why isn't working
Goto page Previous  1, 2
idris
PostPosted: Thu Apr 17, 2014 10:14 am     Reply with quote
we fixed thanks every one last code here now ı have to understood how work DS18B20 because is not measuring correctly every moment changing on screen
#include <18F4550.h>
#device ADC=10
#FUSES PLL1                     //No PLL PreScaler
#FUSES CPUDIV4                  //System Clock by 4
#FUSES INTHS                    //Internal Oscillator, HS used by USB
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(int=8000000)
#include <HDM64GS12.c>
#include <graphics.c>
//#use fast_io(a)
unsigned long int bilgi, bilgi1;
float voltaj, sicaklik;
char text[];
   setup_psp(PSP_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_timer_3(T3_DISABLED | T3_DIV_BY_1);
   setup_CCP1(CCP_OFF);
   setup_CCP2(CCP_OFF);
set_tris_a(0x01);
setup_adc(adc_clock_div_32);
setup_adc_ports(AN0);
glcd_init(ON);
set_adc_channel(0);
delay_us(20);
   bilgi=read_adc();
   delay_ms(10);
   voltaj=bilgi
   sicaklik=voltaj
   delay_ms(20);
   sprintf(text,"%5.2f", sicaklik);
  glcd_text57(1, 1, text, 1, ON);
    delay_ms(10);
    glcd_init(ON);
[/code]
PostPosted: Thu Apr 17, 2014 10:22 am     Reply with quote
You do not have any code or driver for the DS18B20 in your posted program!
PostPosted: Thu Apr 17, 2014 10:26 am     Reply with quote
He is announcing what he is going to do next. His current code works,
so he will next work on DS18B20.
PostPosted: Thu Apr 17, 2014 2:50 pm     Reply with quote
sorry...been a long day...got forklift stuck in mud and this PC decided to go 'funny',sigh....
there are 'drivers' and working code for the DS18b20 in the code library...
hth
jay
gpsmikey
PostPosted: Thu Apr 17, 2014 4:16 pm     Reply with quote
So Temtronic, you are saying you have a problem with the "driver" for the forklift??? Twisted Evil
mikey
mikey
Page 2 of 2
