Silly parameters function problem
Ark2040
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PostPosted: Tue Jul 22, 2014 3:16 pm     Reply with quote
Hi guys, I would like to do any like this code, but I dont know why doesnt work ?
#include <16f877.h>
#fuses HS,NOWDT,NOPROTECT
#use delay (clock=4000000)
#byte PORTA=0x05
#byte PORTB=0x06
#byte PORTC=0x07
#byte PORTD=0x08
int z;
//set_tris_a(0b00011111);
set_tris_b(0b11111111);
set_tris_c(0b11111111);
set_tris_d(0b00000000);
function(5,2);
PORTD=z;
void function(int x, int y){ // IT MUST RECOGNIZE NUMBERS WRITTEN UP
z=x*y;
return
newguy
PostPosted: Tue Jul 22, 2014 3:24 pm     Reply with quote
Either
int8 z;
z = x * y;
return z;
Or
return x * y;
First method will definitely work; 2nd may make the compiler complain.
PostPosted: Tue Jul 22, 2014 3:27 pm     Reply with quote
This is a basic C question. You need to study this topic off the forum.
Google for it:
How to return a value from a function in C
Look at some of the hits that you get. Study how they do it.
http://www.macs.hw.ac.uk/~pjbk/pathways/cpp1/node162.html
PostPosted: Tue Jul 22, 2014 3:30 pm     Reply with quote
if making a function, then it can't be 'void', must be an int as well...
it's covered in the help files...or see any number of the example programs CCS kindly supplies...
hth
jay
Ark2040
Thk U
PostPosted: Tue Jul 22, 2014 4:52 pm     Reply with quote
newguy wrote:
Either
int8 z;
z = x * y;
return z;
Or
return x * y;
Yes, I knew that Newguy, but I'm trying to write inside parentheses to obtain a result so ... I can not to do that Sad
Ark2040
PostPosted: Tue Jul 22, 2014 5:55 pm     Reply with quote
Google for it:
HEY PCM PROGRAMMER I GOT IT THKS U
#include <16f877.h>
#byte PORTA=0x05
#byte PORTB=0x06
#byte PORTC=0x07
#byte PORTD=0x08
int8 z;
void function(int8 one, int8 two)
z=one+two;
function(2,3);
PORTD=z;
PostPosted: Wed Jul 23, 2014 8:20 am     Reply with quote
It works but is very ugly code.
General rule is: Use as few global variables as possible.
In a small program like this it isn't a big problem but in a larger problem you will loose the overview of all the places where a variable is used and changed.
Why do you not want to have the function return a value?
This suggests your teacher wanted you to learn about macro's and that's not what you have created here...
