16F1708 HEF usage
Goto page Previous  1, 2, 3  Next
mvanvliet
PostPosted: Wed Jul 15, 2015 6:35 am     Reply with quote
Unfortunately the writing is not working by me. I've changed the initial zeros to 0,1,2,3 and I also read these back with RS232. Not the 5,6,7,8 which must be written to the HEF in the main.
#include <16F1708.H>
#FUSES INTRC_IO,NOWDT
#FUSES NOPUT,NOMCLR,PROTECT,BROWNOUT,BORV25                              //PUT voor 64ms delay bij opstarten en bij brown-out
#FUSES NOCLKOUT,NOIESO
#FUSES NOFCMEN,WRT, NOPPS1WAY
#FUSES NOSTVREN,NODEBUG,NOLVP
#Device ADC=8
#use delay(clock=8000000)                                                      //Fuses and delay are set, so int osc is set at 8Mhz.
#use rs232(baud=9600, xmit = PIN_A0)                                           //UART1 is pin 5 en 6, UART2 is pin 12 en 13
//Register and bit definitions
#byte PMADRH=getenv("SFR:PMADRH")
#byte PMADRL=getenv("SFR:PMADRL")
#byte PMDATH=getenv("SFR:PMDATH")
#byte PMDATL=getenv("SFR:PMDATL")
#bit CFGS=getenv("BIT:CFGS")
#bit WREN=getenv("BIT:WREN")
#bit FREE=getenv("BIT:FREE")
#bit LWLO=getenv("BIT:LWLO")
#BIT WR=getenv("BIT:WR")
#byte PMCON2=getenv("SFR:PMCON2")
#define HEF 0xF80
void my_erase_program_eeprom(int16 address)
  //erases the page at the selected address
  disable_interrupts(GLOBAL);
  CFGS=FALSE;
  PMADRL=make8(address,0);
  PMADRH=make8(address,1);
  CFGS=FALSE;
  FREE=TRUE;
  WREN=TRUE;
  PMCON2=0x55;
  PMCON2=0xAA;
  WR=TRUE;
  delay_cycles(1);
  delay_cycles(1);
  WREN=FALSE;
void my_write_program_memory(int16 address, int16 *data, int8 ctr)
  //Beware - this does not erase a page for you, and will not handle
  //a write that goes beyond the end of a page. Only works to
  //write ctr bytes, to the program memory starting at address
  int8 count;
  WREN=TRUE;
  CFGS=FALSE;
  LWLO=TRUE; //load latches only
  for (count=0;count<((ctr/2)-1);count++)
    PMDATL=make8(data[count],0);
    PMDATH=make8(data[count],1);
    PMCON2=0x55;
    PMCON2=0xAA;
    WR=TRUE;
    delay_cycles(1);
    delay_cycles(1);
    PMADRL++;
  LWLO=FALSE;
  PMDATH=make8(data[count],1);  //last word
  PMCON2=0x55;
  PMCON2=0xAA;
  WR=TRUE;
  delay_cycles(1);
  delay_cycles(1);
  WREN=FALSE;
//memory layout definitions
struct twobytes
     int8 l;
     int8 h;
union prog_mem
     int16 word;
     struct twobytes b;
#ROM int16 HEF={0,1,2,3} //ensures the compiler will not accidentally
//put something else here.
//output_high  (PF_OK_OUT);                                                       // PF hoog maken zodat bij reset geen pf gegeven wordt.
setup_oscillator(OSC_8MHZ);
setup_dac(DAC_OFF);
setup_vref(VREF_OFF);
setup_adc_ports(sAN2|sAN4|sAN6|sAN9|sAN10|sAN11|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_8);                                                     // Built-in A/D setup function TAD is 2µSec
//setup_ccp1(CCP_PWM);                                                            // Configure CCP1 as a PWM
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);                                      // 32,8 ms tot overflow (0.125us*4*256*256)
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8|T1_GATE);                                 // 4us per ophoging van timer1
setup_timer_2(T2_DIV_BY_1, 255, 1);                                             // Setup for 8 bit at 4kHz
setup_timer_6(T6_disabled,250,1);
//enable_interrupts(GLOBAL);
//enable_interrupts(INT_TIMER4);
                                                          // voor bewaren standby status, opstarten
                     struct
                         union prog_mem I_cal;
                         union prog_mem I_0A;
                         union prog_mem I_16A;
                         union prog_mem komma_8;
                     } values;
                     values.I_cal.b.l = 5;
                     values.I_0A.b.l = 6;
                     values.I_16A.b.l = 7;
                     values.komma_8.b.l = 8; //so they are different
                     //erase the page
                     my_erase_program_eeprom(HEF);
                     //write the values
                     my_write_program_memory(HEF, &values, 8);
                     //and read them back - CCS read works fine
                     read_program_memory(HEF,&values,8);
                           printf("%u ",values.I_0A.b.l);
                     printf("%u ",values.I_cal.b.l);
                     printf("%u ",values.I_16A.b.l);
                     printf("%u ",values.komma_8.b.l);
      delay_cycles(1);
Do you have any idea? Rolling Eyes
mvanvliet
PostPosted: Tue Jul 28, 2015 3:04 am     Reply with quote
Today I'm looking again at the HEF program to make it work. I've discovered that the erase function Ttelmah made is not working for me, but it is like the datasheet tells us so I don't know why it isn't working.
#Device ADC=8
#define HEF 0xF80
int i = 0;
  CFGS=FALSE;
  CFGS=FALSE;
  FREE=TRUE;
  WREN=TRUE;
  PMCON2=0x55;
  PMCON2=0xAA;
  WR=TRUE;
  delay_cycles(1);
  delay_cycles(1);
  WREN=FALSE;
  int8 count;
  WREN=TRUE;
  CFGS=FALSE;
    PMCON2=0x55;
    PMCON2=0xAA;
    WR=TRUE;
    delay_cycles(1);
    delay_cycles(1);
    PMADRL++;
  LWLO=FALSE;
  PMCON2=0x55;
  PMCON2=0xAA;
  WR=TRUE;
  delay_cycles(1);
  delay_cycles(1);
  WREN=FALSE;
struct twobytes
     int8 l;
     int8 h;
union prog_mem
     int16 word;
     struct twobytes b;
#ROM int16 HEF={10,11,12,13} //ensures the compiler will not accidentally
setup_dac(DAC_OFF);
                     struct
                     } values;
                     //erase the page
                     //my_erase_program_eeprom(HEF);
                     //write the values
                     //my_write_program_memory(HEF, &values, 8);
                     printf("\n");
                     i++;
                     if(i >= 10)
                     if(i >= 20)
                     delay_cycles(1);
Maybe another bug in version 5.026 so the code of Ttelmah isn't working for me (and probably is working for him)??
PostPosted: Tue Jul 28, 2015 3:34 am     Reply with quote
You've probably killed the memory.
Seriously as soon as you put the erase function into a loop, this becomes likely.
The erase is going to be called every time i>=10.
The printf's take about 17mSec the erase 2mSec, the write 2mSec, so the total loop, about 20mSec. That will destroy the memory in about 1000 seconds, and that assumes the memory is new. Given yours has probably been used a large number of times already, much earlier death is likely.
'High endurance' is relative to the flash memory. It does not mean it can be written at all often. A simple loop erase, without the prints, can kill the memory in about 3 minutes.....
mvanvliet
PostPosted: Tue Jul 28, 2015 5:02 am     Reply with quote
I still read the 10, 11 ,12 and 13 from the HEF.
The complete program also stops when I>20, because of the while(1).
PostPosted: Tue Jul 28, 2015 5:08 am     Reply with quote
OK.
At least you now tell us what you are seeing. It's still potentially using up life cycles, like they are out of date though...
The most likely thing is that one of the register or bit addresses is wrong in the compiler's database. Enter them manually from the data sheet.
mvanvliet
PostPosted: Tue Jul 28, 2015 6:03 am     Reply with quote
I also tried to manually enter them, but that's also not working. Very strange.
//#byte PMADRH=getenv("SFR:PMADRH")
//#byte PMADRL=getenv("SFR:PMADRL")
#byte PMADRH=192
#byte PMADRL=191
//#byte PMDATH=getenv("SFR:PMDATH")
#byte PMDATH=194
//#byte PMDATL=getenv("SFR:PMDATL")
#byte PMDATL=193
//#bit CFGS=getenv("BIT:CFGS")
#bit CFGS=195.6
//#bit WREN=getenv("BIT:WREN")
#bit WREN=195.2
//#bit FREE=getenv("BIT:FREE")
#bit FREE=195.4
//#bit LWLO=getenv("BIT:LWLO")
#bit LWLO=195.5
//#BIT WR=getenv("BIT:WR")
#BIT WR=195.1
//#byte PMCON2=getenv("SFR:PMCON2")
#byte PMCON2=196
I also can try to add the ASM code from the datasheet in my program, maybe that will work. I will try something...
PostPosted: Tue Jul 28, 2015 7:14 am     Reply with quote
Seriously. I have just loaded 5.026 from a backup. Compiled my code as posted, with just fuses/clock/RS232 added.
Loaded the values with:
#ROM int16 0xF80 = {0,0,0,0}
Then ran this:
   values.I_cal.b.l = 100;
   values.I_0A.b.l = 101;
   values.I_16A.b.l = 102;
   values.komma_B.b.l = 103; //so they are different
   my_erase_program_eeprom(0xF80);
   my_write_program_memory(0x0F80, &values, 8);
   read_program_memory(0x0F80,&values,8);
   printf("%u ",values.komma_B.b.l);
   //Now clear again
   printf("%u \n",values.komma_B.b.l);
   //and read.
and it merrily displays:
101 100 102 103 255 255 255 255
Exactly as it should (erased cell is all 1's).
The code as posted works with your compiler.
Are you sure your PSU is good/stable?. Quite a few of the close chip relatives of this one, will not erase below a voltage quite a bit above the figure in the data sheet, if there is even a little noise on the supply line. There is a pulse in current during the erase (about 5mA), and unless regulation is very good, this can result in it failing.
mvanvliet
PostPosted: Wed Jul 29, 2015 1:26 am     Reply with quote
Hmmm...very strange. If I compile this code with my fuses:
#FUSES NOPUT,NOMCLR,NOPROTECT,BROWNOUT,BORV25                              //PUT voor 64ms delay bij opstarten en bij brown-out
#Device ADC=8
#define HEF 0xF80
  CFGS=FALSE;
  CFGS=FALSE;
  FREE=TRUE;
  WREN=TRUE;
  PMCON2=0x55;
  PMCON2=0xAA;
  WR=TRUE;
  delay_cycles(1);
  delay_cycles(1);
  WREN=FALSE;
  int8 count;
  WREN=TRUE;
  CFGS=FALSE;
    PMCON2=0x55;
    PMCON2=0xAA;
    WR=TRUE;
    delay_cycles(1);
    delay_cycles(1);
    PMADRL++;
  LWLO=FALSE;
  PMCON2=0x55;
  PMCON2=0xAA;
  WR=TRUE;
  delay_cycles(1);
  delay_cycles(1);
  WREN=FALSE;
struct twobytes
     int8 l;
     int8 h;
union prog_mem
     int16 word;
     struct twobytes b;
    struct
          union prog_mem komma_B;
      } values;
   //Now clear again
   //and read.
I receive 0,0,0,0,0,0,0,0 in my RS232 hyperterminal like program.
So the write function is also not working. Is it possible that my fuses cause this problem, I already changed the PROTECT fuse to NOPROTECT but I also saw in the datasheet that this fuse should not affect the HEF.
PostPosted: Wed Jul 29, 2015 2:32 am     Reply with quote
What is your supply voltage, and the nature of your supply?. What smoothing is right by the chip?.
mvanvliet
PostPosted: Wed Jul 29, 2015 3:09 am     Reply with quote
5V is coming from a stabilized power supply (a standard 30V/30V/5V), at the micro there is a 100nF capacitor nearby and a 470uF elco within a few centimeters/inches.
PostPosted: Wed Jul 29, 2015 3:49 am     Reply with quote
WRT
Program memory write protected......
I was worried about voltage, since you have Brownout set at 2.5v, which suggests you are working down near this sort of voltage.
mvanvliet
PostPosted: Wed Jul 29, 2015 4:44 am     Reply with quote
Yes that was the solution:
Thank you for your effort.
mvanvliet
PostPosted: Mon Aug 31, 2015 3:49 am     Reply with quote
Now I'm trying to do more with the HEF there are two questions rised from the program Ttelmah wrote.
wherefore is the .b.l behind the variables? (L from lower byte from struct "twobytes"??)
I've added a 4th variable to the HEF but that's not working, are there 2 bytes reserved per variable so this function is too small:
If that's the case I need to write 10 instead of the 8 which is declared now. Is that correct?
PostPosted: Mon Aug 31, 2015 8:18 am     Reply with quote
Get a C textbook.....
This will tell you how structures and unions work.
The point is that the actual program memory, is 14bits wide, addressed as if it was 16bits wide (you write two bytes for every word in the memory), but only the low 8bits of each HEF location is 'high endurance'. So the data has to be written to the low eight bits of each 14 bits. The data layout allows you to address the low byte of each 14bit instruction.
Yes you have to expand your write for however many variables you have. Presumably you mean a 5th variable, since it already writes 4...
mvanvliet
PostPosted: Mon Aug 31, 2015 8:46 am     Reply with quote
Thank you for your reply. I indeed added a 5th variable.
Page 2 of 3
