Posted: Mon May 12, 2014 7:18 am |
this is a fragment,
NOT a functioning, CCS compilable program.
it will not compile as is.
if it won't compile - i won't bother. |
ezflyr
Posted: Mon May 12, 2014 7:24 am |
It's also a fragment with glaring errors:
John |
ruth
Posted: Mon May 12, 2014 9:02 am |
sorry,make trouble to u all..this is my functioning program
#include <18F4620.h> // PIC18F4620 HEADER FILE
#fuses HS,NOWDT,NOLVP,NOPROTECT // EXTERNAL CLOCK, NO WATCH DOG TIMER, NO LOW VOLTAGE PROGRAMMING
#device adc=10 // USE 10 BIT ADC QUANTIZATION
#use delay (clock=20M) // 20 MHZ CRYSTAL
#include <lcd.c> // LCD DISPLAY HEADER FILE
#include <math.h>
#define SW1 PIN_B0
#define SW2 PIN_B1
#define LED1 PIN_B6
#define LED2 PIN_B7
#define AN0_AN2 0Xc8 // PIN_A0 till PIN_A2
#define LCD_E PIN_D0 // PIN E
#define LCD_RS PIN_D1 // PIN RS
#define LCD_RW PIN_D2 // PIN RW
#define LCD_D4 PIN_D4 // PIN D4
#define LCD_D5 PIN_D5 // PIN D5
#define LCD_D6 PIN_D6 // PIN D6
#define LCD_D7 PIN_D7 // PIN D7
float current;
float v_current;
int i,a;
float value,mean,s;
float v_value,v_mean;
void read_analog(); //current analog
void v_read_analog(); //voltage analog
setup_adc_ports(AN0_AN2); //Configure AN0 and AN2
setup_adc(ADC_CLOCK_DIV_32);
delay_ms(200);
if(!input(SW1))
while (true)
set_adc_channel(0); //ADC channel = AN0,AN0 ready for sampling
current=read_analog();
mean=value/10;
delay_ms(200);
set_adc_channel(2); //ADC channel = AN2,AN2 ready for sampling
v_current=v_read_analog();
v_mean=v_value/10;
delay_ms(200);
output_high(LED1);
read_analog();
v_read_analog();
printf(lcd_putc, "\fI=%fA",mean);
printf(lcd_putc, "\nV=%f",v_mean);
ELSE if(!input(SW2))
while (true)
mean=value/10;
delay_ms(200);
v_mean=v_value/10;
delay_ms(200);
output_high(LED2);
read_analog();
v_read_analog();
s=value*v_value;
printf(lcd_putc, "\fP=%fW",s);
void read_analog()
current=0;
for (i=0; i<=9;++i)
delay_ms(2);
value=read_adc();
v_current=0;
for (a=0; a<=9;++a){
delay_ms(2);
v_value=read_adc();
Posted: Mon May 12, 2014 11:25 am |
if(!input(SW1))
while (true)
how about you find and show me
the EXIT condition for this construct above ??
DITTO:
ELSE if(!input(SW2)) ........ |
ruth
Posted: Mon May 12, 2014 11:40 am |
asmboy,
it is means that i should put "end if" after i use "if"and put "end else if" after i use "else if"? |
ezflyr
Posted: Mon May 12, 2014 12:22 pm |
Hi ruth/low,
Asmboy already pointed you to the issue on the last page! You stated the problem as:
| Quote: |
the problem i encountered is i cant direct change the display from button 1 to button 2 (i only can press button 1, then reset it before i press button 2).
Your code is doing it this way as that is the way you coded it! As coded, SW1 is always evaluated first, and if it's low, SW2 will never be evaluated!
This is really more of a 'design philosophy' problem. For example, you have two operational states, so why do you need two switches? With two switches, it's always going to operate 'oddly'! Why not do one thing then SW1 is high, and another thing when it's low?
John |
Mike Walne
Posted: Mon May 12, 2014 2:35 pm |
I support ezflyr on this one.
I doubt that any part of your code has been properly tested and shown to work as intended.
You are asking for help, yet none of the code does what you claim.
1) You are transfixed on dealing with what the buttons do.
2) The voltage and current procedures do not measure averages.
Work on the KISS principle.
Code in small. easy to manage sections.
Test that each section works as it should.
Move on to the next section.
Stitch all the sections together.
Mike |
