DS1307 starting at faster frequency
Goto page Previous  1, 2
asmallri
PostPosted: Fri Apr 11, 2014 2:52 pm     Reply with quote
Ttelmah wrote:
..Laid out properly, the DS1307, is reliable.
I agree however that is not the problem in this case. The layout, while not ideal, is unlikely to cause what you are seeing.
Are you absolutely positive the crystal you are using is 32768Hz and it supports a 12.5pF load?
Regards, Andrew
asmallri
PostPosted: Fri Apr 11, 2014 2:54 pm     Reply with quote
newguy wrote:
ezflyr wrote:
I just checked Digikey, and they don't sell anything else!
Just designed a board with this:
http://www.digikey.ca/product-detail/en/ECS-.327-6-34S-TR/XC1935CT-ND/3927393
Also previously designed a board with this:
http://www.digikey.ca/product-detail/en/ABS25-32.768KHZ-6-T/535-10240-1-ND/2218053
The specific links in both cases point to a crystal designed for 6pF load - not 12.5pF required by the DS1307. However both offer 12.5pF variants.
Regards, Andrew
newguy
PostPosted: Fri Apr 11, 2014 3:21 pm     Reply with quote
The point of the post was only to show that there are 32.768 kHz crystals that aren't in the "standard" cylindrical radial can package, as a previous poster had implied don't exist.
asmallri
PostPosted: Fri Apr 11, 2014 3:30 pm     Reply with quote
Sorry. I took your previous post comments literally.
Regards, Andrew
ezflyr
PostPosted: Fri Apr 11, 2014 3:52 pm     Reply with quote
Hi newguy,
Uh, no...... Actually, I implied no such thing, and in fact stated exactly the opposite: "I'm not saying they don't exist, but every '32.768 KHz' crystal I've ever seen has come in a cylindrical style package." What I was *implying* is that the package shown in the layout is NOT common for that particular crystal type, that's all! If you want to play 'Gotcha', at least try to get the original posting correct!
John
bkamen
PostPosted: Sat Apr 12, 2014 9:05 pm     Reply with quote
ezflyr wrote:
Are you sure that you are using the correct crystal? I'm not saying they don't exist, but every '32.768 KHz' crystal I've ever seen has come in a cylindrical style package. I just checked Digikey, and they don't sell anything else! I suppose you may have just placed a footprint you had on hand without attempting to match your physical crystal?
John,
I've done several designs with flat SMT (like 5mm x 3.2mm) sized 32.768KHz crystals.
There's other sizes out there..
-Ben
40inD
PostPosted: Mon Apr 14, 2014 5:03 am     Reply with quote
I have replaced the crystal, and problem has gone.
BTW - HC-49 footprint was placed on pcb specially, for using of the crystal in this package. There is a opinion that devices in this package are more precise. But it was out of stock in the shop.
Page 2 of 2
