[How to] Pic24EP256 output Crystal or FPLLO freq. on a pin
pieter
PostPosted: Thu Mar 13, 2014 11:51 pm     Reply with quote
//  Manual Setup for Reference Clock Output
#include <C:\Program Files\PICC\Devices\24EP256GP204.h>
#device ADC=12
#FUSES WDT                       //Watch Dog Timer
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES PLLWAIT                   //Use when PLL ready
#FUSES HS
#FUSES PR_PLL                     //Pimary oscillator
#FUSES OSCIO                       //OSC2 is general purpose output
#FUSES WPRES128              //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16              //Watch Dog Timer PostScalar 1:32768
#use delay(clock = 128000000, crystal=8000000, RESTART_WDT)
#PRAGMA   ZERO_RAM
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#word      REFOCON=0x074E               // reference clock setup register
#word      RP56=0x068C                  // Pin C8 reprogrammable address
main()
   SET_TRIS_A(0xfb7f);   // 1111 1011 0111 1111  my settings
   SET_TRIS_B(0x041f);   // 0000 0100 0001 1111
   SET_TRIS_C(0xfc03);   // 1111 1100 0000 0011  pin C8 is output
   Output_A(0x0000);   //0b7f);
   Output_B(0x0000);   //041f);
   Output_C(0x0143);   //0143);
//   With the fuses above:
//   Crystal = 8 mHz
//   Pll multiplies clock to 128 mHz
//   Output the CRYSTAL frequency or the FPLLO clock on Pin C8:
//   REFOCON=0x3700;            // CRYSTAL frequency to output as ref frequency registers div128
//   REFOCON=0xB700;            // measure freq on pin C8 with scope and multiply with 128 to get the crystal freq.
//     or
   REFOCON=0x2C00;            // FPLLO clock  div4096
   REFOCON=0xAC00;            // measure freq on pin C8 with scope and multiply with 4096 to get the FPLLO freq.
   RP56=0x31;                  // set reference clock output on pin C8
   while (TRUE)                  // main routine
      RESTART_WDT();            // reset watchdog
Fonky
PostPosted: Sun Oct 19, 2014 10:33 am     Reply with quote
// Crystal = 8 mHz
// or
Kick
