PWM Problem
Goto page Previous  1, 2
mazedm80
PostPosted: Fri Feb 20, 2015 1:13 am     Reply with quote
thank u Ttelmah
i u got the problem...
i always use the int16 and it divide by 4 and if it is float the motor didn't run...
PostPosted: Fri Feb 20, 2015 1:19 am     Reply with quote
Glad you got there.
You can always 'force' the function to use whichever version you actually want, by using a 'cast'. So:
float fred;
    fred=1000.0;
    set_pwm1_duty((int8)(fred/4));
Will force the 'int8 ' version of the function to be used, even though you are handing the function a 'float' (which will always default to using the int16 version - code always uses the _highest_ type from those available if a type doesn't actually fit the choices).
Smile
Page 2 of 2
