CCS 5 with Wine (Linux) ?
LiLou
PostPosted: Thu May 15, 2014 12:19 am     Reply with quote
I'm trying to run latest CCS IDE on a Linux Mint Petra, but this is how I see it:
Can compile and it seems to work fine, but some buttons are not visible. Are you able to run it without problems?
Wine version: 1.6.1
PostPosted: Thu May 15, 2014 10:55 am     Reply with quote
be more specific
NOT visible at all
or "greyed out" -unavaialble
LiLou
PostPosted: Fri May 16, 2014 1:17 am     Reply with quote
asmboy wrote:
be more specific
NOT visible at all
The buttons are there, they are enabled, but aren't visible.
PostPosted: Fri May 16, 2014 3:55 pm     Reply with quote
on actual Windows as opposed to emulated windows -
it all works a far as i can tell
this is not a CCS problem unless they specifically say they support your environment ..
LiLou
PostPosted: Mon May 19, 2014 9:00 am     Reply with quote
No one has said the otherwise :S
Just wanted to know if there are someone that can emulate CCS 5 on Linux without problems.
PostPosted: Mon May 19, 2014 9:15 am     Reply with quote
I must admit I've always run a full 'virtual' Windows (VMWare or Parallels), rather than the compatibility layer. These both run fine. The VMWare Workstation player is free (you need a copy of Windows to install into the player).
I'd suggest running WineTricks, and seeing if that helps (it is supplied as standard with the current version so you may already have done this). A lot of the DLL's this adds are necessary for programs like CCS. The commonest problem with Wine, is the display not being handled right, so 'nothing unexpected here'....
