tesla80
Posted: Wed Dec 10, 2014 1:22 am |
Hi guys.
I use this chip for the 3 independent PWM outputs only. Also price..
I have a PCB and working application with this PIC, so I need to add the byte array feature on this PCB.. I don't have where to run, I'll make it real somehow.
Ttelmah, if you answer my questions in the previous post, it will be much appreciated. I'm going to try that..
EEPROM is a need for this chip... Anyway. |
Posted: Wed Dec 10, 2014 9:44 am |
No guarantees on this. Haven't a PIC of this type to try.
However 'comments'. Found that the CCS write function would erase the whole 32word page, not 16words in MPLAB. Not sure if this is a fault with the emulation of the code, so rewrote this. Remember interrupts should be disabled before calling:
//for a const int8 array declared as:
const int8 array[100][3] = {
{1,2,3},{1,2,3},{1,2,3},{1,2,3},{1,2,3},{1,2,3},{1,2,3},{1,2,3},.... //etc.
#define ROW_LEN 3
#WORD PMADDR=getenv("SFR:PMADRL")
#bit CFGS=getenv("BIT:CFGS")
#bit FREE=getenv("BIT:FREE")
#bit WREN=getenv("BIT:WREN")
#bit WR=getenv("BIT:WR")
#bit LWLO=getenv("BIT:LWLO")
#byte PMCON2=getenv("SFR:PMCON2")
#word PMDAT=getenv("SFR:PMDATL")
#inline
void unlock()
PMCON2=0x55;
PMCON2=0xAA;
WR=TRUE;
delay_cycles(1);
delay_cycles(1);
#inline
void erase(int16 address)
//directly from the data sheet
PMADDR=address;
CFGS=FALSE;
FREE=WREN=TRUE;
unlock();
void write_page(int16 address, int16 * data, int8 ctr)
ctr/=2; //writing in words
--ctr;
WREN=TRUE;
CFGS=FALSE;
LWLO=TRUE;
PMADDR=address;
do
PMDAT=*data;
unlock();
PMADDR++;
data++;
} while (--ctr);
LWLO=FALSE;
PMDAT=*data;
unlock();
void write_byte(int8 x,int8 y,int8 val)
//routine to change a byte in 'array' at x,y with rows 'row_len' long
int16 address;
int8 word_address;
int16 temp_buff[16];
address=label_address(array); //address of the array start
//Now calculate the offset
address=address+((int16)ROW_LEN*x)+y;
word_address=(address&0xF);
address&=0xFFF0;
//Now we have the page address and instruction in the page
read_program_memory(address,&temp_buff,32); //read page
//0x34xx is the code for a RETLW instruction
temp_buff[word_address]=(int16)val + 0x3400; //change the byte
//write the page back and erase.
erase(address);
write_page(address,&temp_buff,32);
//So to change byte [80][0] to 43, use:
write_byte(80,0,43);
tesla80
Posted: Thu Dec 11, 2014 3:40 am |
Hi Ttelmah,
I'm going to try your code.
Just a question; do you mean +9 with label_address(array); ?
So I'll locate the array using #org to 0x500 and label_address will give 0x509, correct?
BR |
Posted: Thu Dec 11, 2014 4:20 am |
There is no point in locating it anywhere. Doing so, will reduce your space available, since then things can't be moved.
As I said already:
Declare the variable as:
const int8 array[100][3] = {.........};
Then "label_address(array)" will be the address in ROM where the first instruction of the table is stored."
The 'label_address' function, automatically tells you where the actual data is stored. |
tesla80
Posted: Thu Dec 11, 2014 2:04 pm |
I've tried it as below, but the mcu freezes after write.
| Code: | disable_interrupts(GLOBAL);
write_byte(0,0,50);
write_byte(0,1,100);
write_byte(0,2,150);
enable_interrupts(GLOBAL); |
Posted: Fri Dec 12, 2014 2:20 am |
So run it up in an ICD, or simulator and work out what is hanging. This is called debugging.
As I said 'no guarantees'. It is based directly on what the data sheet says. |
