MCP2515 Baudrate Changing
Mucit23
PostPosted: Wed Aug 13, 2014 1:22 am     Reply with quote
hi friends,
In mcp2515, I want to 100Kbps baud rate value. What should be the correct settings for it?
Thank You
ezflyr
PostPosted: Wed Aug 13, 2014 3:46 am     Reply with quote
Wouldn't it be better to answer this question yourself by reading the data sheet, rather than coming here to be spoon fed an answer?
John
PostPosted: Wed Aug 13, 2014 12:14 pm     Reply with quote
As a hint, many people use the MBTime utility program to help them
calculate the CAN Bus baud rate parameters:
http://www.intrepidcs.com/support/mbtime.htm
The description of the program and the download link are on the right side
of the webpage. It works with MCP2515.
There are tutorials on this forum which explain how to use it.
Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=22138
