[solved] crazy about pin RA4 in PIC18F4550
potato
PostPosted: Sat May 17, 2014 8:59 am     Reply with quote
Hi again!
I've been doing some research here on the forum and I think I'll soon become crazy... My PIC ignores the inputs coming from pin A4 (I have a button there and there are no bouncing problems).
I thought I saw some light when I came across a couple of threads talking about #fuses NOIESO and #fuses SOSC_DIG or DIGITAL... but my compiler (version 4.0, though I've tried it with version 4.1 and it doesn't work, either) doesn't recognise the second fuse, neither SOSC_DIG or SOSC_DIGITAL.
I have to use this pin because the others are occupied (or not working, as A5, C1, C4, C5 or B7). It's not a PIC's problem, because I bought a new one and it's just the same...
What can I do? The fuses are the following:
#include <18F4550.h>
#FUSES HS                         //4 Mhz clock
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOLVP                      //No Low Voltage Programming on B5(PIC18)
#FUSES CPUDIV1                  //No System Clock Postscaler
#FUSES NOPBADEN                   //PORTB pins are NOT configured as analog input channels on RESET
#fuses NOIESO                    //Internal External Switch Over mode disabled
#fuses SOSC_DIG                 //To use the SOSC pins as normal i/o
Many thanks!
Humberto
PostPosted: Sat May 17, 2014 9:29 am     Reply with quote
Some questions:
1) Does your hardware successfully passed the basic test of a blinking LED?
2) If so, did you check if the LED blinking period corresponds with the code?
3) How is connected the button in A4?
5) Did you add a 10k pull-up resistor with the button?
6) Are you aware of this fuse set?
Regarding the posted info, it is very poor. We need a compilable code.
Nobody could help you if you only post the fuses configuration.
regards,
Humber
PostPosted: Sat May 17, 2014 9:30 am     Reply with quote
In addition to what Huberto said....
Since we cant see the rest of your code we have to guess.
Did you disable ADC?
Did you disable CCP?
PostPosted: Sat May 17, 2014 9:37 am     Reply with quote
That fuse is for PIC's like the PIC24's. Your chip doesn't have it.
Read the data sheet:
"The RA4 pin is multiplexed with the Timer0 module
clock input to become the RA4/T0CKI pin. The RA6 pin
is multiplexed with the main oscillator pin; it is enabled
as an oscillator or I/O pin by the selection of the main
oscillator in Configuration Register 1H (see
Section 25.1 “Configuration Bits” for details). When
not used as a port pin, RA6 and its associated TRIS
and LAT bits are read as ‘0’.
RA4 is also multiplexed with the USB module; it serves
as a receiver input from an external USB transceiver.
For details on configuration of the USB module, see
Section 17.2 “USB Status and Control”.
The command to disable the T0CKI use, is:
setup_timer_0(T0_INTERNAL);
If you are running, you need to be running with the internal transceiver, otherwise the hardware uses this pin.
potato
PostPosted: Sat May 17, 2014 9:51 am     Reply with quote
hi guys, thanks for you super-fast replies! Very Happy
I'm afraid I had no reasons to turn crazy... I've realised I had a software problem, because I had a while loop to wait for a button to be pressed and I didn't write that it also had to wait for a4... (because I had it in another while loop)
I know how stupid it sounds, specially because I had review the code millions of times Embarassed
Anyway, thanks for the ideas and, Ttelmah, thanks for specialising that I don't have to worry about that pin!
