Hardware uart parity
Goto page Previous  1, 2, 3
PostPosted: Sun Mar 01, 2015 4:42 am     Reply with quote
I must admit, I was surprised your version wasn't doing parity, since it was a very long time ago, when this didn't work.
I must admit when I last used it, it did seem to be right, testing with a serial monitor.
Have just tried the code, on three compiler versions, and the parity is correct. 4.141, 5.020, 5.030.
If you send 0, which with odd parity should result in bit9, being set, it does set this bit. Send 1, and it clears bit9.
The assembler is identical to what you post.....
Stick a serial monitor on the line and see what is happening.
fobi
PostPosted: Sun Mar 01, 2015 7:48 am     Reply with quote
Absolutely my fault. I am sorry to all.
http://postimg.org/image/nui3kdkft/
I was too lazy to check with hardware.
http://postimg.org/image/jl7q3bxnx/
In that line of thoughts, i suggest all to read this
http://www.ccsinfo.com/forum/viewtopic.php?t=47549
This could save you time and will make our friends less irritated.
CCS is good compiler.
fobi
Page 3 of 3
