lcd with 16f676
Goto page Previous  1, 2
PostPosted: Thu Nov 27, 2014 4:34 pm     Reply with quote
Glad to hear it... You are welcome.
sahu77
PostPosted: Fri Nov 28, 2014 1:11 pm     Reply with quote
now i want to display adc value on lcd. those code as
    set_adc_channel(1);
            delay_us(10);            //-------->NOTE:AQUISITION TIME NECCESARY
            battvolt=read_adc();         //reading current
            delay_us(10);
         battvolt=   (float)(battvolt * 5)/1023.0;
 lcd_gotoxy(1,1);
 printf ( LCD_PutC,"Battery:\f%3.2f", battvolt);
       lcd_gotoxy(12,1);
       printf(LCD_PutC," VOLT \n");
found error as
Printf format type is invalid
sahu
PostPosted: Fri Nov 28, 2014 2:57 pm     Reply with quote
Battvolt is declared as something other than a float.
sahu77
PostPosted: Fri Nov 28, 2014 3:45 pm     Reply with quote
%3.2f is show only float only?
sahu
PostPosted: Sat Nov 29, 2014 1:27 am     Reply with quote
Yes.
This is standard C. Look in the manual for printf.
sahu77
PostPosted: Sat Nov 29, 2014 6:51 am     Reply with quote
battvolt is declared as int32 battvolt . so how can printf it ?
sahu
sahu77
PostPosted: Sat Nov 29, 2014 7:05 am     Reply with quote
Ttelmah wrote:
Yes.
sahu
PostPosted: Sat Nov 29, 2014 9:02 am     Reply with quote
%Ld
However it won't have any decimals since it is an integer number.
Use:
         battvolt=   (battvolt * 500)/1024;
         lcd_gotoxy(1,1);
         printf ( LCD_PutC,"Battery:\f%5.2LW", battvolt);
This prints an integer, as a scaled value (/100 here). So the integer is made 100* larger in the earlier calculation.
Read the threads for why the correct divisor is 1024, _not_ 1023.
sahu77
PostPosted: Sat Nov 29, 2014 9:09 am     Reply with quote
Ttelmah wrote:
%Ld
Use:
         lcd_gotoxy(1,1);
can u explain me 5.2 LW ?
sahu
PostPosted: Sat Nov 29, 2014 9:18 am     Reply with quote
Read the manual....
It is a printf specifier to print an integer as a 'scaled' value.
The .2, specifies how far it is to be scaled.
So the integer '100', printed with 5.2w, prints as '1.00'. Scaled by two places.
The 'L' says that the number is a _long_ integer (bigger than int8).
Page 2 of 2
