48 pwm channels
Goto page Previous  1, 2
n-squared
PostPosted: Thu Feb 07, 2008 2:54 pm     Reply with quote
You forgot to disable HTML, so the code didn't post correctly.
Thanks for the tip, PCM programmer.
I will make sure to log in before answering next time.
Best regards
Noam
ELCouz
PostPosted: Thu Feb 07, 2008 3:02 pm     Reply with quote
Dear Noam,
Could you repost it please (With HTML disabled)?
Many thanks,
/me waiting for your reply Very Happy
EDIT: never mind, i managed to get your code to work correctly
Final result:
#include <18f4550.h>
#device HIGH_INTS=TRUE
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,PLL3,CPUDIV1,NOMCLR
#use delay(clock=48000000)
#use fast_io(d)
int8 pattern[100][1];
int8 pattern_index;
int8 i;
void set_pwm_pattern(int8 channel, int8 duty_cycle)
  int8 byte_ix, mask, index;
  mask = 1 << (channel & 7);
  for (index = 0; index < duty_cycle; index++)
    pattern[index][0] |= mask;
  mask ^= 0xFF;
  while (index < 100)
    pattern[index++][0] &= mask;
#int_timer2 high
void timer2_isr(void) // 6.6mS interrupt for 150Hz
output_d(pattern[pattern_index][0]);
if (++pattern_index >= 100)
pattern_index = 0;
void init(void)
// usual setup functions here
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,33,16);// 66uS interrupt for 150Hz * 1% steps
setup_vref(FALSE);
// initialize six 8-bit ports as outputs
output_d(0);
set_tris_d(0);
memset(pattern, 0, sizeof(pattern)); // turn ALL pwm outputs OFF
pattern_index = 0;
init();
set_pwm_pattern(0,0);
while (1){
for(i=0;i<15;++i){
set_pwm_pattern(0,i);
delay_ms(25);
for(i=15;i>0;--i){
delay_ms(25);
This test code will do an Up and down fade on a led ,,, pin RD0 especially
working with 0-15 of duty is ok for a led , higher than this it just get brighter for nothing...
Best Regards,
Laurent
ELCouz
PostPosted: Thu Feb 07, 2008 11:33 pm     Reply with quote
Ok the previous post did work #1 for PORT D.
Now I have decided to try the real deal, try for what the code was intended to be at first...multiple port pwm!
My code is:
#use fast_io(d)
#use fast_io(b) //<----- ADDED PORT B
int8 byte_ix,pattern[100][2];
int8 pattern_index;
void set_pwm_pattern(int8 channel, int8 duty_cycle) //PASTED your codeyou said that this was for the multiple ports
  mask = 1 <<channel>> 3;
    pattern[index][byte_ix] |= mask;
  mask ^= 0xFF;
  while (index < 100)
    pattern[index++][byte_ix] &= mask;
#int_timer2 high
output_b(pattern[pattern_index][1]);//<----- ADDED PORT B
pattern_index = 0;
void init(void)
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
setup_vref(FALSE);
output_b(0); //<----- ADDED PORT B
set_tris_b(0); //<----- ADDED PORT B
output_d(0);
set_tris_d(0);
pattern_index = 0;
init();
set_pwm_pattern(0,15);
set_pwm_pattern(1,15);
set_pwm_pattern(2,15);
set_pwm_pattern(3,15);
set_pwm_pattern(4,15);
set_pwm_pattern(5,15);
set_pwm_pattern(6,15);
set_pwm_pattern(7,15);
set_pwm_pattern(8,15);//<----- ADDED PORT B
set_pwm_pattern(9,15);//<----- ADDED PORT B
set_pwm_pattern(10,15);//<----- ADDED PORT B
set_pwm_pattern(11,15);//<----- ADDED PORT B
set_pwm_pattern(12,15);//<----- ADDED PORT B
set_pwm_pattern(13,15);//<----- ADDED PORT B
set_pwm_pattern(14,15);//<----- ADDED PORT B
set_pwm_pattern(15,15);//<----- ADDED PORT B
while (1);
and the result is this:
As you can see, i have not 16 but 5 led at on (the tiny pink thing you see on the leds that are OFF , is the phosphor coating which reflect red , they look like they are at ON with little voltage but they are at OFF).
but if i run the code that i have previously posted , the 8 leds can be switched at on without difficulties at an awesome pwm of 220.6hz.
Now i still get the same refresh rate of 220hz but with only 5 pins responding!!
Please help me to fix it, your code is so nice and short !
Oh btw, when you submitted your code as a guest,, I've fixed ++ increment that was missing from your code because of HTML ,, please take a look to see if everything is here Smile
Many thanks !
Laurent
PostPosted: Tue Feb 12, 2008 2:19 pm     Reply with quote
Dear Laurent,
Nice picture.
Try the following code instead of the one you sent me.
best regards
Noam
  byte_ix = channel >> 3;
  mask ^= 0xFF;
  while (index < 100)
ELCouz
PostPosted: Tue Feb 12, 2008 2:49 pm     Reply with quote
WOW thanks it works ! :D
Thank you so much ! Smile
If it wasn't because the PCD compiler is very broken , i would really like to port it to the dsPIC platform Smile
This topic is gonna be so much useful to anyone else who would be asking for software pwm !
Have a nice week,
Best Regards,
Laurent
ELCouz
PostPosted: Sat Nov 08, 2014 2:53 pm     Reply with quote
Just an update to n-squared...
This is still the most useful piece of code I've found on CCS.
I use it in many project requiring multple PWM (because 1-8 PWM avaible on some pics are not enough).
Thank you very much n-squared!
Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
Page 2 of 2
