String/array crossing page/segment border
Goto page Previous  1, 2
rolox
PostPosted: Fri Jan 09, 2015 2:58 am     Reply with quote
did a small test program
in compiler Rev 5.036, the two testpointer 1+2 have the highbyte zero,
but should be 0x3F. LowByte i correct - verified with program memory
The testpointer3 to a int32 in rom is ok.
Direct access on the Data via Index is ok too - but i need pointer to switch Data
This worked in 5.012 - maybe the declaration of ROM data must be changed ?
#include <16f1788.h>
#device *=16
#device ICD=TRUE
#DEVICE PASS_STRINGS=IN_RAM
#fuses NOWDT,NOPROTECT,NOLVP, NOPUT
#use delay(internal=16000000)
int32 rom myConst =123456;
char rom Data1[] = {7,8, 9,10, 11,};
char rom Data2[5] ={20,21,22,23,24,};
   int8 dummy=0;
   rom char *testpointer1 =&Data1[0];
   rom char *testpointer2 =&Data2[0];
    rom int32 *testpointer3 =&myConst;
   char d0 = Data1[0];
   char d1 = Data1[1];
   char d2 = Data1[2];
   char d3 = Data1[3];
   char e0 = Data2[0];
   char e1 = Data2[1];
   char e2 = Data2[2];
   char e3 = Data2[3];
   //dummy to set a breakpoint
   dummy=1;
   char c0 = &testpointer1++;
   char c1 = &testpointer1++;
   char c2 = &testpointer1++;
   char c3 = &testpointer1++;
   dummy=2;
rolox
PostPosted: Thu Jan 15, 2015 5:15 am     Reply with quote
solved : ROM Pointer in 5.036 wrong
I posted the problem to CCS support - the said it will be fixed in the next revision
Page 2 of 2
