IO Ports as Input
Goto page Previous  1, 2
gaugeguy
PostPosted: Fri Aug 01, 2014 6:28 am     Reply with quote
When you "turn off power" your pull-up resistor becomes a pull-down resistor.
What else may happen depends on what the rest of your circuit looks like and how everything is powered.
PostPosted: Fri Aug 01, 2014 6:36 am     Reply with quote
simple RF suppression:
pull-up resistor =10k ohm
parallel capacitor = 10nF
capacitor is placed across the switch terminals
PostPosted: Fri Aug 01, 2014 2:05 pm     Reply with quote
Sterngleiter wrote:
it's just like having drawn alan.
I don't think so. In your previous post, you said this:
Sterngleiter wrote:
It's pulled low.
Then your code below, waits for the pin to go high (when the button is
pressed), and then counts up 'test' while the pin is high:
while(true)
   if(input(pin_a1)==1)
      while(input(pin_a1)==1);
      ++test;
So I strongly suspect that it's really connected like this:
                     Switch     +5v
                      ___        |
To                   _|_|_       |
PIC --------o--------o   o-------o
pin         |
            > 4.7K
           --- GND
If this is not an accurate description of your circuit, then post a schematic
that shows exactly what you have. Show all component values.
Sterngleiter
PostPosted: Tue Aug 05, 2014 11:34 am     Reply with quote
Hi, Thank You for so many tips. I thought software debouncing would be enough but unfortunately I have to debounce Hardware
Mike Walne
PostPosted: Tue Aug 05, 2014 3:27 pm     Reply with quote
Software debouncing is usually sufficient.
The problem all along has been you have adamantly refused to give us enough information to work on.
You say problem is now solved, that's good, but I still can't work out what the real problem was, hence my opt-out earlier.
Mike
PostPosted: Tue Aug 05, 2014 5:17 pm     Reply with quote
magic......
it would be nice to see the schematic and code for your solution
it'll help others in the future as it's a common problem...
jay
joergn
PostPosted: Fri Aug 08, 2014 3:11 am     Reply with quote
while(true)
      ++test;   // should count only when button is released or changed
Polling should not eat up all MCU power , so put it inside a timer
loop.
Page 2 of 2
