloader.h>
.................... ////                       BOOTLOADER.H                                ////
.................... ////  This include file must be included by any application loaded     ////
.................... ////  by the example bootloader (ex_bootloader.c).                     ////
.................... ////  The directives in this file relocate the reset and interrupt     ////
.................... ////  vectors as well as reserving space for the bootloader.           ////
.................... ////  LOADER_END may need to be adjusted for a specific chip and       ////
.................... ////  bootloader.  LOADER_END must be 1 minus a multiple of            ////
.................... ////  FLASH_ERASE_SIZE.                                                ////
.................... ////        (C) Copyright 1996,2014 Custom Computer Services           ////
.................... //// This source code may only be used by licensed users of the CCS    ////
.................... //// C compiler.  This source code may only be distributed to other    ////
.................... //// licensed users of the CCS C compiler.  No other use,              ////
.................... //// reproduction or distribution is permitted without written         ////
.................... //// permission.  Derivative programs created using this software      ////
.................... //// in object code form are not restricted in any way.                ////
.................... #ifndef __BOOTLOADER_H__
.................... #define __BOOTLOADER_H__
.................... #ifndef LOADER_END
....................  #if defined(__PCM__)
....................   #ifdef BOOTLOADER_MODE2X
....................    #define LOADER_END 0x4BF
....................   #else
....................    #define LOADER_END 0x33F
....................   #endif
....................  #elif defined(__PCH__)
....................   #define FLASH_SIZE getenv("FLASH_ERASE_SIZE")
....................   #if ((0x500 % FLASH_SIZE) == 0)         //IF 0x500 is even flash boundary
....................    #define LOADER_END   0x4FF
....................   #else                                  //ELSE, goto next even boundary
....................    #define LOADER_END   ((0x500+FLASH_SIZE-(0x500 % FLASH_SIZE))-1)
....................   #error Bootloader only works with PCM or PCH compiler
.................... #define LOADER_SIZE   LOADER_END
.................... #ifndef BOOTLOADER_AT_START
....................  #define BOOTLOADER_AT_START
.................... #ifndef _bootloader
....................   #build(reset=LOADER_END+1, interrupt=LOADER_END+5)
....................   #build(reset=LOADER_END+1, interrupt=LOADER_END+9)
....................  #org 0, LOADER_END {}
....................  #ifdef __PCM__
....................   #if getenv("PROGRAM_MEMORY") <= 0x800
....................    #org LOADER_END+3, (getenv("PROGRAM_MEMORY") - 1) {}
....................    #org LOADER_END+3, 0x7FF {}
....................    #if getenv("PROGRAM_MEMORY") <= 0x1000
....................     #org 0x800, (getenv("PROGRAM_MEMORY") - 1) {}
....................     #org 0x800, 0xFFF{}
....................     #if getenv("PROGRAM_MEMORY") <= 0x1800
....................      #org 0x1000, (getenv("PROGRAM_MEMORY") - 1) {}
....................      #org 0x1000, 0x17FF {}
....................      #if getenv("PROGRAM_MEMORY") <= 0x2000
....................       #org 0x1800, (getenv("PROGRAM_MEMORY") - 1) {}
....................       #org 0x1800, 0x1FFF {}
....................       #if getenv("PROGRAM_MEMORY") <= 0x2800
....................        #org 0x2000, (getenv("PROGRAM_MEMORY") - 1) {}
....................        #org 0x2000, 0x27FF {}
....................        #if getenv("PROGRAM_MEMORY") <= 0x3000
....................         #org 0x2800, (getenv("PROGRAM_MEMORY") - 1) {}
....................         #org 0x2800, 0x2FFF {}
....................         #if getenv("PROGRAM_MEMORY") <= 0x3800
....................          #org 0x3000, (getenv("PROGRAM_MEMORY") - 1) {}
....................          #org 0x3000, 0x37FF {}
....................          #org 0x3800, 0x3FFF {}
....................   #if getenv("PROGRAM_MEMORY") <= 0x10000
....................    #org LOADER_END+5, (getenv("PROGRAM_MEMORY") - 1) {}
....................    #org LOADER_END+5, 0xFFFE {}
....................    #org 0x10000, (getenv("PROGRAM_MEMORY") - 1) {}
.................... #include <loader.c>
.................... ////                         loader.c                                  ////
.................... //// This driver will take an Intel 8-bit Hex file over RS232 channels ////
.................... //// and modify the flash program memory with the new code.  A proxy   ////
.................... //// function is required to sit between the real loading function     ////
.................... //// and the main code because the #org preprocessor command could     ////
.................... //// possibly change the order of functions within a defined block.    ////
.................... //// After each good line, the loader sends an ACKLOD character.  The  ////
.................... //// driver uses XON/XOFF flow control.  Also, any buffer on the PC    ////
.................... //// UART must be turned off, or to its lowest setting, otherwise it   ////
.................... //// will miss data.                                                   ////
....................  #define LOADER_END      getenv("PROGRAM_MEMORY")-1
....................   #define LOADER_SIZE   0x27F
....................   #if (getenv("PROGRAM_MEMORY") % getenv("FLASH_ERASE_SIZE")) == 0
....................    #define LOADER_SIZE   0x3FF
....................    #define LOADER_SIZE   (getenv("PROGRAM_MEMORY") % (getenv("FLASH_ERASE_SIZE")) - 1)
.................... #define LOADER_ADDR LOADER_END-LOADER_SIZE
....................  #ORG LOADER_ADDR+4, LOADER_END auto=0 default
.................... #ifndef BUFFER_LEN_LOD
....................  #define BUFFER_LEN_LOD    64
....................  #define BUFFER_COUNT   2
....................  #define BUFFER_COUNT   1
.................... #if defined(__PCM__) && !getenv("ENH16") && (BUFFER_COUNT == 2)
....................  struct
....................    int8 idx;
....................    char *buffer;
....................  } rBuffer[BUFFER_COUNT];
....................  char Buffer1[BUFFER_LEN_LOD];
....................  char Buffer2[BUFFER_LEN_LOD];
....................    char buffer[BUFFER_LEN_LOD];
.................... #define ACKLOD 0x06
.................... #define XON    0x11
.................... #define XOFF   0x13
.................... unsigned int atoi_b16(char *s);
.................... #ifdef BOOTLOADER_STREAM
....................  #define BootLoaderGetc()     fgetc(BOOTLOADER_STREAM)
....................  #define BootLoaderPutc(c)    fputc(c, BOOTLOADER_STREAM)
....................  #define BootLoaderGetc()     getc()
....................  #define BootLoaderPutc(c)    putc(c)
.................... void real_load_program (void)
0014E:  BCF    49.1
00150:  CLRF   4F
00152:  CLRF   4E
....................    int1  do_ACKLOD, done=FALSE;
....................    int8  checksum, line_type;
....................    int16 l_addr,h_addr=0;
....................    int32 addr;
....................   #if getenv("FLASH_ERASE_SIZE") != getenv("FLASH_WRITE_SIZE")
....................    int32 next_addr;
....................    int8  dataidx, i, count;
....................    int8  data[BUFFER_LEN_LOD / 2];
....................    int8  buffidx;
....................    rBuffer[0].buffer = &Buffer1[0];
....................    rBuffer[1].buffer = &Buffer2[0];
....................    buffidx = 0;
....................    while (!done)  // Loop until the entire program is downloaded
....................       rBuffer[buffidx].idx = 0;     // Read into the buffer until 0x0D ('\r') is received or the buffer is full
....................       do {
....................          rBuffer[buffidx].buffer[rBuffer[buffidx].idx] = BootLoaderGetc();
....................       } while ((rBuffer[buffidx].buffer[rBuffer[buffidx].idx++] != 0x0D) && (rBuffer[buffidx].idx <= BUFFER_LEN_LOD));
....................       if(++buffidx >= BUFFER_COUNT)
00154:  BTFSC  49.1
00156:  BRA    030E
....................       rBuffer[0].idx = 0;
00158:  CLRF   06
....................          rBuffer[0].buffer[rBuffer[0].idx] = BootLoaderGetc();
0015A:  CLRF   03
0015C:  MOVF   06,W
0015E:  ADDLW  07
00160:  MOVWF  FE9
00162:  MOVLW  00
00164:  ADDWFC 03,W
00166:  MOVWF  FEA
00168:  BTFSS  F9E.5
0016A:  BRA    0168
0016C:  MOVFF  FAE,FEF
....................       } while ((rBuffer[0].buffer[rBuffer[0].idx++] != 0x0D) && (rBuffer[0].idx <= BUFFER_LEN_LOD));
00170:  MOVF   06,W
00172:  INCF   06,F
00174:  CLRF   03
00176:  ADDLW  07
00178:  MOVWF  FE9
0017A:  MOVLW  00
0017C:  ADDWFC 03,W
0017E:  MOVWF  FEA
00180:  MOVF   FEF,W
00182:  SUBLW  0D
00184:  BZ    018C
00186:  MOVF   06,W
00188:  SUBLW  40
0018A:  BC    015A
....................          BootLoaderPutc(XOFF);  // Suspend sender
0018C:  MOVLW  13
0018E:  RCALL  007C
....................          do_ACKLOD = TRUE;
00190:  BSF    49.0
....................          if(rBuffer[0].idx != rBuffer[1].idx)
....................             do_ACKLOD = FALSE;
....................          else
....................             for(i=0;i<(rBuffer[0].idx-1);i++)
....................                if(rBuffer[0].buffer[i] != rBuffer[1].buffer[i])
....................                   break;
....................             if(do_ACKLOD)
....................                // Only process data blocks that start with ':'
....................                if (rBuffer[0].buffer[0] == ':')
00192:  MOVF   07,W
00194:  SUBLW  3A
00196:  BTFSS  FD8.2
00198:  BRA    0300
....................                   count = atoi_b16 (&rBuffer[0].buffer[1]);  // Get the number of bytes from the buffer
0019A:  CLRF   x7C
0019C:  MOVLW  08
0019E:  MOVWF  x7B
001A0:  RCALL  0084
001A2:  MOVFF  01,56
....................                   // Get the lower 16 bits of address
....................                   l_addr = make16(atoi_b16(&rBuffer[0].buffer[3]),atoi_b16(&rBuffer[0].buffer[5]));
001A6:  CLRF   x7C
001A8:  MOVLW  0A
001AA:  MOVWF  x7B
001AC:  RCALL  0084
001AE:  MOVFF  01,77
001B2:  CLRF   x7C
001B4:  MOVLW  0C
001B6:  MOVWF  x7B
001B8:  RCALL  0084
001BA:  MOVFF  77,4D
001BE:  MOVFF  01,4C
....................                   line_type = atoi_b16 (&rBuffer[0].buffer[7]);
001C2:  CLRF   x7C
001C4:  MOVLW  0E
001C6:  MOVWF  x7B
001C8:  RCALL  0084
001CA:  MOVFF  01,4B
....................                   addr = make32(h_addr,l_addr);
001CE:  MOVFF  4E,52
001D2:  MOVFF  4F,53
001D6:  MOVFF  4C,50
001DA:  MOVFF  4D,51
....................                  #if defined(__PCM__)  // PIC16 uses word addresses
....................                   addr /= 2;
....................                   checksum = 0;  // Sum the bytes to find the check sum value
001DE:  CLRF   4A
....................                   for (i=1; i<(rBuffer[0].idx-3); i+=2)
001E0:  MOVLW  01
001E2:  MOVWF  55
001E4:  MOVLW  03
001E6:  SUBWF  06,W
001E8:  SUBWF  55,W
001EA:  BC    0214
....................                      checksum += atoi_b16 (&rBuffer[0].buffer[i]);
001EC:  CLRF   03
001EE:  MOVF   55,W
001F0:  ADDLW  07
001F2:  MOVWF  01
001F4:  MOVLW  00
001F6:  ADDWFC 03,F
001F8:  MOVFF  01,77
001FC:  MOVFF  03,78
00200:  MOVFF  03,7C
00204:  MOVFF  01,7B
00208:  RCALL  0084
0020A:  MOVF   01,W
0020C:  ADDWF  4A,F
0020E:  MOVLW  02
00210:  ADDWF  55,F
00212:  BRA    01E4
....................                   checksum = 0xFF - checksum + 1;
00214:  MOVLW  FF
00216:  BSF    FD8.0
00218:  SUBFWB 4A,W
0021A:  ADDLW  01
0021C:  MOVWF  4A
....................                   if (checksum != atoi_b16 (&rBuffer[0].buffer[rBuffer[0].idx-3])) {
0021E:  MOVLW  03
00220:  SUBWF  06,W
00222:  CLRF   03
00224:  ADDLW  07
00226:  MOVWF  01
00228:  MOVLW  00
0022A:  ADDWFC 03,F
0022C:  MOVFF  01,77
00230:  MOVFF  03,78
00234:  MOVFF  03,7C
00238:  MOVFF  01,7B
0023C:  RCALL  0084
0023E:  MOVF   01,W
00240:  SUBWF  4A,W
00242:  BZ    0248
00244:  BCF    49.0
00246:  BRA    0300
....................                      // If the line type is 1, then data is done being sent
....................                      if (line_type == 1)
00248:  DECFSZ 4B,W
0024A:  BRA    0250
....................                         done = TRUE;
0024C:  BSF    49.1
0024E:  BRA    0300
....................                      else if (line_type == 4)
00250:  MOVF   4B,W
00252:  SUBLW  04
00254:  BNZ   0278
....................                         h_addr = make16(atoi_b16(&rBuffer[0].buffer[9]), atoi_b16(&rBuffer[0].buffer[11]));
00256:  CLRF   x7C
00258:  MOVLW  10
0025A:  MOVWF  x7B
0025C:  RCALL  0084
0025E:  MOVFF  01,77
00262:  CLRF   x7C
00264:  MOVLW  12
00266:  MOVWF  x7B
00268:  RCALL  0084
0026A:  MOVFF  01,78
0026E:  MOVFF  77,4F
00272:  MOVFF  01,4E
00276:  BRA    0300
....................                      else if (line_type == 0)
00278:  MOVF   4B,F
0027A:  BNZ   0300
....................                         if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < getenv("PROGRAM_MEMORY"))
0027C:  MOVF   53,F
0027E:  BNZ   028A
00280:  MOVF   52,F
00282:  BNZ   028A
00284:  MOVF   51,W
00286:  SUBLW  04
00288:  BC    0300
0028A:  MOVF   53,F
0028C:  BNZ   0300
0028E:  MOVF   52,W
00290:  SUBLW  01
00292:  BNC   0300
....................                            // Loops through all of the data and stores it in data
....................                            // The last 2 bytes are the check sum, hence buffidx-3
....................                            for (i = 9,dataidx=0; i < rBuffer[0].idx-3; i += 2)
00294:  MOVLW  09
00296:  MOVWF  55
00298:  CLRF   54
0029A:  MOVLW  03
0029C:  SUBWF  06,W
0029E:  SUBWF  55,W
002A0:  BC    02E8
....................                               data[dataidx++]=atoi_b16(&rBuffer[0].buffer[i]);
002A2:  MOVF   54,W
002A4:  INCF   54,F
002A6:  CLRF   03
002A8:  ADDLW  57
002AA:  MOVWF  01
002AC:  MOVLW  00
002AE:  ADDWFC 03,F
002B0:  MOVFF  01,77
002B4:  MOVFF  03,78
002B8:  CLRF   03
002BA:  MOVF   55,W
002BC:  ADDLW  07
002BE:  MOVWF  01
002C0:  MOVLW  00
002C2:  ADDWFC 03,F
002C4:  MOVFF  01,79
002C8:  MOVFF  03,7A
002CC:  MOVFF  03,7C
002D0:  MOVFF  01,7B
002D4:  RCALL  0084
002D6:  MOVFF  78,FEA
002DA:  MOVFF  77,FE9
002DE:  MOVFF  01,FEF
....................                            #if getenv("FLASH_ERASE_SIZE") > getenv("FLASH_WRITE_SIZE")
....................                               if ((addr!=next_addr) && (addr > (next_addr + (getenv("FLASH_ERASE_SIZE") - (next_addr % getenv("FLASH_ERASE_SIZE"))))) && ((addr & (getenv("FLASH_ERASE_SIZE")-1)) != 0))
....................                                  #if defined(__PCH__) && defined(BOOTLOADER_AT_START)
....................                                     #if ((getenv("PROGRAM_MEMORY") % getenv("FLASH_ERASE_SIZE")) != 0)
....................                                        if (addr > (getenv("PROGRAM_MEMORY") - (getenv("PROGRAM_MEMORY") % getenv("FLASH_ERASE_SIZE"))))
....................                                           read_program_memory(getenv("PROGRAM_MEMORY"), rBuffer[0].buffer, getenv("FLASH_ERASE_SIZE") - (getenv("PROGRAM_MEMORY") % getenv("FLASH_ERASE_SIZE")));
....................                                           erase_program_eeprom(addr);
....................                                           write_program_memory(getenv("PROGRAM_MEMORY"), rBuffer[0].buffer, getenv("FLASH_ERASE_SIZE") - (getenv("PROGRAM_MEMORY") % getenv("FLASH_ERASE_SIZE")));
....................                                  next_addr = addr + count/2;
....................                                  next_addr = addr + count;
002E2:  MOVLW  02
002E4:  ADDWF  55,F
002E6:  BRA    029A
....................                                  if (addr == (getenv("PROGRAM_MEMORY") - (getenv("PROGRAM_MEMORY") % getenv("FLASH_ERASE_SIZE"))))
....................                                     write_program_memory(addr, data, count);
002E8:  MOVFF  52,FF8
002EC:  MOVFF  51,FF7
002F0:  MOVFF  50,FF6
002F4:  CLRF   FEA
002F6:  MOVLW  57
002F8:  MOVWF  FE9
002FA:  MOVFF  56,77
002FE:  BRA    010A
....................          if (do_ACKLOD)
00300:  BTFSS  49.0
00302:  BRA    0308
....................             BootLoaderPutc(ACKLOD);
00304:  MOVLW  06
00306:  RCALL  007C
....................          BootLoaderPutc(XON);
00308:  MOVLW  11
0030A:  RCALL  007C
0030C:  BRA    0154
0030E:  MOVLW  06
00310:  RCALL  007C
00312:  MOVLW  11
00314:  RCALL  007C
....................    reset_cpu();
00316:  RESET
00318:  GOTO   031E (RETURN)
.................... unsigned int atoi_b16(char *s) {  // Convert two hex characters to a int8
00084:  CLRF   x7D
....................    unsigned int result = 0;
....................    int i;
....................    for (i=0; i<2; i++,s++)  {
00086:  CLRF   x7E
00088:  MOVF   x7E,W
0008A:  SUBLW  01
0008C:  BNC   00E4
....................       if (*s >= 'A')
0008E:  MOVFF  7C,03
00092:  MOVFF  7B,FE9
00096:  MOVFF  7C,FEA
0009A:  MOVF   FEF,W
0009C:  SUBLW  40
0009E:  BC    00C0
....................          result = 16*result + (*s) - 'A' + 10;
000A0:  MOVF   x7D,W
000A2:  MULLW  10
000A4:  MOVFF  FF3,7F
000A8:  MOVFF  7C,03
000AC:  MOVFF  7B,FE9
000B0:  MOVFF  7C,FEA
000B4:  MOVF   FEF,W
000B6:  ADDWF  x7F,W
000B8:  ADDLW  BF
000BA:  ADDLW  0A
000BC:  MOVWF  x7D
000BE:  BRA    00D8
....................          result = 16*result + (*s) - '0';
000C0:  MOVF   x7D,W
000C2:  MULLW  10
000C4:  MOVFF  FF3,7F
000C8:  MOVFF  7B,FE9
000CC:  MOVFF  7C,FEA
000D0:  MOVF   FEF,W
000D2:  ADDWF  x7F,W
000D4:  ADDLW  D0
000D6:  MOVWF  x7D
000D8:  MOVF   x7E,W
000DA:  INCF   x7E,F
000DC:  INCF   x7B,F
000DE:  BTFSC  FD8.2
000E0:  INCF   x7C,F
000E2:  BRA    0088
....................    return(result);
000E4:  MOVFF  7D,01
000E8:  RETURN 0
....................  #ORG default
....................  #ORG LOADER_ADDR, LOADER_ADDR+3
.................... void load_program(void)
....................    real_load_program();
0031C:  BRA    014E
0031E:  GOTO   0396 (RETURN)
.................... #define PUSH_BUTTON       PIN_E3
.................... #define HEARTBEAT_LED      PIN_C2
.................... #if 0
.................... #warning Loader end: LOADER_END
.................... #warning Loader size: LOADER_SIZE
.................... #warning Loader addr: LOADER_ADDR
.................... #warning Program mem: getenv("PROGRAM_MEMORY")
.................... #warning Flash erase size: getenv("FLASH_ERASE_SIZE")
.................... #warning Flash write size: getenv("FLASH_WRITE_SIZE")
.................... #warning Bits per Instr: getenv("BITS_PER_INSTRUCTION")
.................... #warning Count = (getenv("PROGRAM_MEMORY") % getenv("FLASH_ERASE_SIZE"))
.................... #warning Program memory less than 65536
.................... #INT_GLOBAL
.................... void isr(void){
....................    jump_to_isr(LOADER_END+9);
00008:  GOTO   0508
0000C:  NOP
0000E:  NOP
00010:  NOP
00012:  NOP
00014:  NOP
00016:  NOP
00018:  GOTO   0518
0001C:  RETFIE 0
.................... #org LOADER_END+2, LOADER_END+4
.................... void application(void) {
....................   while(TRUE) {
00500:  BRA    0500
....................       //output_high( HEARTBEAT_LED );
....................       //delay_ms(100);
....................       //output_low( HEARTBEAT_LED );
00502:  RETURN 0
00322:  CLRF   FF8
00324:  BCF    FD0.7
00326:  MOVLW  70
00328:  MOVWF  FD3
0032A:  MOVLW  40
0032C:  MOVWF  F9B
0032E:  CLRF   F64
00330:  BSF    F65.3
00332:  MOVLW  82
00334:  MOVWF  FAF
00336:  MOVLW  06
00338:  MOVWF  FD4
0033A:  MOVLW  A6
0033C:  MOVWF  FAC
0033E:  MOVLW  90
00340:  MOVWF  FAB
00342:  CLRF   48
00344:  CLRF   47
00346:  MOVLW  00
00348:  MOVLB  F
0034A:  MOVWF  x23
0034C:  MOVWF  x24
0034E:  MOVWF  x25
00350:  BCF    FC1.3
00352:  BCF    FC1.4
00354:  BCF    FC1.5
00356:  MOVLB  1
00358:  CLRF   x88
0035A:  MOVLB  F
0035C:  CLRF   x2E
0035E:  CLRF   x2F
00360:  CLRF   x54
....................    setup_oscillator( OSC_16MHZ | OSC_PLL_ON );          // Required when using Internal osc. with 4X PLL enabled.
00362:  MOVLW  70
00364:  MOVWF  FD3
00366:  MOVLW  40
00368:  MOVWF  F9B
0036A:  CLRF   F64
....................    output_low( HEARTBEAT_LED );
0036C:  BCF    F94.2
0036E:  BCF    F8B.2
....................    printf("\r\nSerial Bootloader v1.0\r\n");
00370:  MOVLW  1E
00372:  MOVWF  FF6
00374:  MOVLW  00
00376:  MOVWF  FF7
00378:  MOVLW  00
0037A:  MOVWF  FF8
0037C:  MOVLB  0
0037E:  RCALL  0052
....................    // Enter Bootloader if Pin E3 is low after a RESET
....................    if ( !input(PUSH_BUTTON) )
00380:  BSF    F96.3
00382:  BTFSC  F84.3
00384:  BRA    0396
....................      // Let the user know it is ready to accept a download.
....................     printf("Waiting for download...");
00386:  MOVLW  3A
00388:  MOVWF  FF6
0038A:  MOVLW  00
0038C:  MOVWF  FF7
0038E:  MOVLW  00
00390:  MOVWF  FF8
00392:  RCALL  0052
....................       load_program();
00394:  BRA    031C
....................    application();
00396:  RCALL  0500
00398:  SLEEP
Configuration Fuses:
   Word  1: C815   VREGSLEEP INTRC_HP SOSC_DIG NOXINST INTRC_IO NOPLLEN FCMEN IESO
   Word  2: 2466   PUT BROWNOUT BORV30 ZPBORM NOWDT WDT512
   Word  3: 8901   RTCOSC_T1 CCP2C1 MSSPMSK7 MCLR
   Word  4: 0091   STVREN BBSIZ2K NODEBUG
   Word  5: C0FF   NOPROTECT NOCPB NOCPD
   Word  6: E0FF   NOWRT NOWRTC NOWRTB NOWRTD
   Word  7: 40FF   NOEBTR NOEBTRB
davidd
PostPosted: Fri Jan 29, 2016 10:53 am     Reply with quote
there are interrupt vectors at 508 and 518 -- sorry about that.
I think what you can do is place a goto in the application(), and place a function after the interrupt vectors
like this:
{ goto TEST_LOOP;}
#ORG 0x600
TEST_LOOP:
void blinker(void){
do{
heartbeat_ON;
heartbeat_OFF;
while (button_not_pressed);
cpu_reset();
[/code]
SeeCwriter
PostPosted: Fri Jan 29, 2016 11:54 am     Reply with quote
No, that doesn't work. I get all kinds of compiler errors.
   goto TEST_LOOP;
}   // <-- Error 88: "Undefined label that was used in a GOTO > TEST_LOOP"
#org 0x600
TEST_LOOP:      // <-- Error 43: "Expecting a declaration"
void blink_led()
{                                   // <-- Error 117: "Improper use of a function identifier"
  while( !PROGRAMMING_MODE() ) {
      delay_ms(200);
      delay_ms(200);
   cpu_reset();
I also tried it with TEST_LOOP inside of blink_led(). Same errors.
I wrapped "goto label" in #asm/#endasm and that removed the error in application(), but added the same
error to the #org statement.
I removed the #org 0x600 statement, and got the same errors as with the #org statement.
PostPosted: Fri Jan 29, 2016 12:30 pm     Reply with quote
Read Ttelmah's comment here, about how you should not put any
code in the application() routine in the bootloader code:
http://www.ccsinfo.com/forum/viewtopic.php?t=52561&start=20
I think you should start over. Don't use the IDE's bootloader wizard.
Use Ex_bootloader.c and Ex_bootload.c.
Here I show changes necessary to Ex_bootloader.c and Ex_bootload.c
to make it work with an 18F45K22:
http://www.ccsinfo.com/forum/viewtopic.php?t=44925&start=8
davidd
PostPosted: Fri Jan 29, 2016 3:50 pm     Reply with quote
Does your program run without the bootloader?
Make sure whatever fuses you have set in yourproject.c are either moved to the bootloader or the same in each. With the advice from this forum I put fuses in the bootloader and placed FUSES NONE in the main code.
in regards to application();
maybe try it this way see if it fits.
void application(void) { blink_led(); }
#org 0x600
void blink_led(void)
      delay_ms(200);
      delay_ms(200);
   cpu_reset();
SeeCwriter
PostPosted: Fri Jan 29, 2016 4:22 pm     Reply with quote
It turns out it wasn't the bootloader program that was the problem, it was the terminal program,
just as a previous poster mentioned. Both SIOW and MTTTY do not work for downloading files.
With Tera Term, everything worked, even the original program created by the wizard.
CCS should really remove any mention of SIOW.exe in the bootloader examples, since it doesn't work.
I lost several days rewriting a program that worked from the beginning.
davidd
PostPosted: Fri Jan 29, 2016 4:35 pm     Reply with quote
I am so glad you got it working!
I had the same issue with CCS_Bootloader.exe hanging half way through. but sometimes it would work and everything worked fine.
jeremiah
PostPosted: Sat Jan 30, 2016 8:38 am     Reply with quote
I think one of the major problems here is people don't report this to CCS tech support. I think they make the mistake of thinking this forum is tech support, but it is really just a user forum, so it is hit or miss if the CCS crew actually reads into the details.
I would recommend sending them an email ( support@ccsinfo.com ), link them this thread and the other threads you saw were people were having the same problem. Maybe they can identify and fix the issue.
Page 2 of 3
