sst25vf.c Bug fixes
Post new topic   Reply to topic    CCS Forum Index -> Code Library
haxan7
sst25vf.c Bug fixes
PostPosted: Wed Aug 06, 2014 1:51 pm     Reply with quote
File: sst25vf.c
Compiler Version: v5.015
BUG #1
The following line
#define FLASH_ADDR_INVALID(addr) (addr > FLASH_SIZE)
needs to be changed to:
#define FLASH_ADDR_INVALID(addr) (addr >= FLASH_SIZE)
because addresses starts at zero, and the last byte is stored at FLASH_SIZE-1
BUG #2
At the start of the function void ext_flash_protect(FLASH_PROTECT_RANGE range), the following line should be added:
range=range<<2;
because BP0 is second bit of the Status Register.
BUG #3
In the function void ext_flash_protect(FLASH_PROTECT_RANGE range) this line
_ext_flash_send(SST25VF_WRITE_STATUS, TRUE);
needs to be changed into:
_ext_flash_send(SST25VF_WRITE_STATUS, FALSE);
BUG #4
Search for the following line:
static uint8_t _ext_flash_block_sizes[3] = {4096, 32768, 65536};
and change the uint8_t to uint32_t
Possible Compiler Bug
In function void ext_flash_protect(FLASH_PROTECT_RANGE range)
FLASH_XFER(range|FLASH_PROTECT_LOCK); was giving unpredictible results, following worked for me:
uint8_t reg2send = range|FLASH_PROTECT_LOCK;
FLASH_XFER(reg2send);
More bugs incoming ...[/b]
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
