Assembler, goto instruction
slavka012
PostPosted: Tue Apr 28, 2015 4:56 pm     Reply with quote
with microchip assembler I can use the following construction:
Goto $+1
where $ denotes current PC. Is there equivalent syntax for use with inline assembler with CCS ?
PostPosted: Tue Apr 28, 2015 5:25 pm     Reply with quote
WHY ??
edit: duh - i forgot GOTO is a 2 cycle instruct ;-((
thiS IS Basically 2 NOP
or in ccs
delay_cycles(2);
slavka012
PostPosted: Tue Apr 28, 2015 5:34 pm     Reply with quote
ok I already found a solution - bra 0. Hm no, compiler does not take that
Yes it is basically a nop, but one that takes two cycles to execute.
I can't call delay_cycles from inside the #asm block. Why I want goto $+1 instead of 2 nop's, well, no huge reason other than code being a little more compact.
PostPosted: Tue Apr 28, 2015 11:40 pm     Reply with quote
Just use delay_cycles. Cheat:
#DEFINE NOP2 #endasm delay_cycles(2); #asm
Then just use the instruction 'NOP2' in the assembler when you want a two cycle delay.
