Communicating with energy meter on MODBUS with P24FJ64GA004
Goto page Previous  1, 2
PostPosted: Thu Apr 24, 2014 1:57 am     Reply with quote
#define MODBUS_SERIAL_BAUD 9600
default baud on your device, is 19200....
hssn601
PostPosted: Thu Apr 24, 2014 7:47 am     Reply with quote
dear its already defined see system.h
alan
PostPosted: Thu Apr 24, 2014 7:53 am     Reply with quote
Yes what Ttelmah means it should be defined as 19200 and not 9600.
Regards
notbad
PostPosted: Thu Apr 24, 2014 8:11 am     Reply with quote
I'm not an expert but I suggest you test with a simple setup.
Let modbus library use hardware UART.
Use ASCII mode and if you can, use another 485 receiver and a PC to see whats going on the bus.
Check if communication parameters(baudrate etc.) are the same between PIC and slave.
Check power and wiring.
You can test one thing. Connect your PC to your unit using a USB<>485 converter and type modbus ASCII commands in a terminal program(like HyperTerminal) and see if it responds.
Make sure your terminal program is set to send both CR and LF.
hssn601
PostPosted: Thu Apr 24, 2014 8:19 am     Reply with quote
Regards
on energy meter i have changed it to 9600
hssn601
PostPosted: Thu Apr 24, 2014 8:20 am     Reply with quote
hm i am also thinking off something like this.
hssn601
PostPosted: Tue May 06, 2014 5:49 am     Reply with quote
i only want to read values of some registers so i have written my own program.
the problem is that sometimes it stuck on fgetc() may be because nothing is comming from port .
i am using software serial.
read4012(){
DIR_485_OUT();
InitializeModbus();
//sending command to read register
delay_ms(10);
for(int i=0; i<8 ; i++){
fprintf(S_SERIAL3,"%c",read4012c[i]);
fprintf(SERIAL2,"%c",read4012c[i]);
DIR_485_IN();
int sbuff[8];
//Reading Response
for(i=0 ; i<7; i++){
sbuff[i]=fgetc(S_SERIAL3); // here code gets sucked may be becauce nothing is comming.
//timeout=0;ready=0;
float result=make16(sbuff[3],sbuff[4]);
result = result/100;
fprintf(SERIAL2,"Frequency=%3.2f \r",result);
result=0;
InitializeModbus(){
DIR_485_OUT();
for(int i3=0;i3<10;i3++){
for(int i2=0; i2<8 ; i2++){
fprintf(S_SERIAL3,"%c",read4012c_ini[i2]);
//fprintf(SERIAL2,"%c",read4012c[i]);
i just want to advance to next line if fgetc(S_SERIAL3); reads nothing for 10ms
PostPosted: Tue May 06, 2014 7:24 am     Reply with quote
Look at the timeout option in #use rs232
There may well be better ways of handling things, but this is a start.
hssn601
PostPosted: Wed May 07, 2014 1:01 am     Reply with quote
thanks solved my problem.
Page 2 of 2
