16F1708 HEF usage
Goto page 1, 2, 3  Next
mvanvliet
16F1708 HEF usage
PostPosted: Wed Jun 10, 2015 7:32 am     Reply with quote
I've some questions about the HEF of a 16F1708:
Where can I find the start address of the HEF?
edit: I think I found it in the datasheet 0F80h - 0FFFh
Do I have to use the write_program_memory or can I also use the write_eeprom_memory function?
CCS: 5.026
PostPosted: Wed Jun 10, 2015 8:16 am     Reply with quote
You have to use write_program_memory, and (key thing) have to remember that everything on the program memory is done in pages. To change a single byte, you have to read the entire page, change just the byte you want, and write the whole page back. 32 instruction words (64 bytes) needing to be stored...
A search here will find some threads about this.
The data sheet couldn't be much clearer on where it is. Look at table 3-1.
However there is then another caveat.
The memory on these is 14bits wide. The HEF, is only the low 8bits of each instruction word. So 32 bytes out of each 64 written.
mvanvliet
PostPosted: Fri Jun 12, 2015 8:40 am     Reply with quote
How do I have to write 47 decimal to the first address of the HEF?
I've tried this:
write_program_memory(0x0F80, 47, 2);
But that's not the way to use this function...can anyone help me?
PostPosted: Fri Jun 12, 2015 9:15 am     Reply with quote
    int16 val=47;
    write_program_memory(0x0F80, &val, 2);
The second value needs to be a _pointer_ to the RAM containing the value to be written.
mvanvliet
PostPosted: Fri Jun 19, 2015 4:21 am     Reply with quote
How many bytes is one page for the 16F1708? 64?
If I have 4 bytes to change, is it correct that I've one read_program_memory function and I put the results in a string, change the bytes I want and do one write_program_memory?
PostPosted: Fri Jun 19, 2015 2:04 pm     Reply with quote
Not a string, no.
A 'string', is an array of characters terminated by a '\0'.
You need to use 4 * int16 values, and remember that each (for this), can only hold numbers up to 16383.
    int16 configs[4]={1,2,3,4};
    write_program_memory(0x0F80, configs, 8);
Remember in C, the name of an array, is the pointer to it, so the '&' is not needed here.
mvanvliet
PostPosted: Mon Jul 13, 2015 7:38 am     Reply with quote
The limit of 16383 is not a problem because I want to save 8 bit integers.
I've tried something with the code you suggested, but it isn't working as I have written it.
                  int16 configs[4]={150,17,230,104};
                  int I_cal = 100;
                  int I_0A = 100;
                  int I_16A = 100;
                  int komma_8 = 100;
                  configs[0] = I_cal;
                  configs[1] = I_0A;
                  configs[2] = I_16A;
                  configs[3] = komma_8;
In this case I see 2x 255, 1x 150 and 1x 0. Is it not possible to do it like I did?
PostPosted: Mon Jul 13, 2015 8:56 am     Reply with quote
1) How are you testing this?.
2) You need to protect the area, or the compiler may put things there - particularly constants.
3) Compiler version?. Still 5.026?.
There is a fault in some compiler versions with the automatic erase code not working. If this is the case for yours, you need to do this yourself (I haven't checked if .026 needs this):
#byte PMADRH=getenv("SFR:PMADRH")
#byte PMADRL=getenv("SFR:PMADRL")
#bit CFGS=getenv("BIT:CFGS")
#bit WREN=getenv("BIT:WREN")
#bit FREE=getenv("BIT:FREE")
#BIT WR=getenv("BIT:WR")
#byte PMCON2=getenv("SFR:PMCON2")
void erase_program_eeprom(int16 address)
  disable_interrupts(GLOBAL);
  PMADRL=make8(address,0);
  PMADRH=make8(address,1);
  CFGS=FALSE;
  FREE=TRUE;
  WREN=TRUE;
  PMCON2=0x55;
  PMCON2=0xAA;
  WR=TRUE;
  delay_cycles(1);
  delay_cycles(1);
mvanvliet
PostPosted: Tue Jul 14, 2015 12:44 am     Reply with quote
For testing I've this code which I send to the computer with RS232.
read_program_memory(0x0F80, configs, 8);
I_cal    = configs[0];
I_0A     = configs[1];
I_16A    = configs[2];
komma_8  = configs[3];
printf("%u",I_0A);                      putc(' ');
printf("%u",I_cal);                     putc(' ');
printf("%u",I_16A);                     putc(' ');
printf("%u",komma_8);                   putc(' ');
The compiler version is still 5.026.
I'm going to look at the ASM to check of the automatic erase is working (if I can recognize this with my very little knowlegde about ASM).
edit: this is the ASM code of the write_program_memory function (I think the original erase should be inside this function if 5.026 doesn't have this bug?).
....................                   write_program_memory(0x0F80, configs, 8);
01B2:  MOVLW  0F
01B3:  MOVLB  03
01B4:  MOVWF  12
01B5:  MOVLW  80
01B6:  MOVWF  11
01B7:  MOVLW  20
01B8:  MOVWF  05
01B9:  MOVLW  36
01BA:  MOVWF  04
01BB:  MOVLW  08
01BC:  MOVLB  00
01BD:  MOVWF  5C
Or do I always have to perform an erase_program_memory/eeprom before a write_program_memory function?
PostPosted: Tue Jul 14, 2015 2:36 am     Reply with quote
That is not the write_program_memory function.
That is just the 'setup' to load the registers required before calling the function....
mvanvliet
PostPosted: Tue Jul 14, 2015 3:16 am     Reply with quote
That's all the ASM which is under the write_program_memory function.
This is the read_program_memory:
.................... read_program_memory(0x0F80, configs, 8);
047D:  MOVLW  0F
047E:  MOVLB  03
047F:  MOVWF  12
0480:  MOVLW  80
0481:  MOVWF  11
0482:  MOVLW  20
0483:  MOVWF  05
0484:  MOVLW  36
0485:  MOVWF  04
0486:  MOVLW  08
0487:  MOVLB  00
0488:  MOVWF  5C
0489:  GOTO   05A
....................                   I_cal = 100;
01A5:  MOVLW  64
01A6:  MOVWF  2E
....................                   I_0A = 100;
01A7:  MOVWF  2F
....................                   I_16A = 100;
01A8:  MOVWF  30
....................                   komma_8 = 100;
01A9:  MOVWF  45
....................                   configs[0] = I_cal;
01AA:  MOVF   2E,W
01AB:  MOVWF  56
....................                   configs[1] = I_0A;
01AC:  MOVF   2F,W
01AD:  MOVWF  57
....................                   configs[2] = I_16A;
01AE:  MOVF   30,W
01AF:  MOVWF  58
....................                   configs[3] = komma_8;
01B0:  MOVF   45,W
01B1:  MOVWF  59
Where can I find the code to see of the erase function bug is in this version of the compiler?
PostPosted: Tue Jul 14, 2015 7:29 am     Reply with quote
Again, no it isn't.....
The read_program_memory function is at 0x5A. It again loads the registers _first_ then goes to the function.
mvanvliet
PostPosted: Tue Jul 14, 2015 7:40 am     Reply with quote
Aah I get it...I've missed the GOTO.
This is at 5A:
005A:  MOVF   5C,W
005B:  MOVWF  77
005C:  BCF    03.0
005D:  INCF   77,F
005E:  RRF    77,F
005F:  MOVLB  03
0060:  BSF    15.0
0061:  NOP
0062:  NOP
0063:  MOVF   13,W
0064:  MOVWF  00
0065:  INCF   04,F
0066:  MOVF   14,W
0067:  MOVWF  00
0068:  INCF   04,F
0069:  INCF   11,F
006A:  BTFSC  03.2
006B:  INCF   12,F
006C:  DECFSZ 77,F
006D:  GOTO   060
006E:  MOVLP  00
006F:  MOVLB  00
0070:  GOTO   48A (RETURN)
PostPosted: Tue Jul 14, 2015 8:24 am     Reply with quote
OK. Have looked in my archives, and have 5.025. Confirm this does not erase the page, or write correctly. Very likely that 5.026 won't either.
So have written (slightly cruder than the CCS version) replacement functions.
Also note I don't copy the variables around but leave them in the memory block that can be directly written/read.
Have included basically your test code, but modified the values so one can see they are different.
Also note you swap the order of the first and second values in the print.
//Suitable header here
//Register and bit definitions
#byte PMDATH=getenv("SFR:PMDATH")
#byte PMDATL=getenv("SFR:PMDATL")
#bit LWLO=getenv("BIT:LWLO")
#define HEF 0xF80
void my_erase_program_eeprom(int16 address)
  //erases the page at the selected address
  CFGS=FALSE;
  CFGS=FALSE;
  FREE=TRUE;
  WREN=TRUE;
  PMCON2=0x55;
  PMCON2=0xAA;
  WR=TRUE;
  delay_cycles(1);
  delay_cycles(1);
  WREN=FALSE;
void my_write_program_memory(int16 address, int16 *data, int8 ctr)
  //Beware - this does not erase a page for you, and will not handle
  //a write that goes beyond the end of a page. Only works to
  //write ctr bytes, to the program memory starting at address
  int8 count;
  WREN=TRUE;
  CFGS=FALSE;
  LWLO=TRUE; //load latches only
  for (count=0;count<((ctr/2)-1);count++)
    PMDATL=make8(data[count],0);
    PMDATH=make8(data[count],1);
    PMCON2=0x55;
    PMCON2=0xAA;
    WR=TRUE;
    delay_cycles(1);
    delay_cycles(1);
    PMADRL++;
  LWLO=FALSE;
  PMDATH=make8(data[count],1);  //last word
  PMCON2=0x55;
  PMCON2=0xAA;
  WR=TRUE;
  delay_cycles(1);
  delay_cycles(1);
  WREN=FALSE;
//memory layout definitions
struct twobytes
     int8 l;
     int8 h;
union prog_mem
     int16 word;
     struct twobytes b;
#ROM int16 HEF={0,0,0,0} //ensures the compiler will not accidentally
//put something else here.
void main(void) //crude demo program
   struct
       union prog_mem I_cal;
       union prog_mem I_0A;
       union prog_mem I_16A;
       union prog_mem komma_B;
   } values;
   values.I_cal.b.l = 100;
   values.I_0A.b.l = 101;
   values.I_16A.b.l = 102;
   values.komma_B.b.l = 103; //so they are different
   //erase the page
   my_erase_program_eeprom(HEF);
   //write the values
   my_write_program_memory(HEF, &values, 8);
   //and read them back - CCS read works fine
   read_program_memory(HEF,&values,8);
   printf("%u ",values.I_0A.b.l);
   printf("%u ",values.I_cal.b.l);
   printf("%u ",values.I_16A.b.l);
   printf("%u ",values.komma_B.b.l);
      delay_cycles(1);
mvanvliet
PostPosted: Tue Jul 14, 2015 9:01 am     Reply with quote
Thank you for your effort. I will check your program and will let you know tomorrow of it works.
It will also be time to get an new 1 year maintenance...this kind of bugs aren't nice to have.
Page 1 of 3
