More current from a pin please!
will@reeve.org.uk
PostPosted: Fri Oct 17, 2003 8:07 am     Reply with quote
Guys,
I need more that 25mA from a 12F629 PIC pin! Running at 3.6volts (from a battery) I need to run a little RF receiver, that requires a 3.3volt input. Trouble is one pin will not supply enough current (approx 30mA) to run the receiver. Can I join two pins together (short) to source some more current to my receiver? I can’t use a transistor switch due to the voltage drop (0.7v). Any ideas much appreciated!
Will
P.S. Looking at the pin trying to supply the voltage, it give 3.6volts for about 5ms then sags to 2v!
Question
TSchultz
PostPosted: Fri Oct 17, 2003 8:43 am     Reply with quote
You can use a FET to switch the power, for a decent FET the voltage drop will be very low.
SherpaDoug
PostPosted: Fri Oct 17, 2003 9:19 am     Reply with quote
You can parallel (short together) two or more pins, but using a MOSFET transistor switch is a better solution. A 2N7002 is my default choice for a small switching FET application such as yours. At 3V on the gate it has about 5 ohms or 150mV drop at 30mA. I am sure you can find better if you need to.
dbotkin
PostPosted: Fri Oct 17, 2003 11:59 am     Reply with quote
Doug, where do you find that information -- or did you measure it? I can find all kinds of graphs in the 2N7000 / 2N7002 data sheet, but none seem to indicate to me Rds of 5 Ohms at Vgs = 3. I'm not disputing you, jsut asking where you found that -- I'm curious about performance of that and other MOSFETs at fairly low gate voltages.
Dale
mcafzap
Current from pins etc.
PostPosted: Sat Oct 18, 2003 9:46 am     Reply with quote
You can use a Zetex bipolar transistor. From memory they have some with Hfe of 900 and Vce about 14mV. They are also obtainable from Farnell. However, doubling-up on the outputs should be reasonably safe, cheaper and easier than any other solution.
Steve
david smith
driving higher currents
PostPosted: Tue Oct 21, 2003 9:47 pm     Reply with quote
I've used PICs to drive MOSFETs for several applications:
My frequent choice due to pkg/versatility is the
IRLD024 from I.R./Digikey. Ron <0.1ohm, 2.5A current, 4pin DIP, logic in
Other parts I've used, some with much higher currents. (Still ~$1)
mosfet IRLML2803 Nch 30V 0.25ohm SOT-23.pdf
MOSFET TN0604 N 4A 40V Logic Supertex.pdf
mosfet NTP45N06L N 45A 60V Logic.pdf
And, to drive loads connected to gnd, use a logic-level P-ch fet.
MOSFET VP3203 P -3V -30V .5A supertex.pdf
mosfet MTB30P06V P -30A 60V $0.94 Arrow.pdf
mosfet MTB50P03HDL P -50A 30V Logic D2PAK.pdf
SherpaDoug
PostPosted: Wed Oct 22, 2003 1:13 pm     Reply with quote
Dale
The Diodes Incorporated datasheet available through the Digi-Key website has a graph which shows less than 5 Ohms at 3V. It was clearer on another data sheet I looked at but I don't remember which brand.
dbotkin
PostPosted: Mon Oct 27, 2003 5:30 pm     Reply with quote
Ah-hah -- Thanks!! I hadn't thought of that, I was looking at the Fairchild data sheet. Should have looked at other manufacturers.
By the way, anyone want 250 2N7002's, SOT-23? I ordered them by mistake, meant to get 2N7000's (TO-92). First offer of eleven bucks including shipping gets 'em, I just received them from Mouser. Offer stands until I get an RMA number... :oops:
Dale
