Formula for Current Transducer Model LTS 15 NP
Goto page Previous  1, 2, 3  Next
Mike Walne
PostPosted: Sun May 04, 2014 10:49 am     Reply with quote
ruth wrote:
may i know it is any method that i can use both of my current sensor (10 bit analog input) and voltage sensor (10 bit analog input) into my PIC which is 10 bit?
You are already converting current to a voltage.
Simply use another analogue input to the PIC for the conditioned voltage signal.
Mike
low
PostPosted: Sat May 10, 2014 2:12 am     Reply with quote
mike, i wan to use the value of voltage sensor and current to calculate the power (P=IrmsVrms)
i had tried to use another analog input for my voltage sensor. i had get the result for both current and votlage sensor if but my adc only can read 1 adc value at 1 time. I cant read 2 adc values at the same time.
So, my problem is in the program the my adc value for voltage sensor and current sensor cant be read together, so i cant multiply that the output of that 2 sensor.
Do u all have any idea about that?
PostPosted: Sat May 10, 2014 2:22 am     Reply with quote
You can read one input, then the other. On a typical PIC, just 10uSec between the readings (on some as little as 2.5uSec). On a 50/60Hz waveform, the error in this time is insignificant, and will cancel over time (second reading higher on the first half cycle, and lower on the second).
Take the readings then do the maths (to minimise the delays).
Mike Walne
PostPosted: Sat May 10, 2014 6:22 am     Reply with quote
Are you trying to measure REAL or APPARENT power?
The formula you quote is for apparent power.
For real power you want the average of I*V over an integral number of mains cycles.
Like Mr T says measuring I and V one after the other is not a problem with mains frequency input.
OR
Read I and V at equally spaced intervals. Calculate power from one reading of current and average of two voltage readings.
Mike
low
PostPosted: Sat May 10, 2014 10:06 am     Reply with quote
thx for guide for ttelmah and mike..
actually i want to find real, apparent, reactive and power factor as well...
so in order to obtain all those parameter i just need to play around the formula is it? is it necessary to find the zero crossing for voltage sensor?
Mike Walne
PostPosted: Sat May 10, 2014 2:30 pm     Reply with quote
I've already shown how to handle V & I without the need to determine crossing points.
I will have a look at real power issue and come back.
Once you have real & apparent power, the other two, reactive power & power factor, fall out.
Mike
PostPosted: Sat May 10, 2014 3:38 pm     Reply with quote
That being true, your sensor is only one part of the circuitry you need.
Understand that it is based on a passive current transformer, and thus
IS NOT PHASE SENSITIVE.
the data you get from it is unavoidably "simple instantaneous" current.
it is NOT the "real" ( x or REAL component of a synchronous demodulator)
NOR is it the "reactive" current either ( the Y /IMAGINARY/QUADRATURE component of a sync demod)
what your data really is,
IS actually the square root of (X^2) *(Y^2); from above
and nothing more..... Very Happy Very Happy Very Happy
adding circuitry to get X is simpler than what you need to read Y,
and with the identity provided by the above equation AND X alone
you can calculate the other stuff you care about.
here is a link to page with info about how to use a multiplier IC AD633 -
for an in-phase watt meter . and background that may also help you.
http://mysite.du.edu/~etuttle/electron/elect64.htm
the" test circuit" in the article highlights how a multiplier ( as a simple form of sync-demod) can create a phase sensitive True RMS power result,
from a power factor impaired load.
BTW: is this for a no-kidding PRODUCT or school PROJECT?
ruth
PostPosted: Sun May 11, 2014 7:45 am     Reply with quote
instantaneous current-by using the LTS current sensor (i get 10 sample,find its mean and rms)
voltage value- my voltage sensor ( use simply a transformer to step down the input voltage before enter PIC, use 10 sample, find its mean and rms)
the multiplication of instantaneous current and voltage value is just a normal power (which is not real nor reactive power)
in order to find real n reactive power i should get either x or y component (phasor different)?
asmboy, my understand is it correct?
that is school project.. Smile
PostPosted: Sun May 11, 2014 8:48 am     Reply with quote
\in order to find real n reactive power i should get either x or y component (phasor different)?
Yes - as well as you express it -
but as i said -
is easier to get a X value ( from sensed input voltage-)
since you have no (simple) source of quadrature demodulation carrier
to measure Y .
Mike Walne
PostPosted: Sun May 11, 2014 10:52 am     Reply with quote
1) For your voltage sensor:- Can we assume that you offset the voltage? (So that you are not forcing the PIC ADC input to go negative)
2) How are you selecting your 10 samples for the V and I computations?
Mike
ruth
PostPosted: Sun May 11, 2014 11:19 am     Reply with quote
mike,
yes, i had offset the voltage before it enter the PIC.
for the samples selection, i just use 10 sample in my loop and do my calculation. i dont really select it.
for programming, i use 2 buttons (button 1 and button 2)to control the display analog input on LCD.
the problem i encountered is i cant direct change the display from button 1 to button 2 (i only can press button 1, then reset it before i press button 2).
the programming is used is
if(!input(SW1))
while (true)
function
if(!input(SW2))
while (true)
function
can anyone give me the idea to solve it?
thanks
PostPosted: Sun May 11, 2014 11:24 am     Reply with quote
ELSE if(!input(SW2))
then if SW1 asserted you have the OPTION of SW2
this has become K&R 1.0 we are discussing. Very Happy Very Happy Question
ruth
PostPosted: Sun May 11, 2014 11:36 am     Reply with quote
asmboy, i had tried this before but it doesnt work as well.
Do u have any idea?
thanks
PostPosted: Sun May 11, 2014 12:55 pm     Reply with quote
perhaps you might post THE WHOLE program as you have it now ??
i can't keep guessing based on these tiny fragments .........
ruth
PostPosted: Mon May 12, 2014 2:27 am     Reply with quote
asmboy, here is my code. Can u help me take a look? thanks
void read_analog();
void v_read_analog();
setup_adc_ports
if(!input(SW1))
while (true)
 current=read_analog();
v_current=v_read_analog();
 output_high(LED1);
 read_analog();
  v_read_analog();
    printf(lcd_putc, "\fI=%fA",current);
    printf(lcd_putc, "\nV=%f",v_current);
if(!input(SW2))
while (true)
  s=current*v_current;
   printf(lcd_putc, "\fP=%fW",s);
[/code]
Page 2 of 3
