Interfacing LCD 2X16 JHD162A with PIC18F46K22
Goto page Previous  1, 2, 3
PostPosted: Wed Jan 08, 2014 2:16 am     Reply with quote
One of the old recommendations applies here.
KISS.
Write a simple program, that toggles one pin. Perhaps 1 second delay in the loop. Nothing else.
A total of about four lines of code.
Then run this, and verify that the pin does toggle and at the right speed. LED, or scope.
Only try to write any other code, once the pin _is_ toggling at the defined rate. Otherwise you are on a 'hiding to nowhere'.
senur
PostPosted: Thu Jan 09, 2014 9:43 am     Reply with quote
I have fixed the problem. It is weird but it worked for me. I don't know why I'm getting this problem. It was specified clearly in the datasheet that the speed for writing is 40us.
But in my case it is 60us. I've tried a lot with every possible number but 60 was the only one that gave me the right output.
I simply modified the "flex_lcd.c" function lcd_send_byte() to delay_us(60)
and surprise surprise I got the expected output. Very Happy
You guys told me that it was a timing problem but I never thought of this number. Till now I'm still confused why this number even though it was written in the datasheet 40us. Confused
Thank you for helping me.
gpsmikey
PostPosted: Thu Jan 09, 2014 9:47 am     Reply with quote
One of the things that often bites people here (especially people like students/experimenters) is that the parts they buy from surplus outfits etc. often are there for a reason - they may not meet the published specs (timing, leakage etc.). Parts obtained from ebay and various surplus places may function correctly, just not within the published specs (like timing).
mikey
Page 3 of 3
