bootloader interrupts
Goto page Previous  1, 2
lucasromeiro
PostPosted: Sun Nov 15, 2015 5:31 pm     Reply with quote
Ttelmah wrote:
If you are going to be modifying it, you need to decide _now_ how large your bootloader is likely to be, when you have finished, and allocate enough space for this. Otherwise you are going to have to re-compile all the code you intend to use, when you change the bootloader. It is pointless to be adjusting the size to fit the current bootloader....
got it,
I will do the changes in the bootloader.
after modifying it, we calculate the necessary space the way I wrote above in the example?
Page 2 of 2
