ADC test code
Goto page Previous  1, 2
irmanao
PostPosted: Sat Jul 11, 2015 5:21 am     Reply with quote
Ok i should have done this.. what i found is:
#byte PORTD=0x0E32
#byte PORTE=0x0E42
I've never used fuses. Are they needed in this program?
_thanks_
PostPosted: Sat Jul 11, 2015 6:45 am     Reply with quote
fuses are REQUIRED for every program.
they 'configure' the PIC.
Have a look at any of the example programs that CCS supplies.
Now fuses are specific to the series of PIC you're using, based upon the features of the PIC.
I do not use the 33 series PICs so perhaps another programmer will show you a 'typical' set of fuses that will work for you.
Jay
irmanao
PostPosted: Sat Jul 11, 2015 4:22 pm     Reply with quote
That's how i connect the voltage..
http://postimg.org/image/f1rbzwibb/
For the fuses what i found in here is:
#fuses FRC_PLL,NOWDT,NOPROTECT
#use delay(internal=117920000)
PostPosted: Sat Jul 11, 2015 5:29 pm     Reply with quote
OK maybe go back to the beginning....
program the PIC to flash an LED at a 1Hz rate. Show us the entire program as it's less than 30 lines of code and tell us if the LED actually does flash at a 1Hz rate.
As I said I don't use the 33 series but 117MHz for the clock seems pretty darn fast to me !!
By doing the '1Hz LED' program you will confirm the PIC,PCB, and coding is working and then we have a firm place to help you from
Jay
irmanao
PostPosted: Mon Jul 13, 2015 9:07 am     Reply with quote
Ok this is embarrassing, it turns out i didn't connect the voltage correctly as i got confused with the connector's pin layout.
_thank you all for helping and sorry for wasting your time_
PostPosted: Mon Jul 13, 2015 9:14 am     Reply with quote
Crying or Very sad
As a comment, why are the PORT definitions there?.
They won't work, since on this chip the ports are _words_ not bytes. Then they are basically pointless look at the CCS output_d, and output_e functions (and their input equivalents.
Page 2 of 2
