[Solved]Loading eeprom with some initial values
Goto page Previous  1, 2
PostPosted: Sun Jun 01, 2014 3:48 pm     Reply with quote
Actually it does work. I tested it in vs. 5.026 and it works. But the OP
is likely using vs. 4.057, because it fails with that version (returns 0).
ckielstra warned the OP about using vs. 4.057 in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=51586
That version is buggy.
Here are the results of running the following test program,
first with vs. 5.026 and then with vs. 4.057:
add: 2100
add: 00
#include <16F886.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
printf("add: %Lx\n",getenv("EEPROM_ADDRESS"));
Page 2 of 2
