Posted: Mon Apr 28, 2014 2:06 am |
Yes.
My problem is the 'dross'....
A test program, should only use the timers, interrupts etc., that are actually involved in the problem.
As a test, if you want the original message, this can be done as:
#include <16F648A.h>
#FUSES NOWDT
#FUSES EC_IO
#FUSES BROWNOUT,MCLR,NOLVP,NOPROTECT,NOCPD,PUT
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,UART1,bits=8,ERRORS)
#define MESSAGE_SIZE 19;
int8 message[]={0xAA,0x55,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0xFF};
#int_TBE
void TBE_isr(void)
static int8 ctr=0;
putc(message[ctr++]);
if (ctr==MESSAGE_SIZE)
disable_interrupts(INT_TBE);
ctr=0;
#int_TIMER0
void TIMER0_isr(void)
static tick=60;
if(tick--==0)
tick=60
enable_interrupts(INT_TBE);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
setup_vref(FALSE);
do
delay_us(10);
while(TRUE);
I seriously think you have a hardware problem. I'd suspect something like a capacitive connection to the RS232 lines, so a small 'spike' is getting through (enough to be seen as a start bit), but not the data. Hence a simple 'hello world' test should be the starting point.
As a comment to the original code, you do realise that you can code multiple identical cases as:
case 2:
case 3:
case 4: //etc..
putc(0x00);
scomtxwords++;
The single set of code, gets it's address put into the jump table for every case listed, instead of multiple routined being generated. |
gjs_rsdi
Posted: Mon Apr 28, 2014 2:42 am |
Hi Ttelmah
I made the program bellow according to Mike advice (part of it)
I am getting infinite 00, don't have any delay.
I will copy now your program and will run it.
The reason I wrote identical cases (I didn't know that I can write them as you have written) is because in the original program have different data in each case.
I think also is a hardware problem, but not with my board as I tested the previous board and have the same problem.
Maybe the FTDI USB to TTL is the problem, this is the only new component in the system because the old one I give to my friend. Maybe the driver is wrong. I try to find out.
Joe
The program:
#FUSES EC_IO
#FUSES PUT,NOPROTECT,BROWNOUT,MCLR,NOLVP,NOCPD
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,ERRORS)
setup_vref(FALSE);
disable_interrupts(INT_TIMER1);
disable_interrupts(INT_TIMER0);
disable_interrupts(INT_RDA);
rs232_errors=0;
while (1)
printf ("Hello World \n\r");
Posted: Mon Apr 28, 2014 4:21 am |
| The FTDI adapters are usually about the best. Obvious thing would be that it's baud rate is set to a value like 115200bps. Then it'd see any start bit or low data bit as 8 bits of 'all low'.... |
Posted: Mon Apr 28, 2014 5:25 am |
hmm.. simple thing to do..
Remove the USB<->TTL adapter and just wire it's TX to it's RX pins, effectively a 'loopback' connection. Use a PC terminal prgram and confirm typing on the PC KBD does display onto the PC screen. If you remove the loopback connection nothing should appear on the screen while typing.
This test will confirm the PC is OK, and that the USB<->TTL adapter is working correctly.
You might have the TX and RX of the PIC on the TX and RX of the USB adapter! Easy mistake, they should be RX to TX, TX to RX. I've used several 'generic' USB-TTL adapters since they're only $2 a unit these days and never had one fail yet. I do the above test on every one though as it's best to KNOW hardware does work BEFORE adding in software.
hth
jay |
gjs_rsdi
Posted: Mon Apr 28, 2014 3:26 pm |
First I would like to apologize to every one for spending your time, myself learned a lot.
I simply connected the TTL tx to the rx as temtronic has advised me.
Sending 55,AA,FF, getting 00,00,00. Doesn't matter what I am sending, getting back just '00', at the length of my message.
I will be grateful if somebody will teach me what to do regarding the FTDI
Ttelmah, I copy your file and tried to compile but getting 46 errors starting with: USE parameter value is out of range "UART1". If I remove the UART1 remain 44 errors.
I would like to make your program operational as I can learn a lot from it.
Thanks for everybody investing his time on this topic
Joe |
Posted: Mon Apr 28, 2014 5:22 pm |
Joe
Good news is it's NOT the PIC....bad news..silly usb module, but at least you KNOW where the trouble is, which is 1/2 the battle!
I use Realterm for my terminal program,though even Hyperterminal should work fine. I don't use the FTDI product but try their website for any information regarding the 'driver' the PC needs to run it. Maybe you need a different version to operate correctly ? Also, maybe you have 'handshaking' enabled(or not) and that might be wrong.Others here have probably used the FTDI unit, maybe post the model number and see if other can help.
cheers
jay |
gjs_rsdi
Posted: Mon Apr 28, 2014 6:04 pm |
The board have a connector to the USB cable and a male connector to TTL with all the functions, I am using just TX, RX and ground. Have also LED for TX and LED for RX
What is written on the chip is:
FTDI
1213 - C
CN 480661
FT 232 RL
Any help is appreciated.
Joe |
gjs_rsdi
gjs_rsdi
Posted: Mon Apr 28, 2014 7:27 pm |
Problem solved
Manually changed the driver to the older version and everything works perfect.
I would like to thank again to everyone that spent time to help me.
Best wishes
Joe |
Posted: Tue Apr 29, 2014 12:36 am |
There is one extra ';' (on the define), and one missing on one line in the code. Type missing on one variable declaration. A total of three errors:
#FUSES NOWDT
#FUSES EC_IO
#int_TBE
void TBE_isr(void)
static int8 ctr=0;
ctr=0;
#int_TIMER0
static int8 tick=60;
if(tick--==0)
tick=60;
setup_vref(FALSE);
do
delay_us(10);
while(TRUE);
Works, and makes changing what it sent much easier. |
gjs_rsdi
Posted: Tue Apr 29, 2014 6:07 am |
Thanks Ttlemah.
It works after taking out UART1, otherwise makes errors:
Undefined identifier -- putchar
#use rs232(baud=9600,parity=N,bits=8,ERRORS) works fine
I will play with the program later, will try to make the program I am improving now more small.
James |
Posted: Tue Apr 29, 2014 7:22 am |
What compiler are you on?.
UART1, has been allowed as an automatic definition for the UART (and is in fact 'required' on chips with selectable pins), for about 50+ versions of the compiler.... |
gjs_rsdi
Posted: Tue Apr 29, 2014 5:22 pm |
The compiler is very old, but works very good, no bugs except one:
CCS PCM C Compiler, Version 3.249
I am not working anymore with electronics, it is just an one time project for a friend.
Joe |
