vortexe90
| Big font for T6963c Graphic LCD |
Posted: Fri Nov 01, 2013 4:58 pm |
Hi friends............
I used the driver for a graphic display T6963C, but I found a problem to display large letter, the resolution is very unpleasant when I use a letter with a large size. so I would like letters with resolution of 16x16 if possible, because the one I use is 5x7.
Main prog :
| Code: | #include <16F877A.h>
#device adc=16
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#use delay(clock=25000000)
#include "T6963KELLAL.c"
CHAR PP[]="Ab5";
int16 counter;
set_tris_c(0x00);
glcd_init();
glcd_WriteByte(1, (LCDModeSet|LCDMode_XOR));
glcd_WriteByte(1, (LCDDispMode|LCDDisp_TXT|LCDDisp_GRH));
delay_ms(200);
clear_screen();
While (1)
glcd_text57(5, 32, PP, 1, 1);
glcd_text57(40, 20, PP, 4, 1);
glcd_text57(140, 20, PP, 5, 1);
delay_ms(3000);
driver : T6963KELLAL.c
| Code: | #use fast_io(D)
#include "math.h"
#define set_tris_lcd(x) set_tris_d(x)
//TRIS DataBus=x, note:control bus (PORTC) always outputs
const int16 TextHome=0x0780; //(240*64)/8=1920-->0x0780
const int8 TextArea=0x001E; // how many bytes before a new line (30 bytes)
const int16 GraphicsHome=0x0000;
const int8 GraphicsArea=0x001E; // how many bytes before a new line (30 bytes)
const int8 AutoModeWrite=0xB0; //DataAutoWrite
const int8 AutoModeRead=0xB1; //DataAutoRead
const int8 AutoModeReset=0xB2; //Auto reset
const int8 LCDModeSet = 0x80; // send this OR'd with the following
const int8 LCDMode_OR = 0b0000;
const int8 LCDMode_XOR = 0b0001;
const int8 LCDMode_AND = 0b0010;
const int8 LCDMode_TA = 0b0100; // TEXT ATTRIBUTE mode.
const int8 LCDMode_RAM = 0b1000; // 1=CG RAM, 0=internal CG ROM
const int8 LCDSetCursorPtr = 0x21; // cursor address
const int8 LCDSetCursorSize = 0xA0; // 1 line cursor
const int8 LCDDispMode = 0x90; // send this OR'd with the following
const int8 LCDDisp_BLK = 0b0011; // Blink Cursor
const int8 LCDDisp_CUR = 0b0010; // Add Cursor
const int8 LCDDisp_TXT = 0b0100; //Text-OK,Graphic-NG
const int8 LCDDisp_GRH = 0b1000; //Text-NG,Graphic-OK
const int8 LCDBitSet = 0xF8;
const int8 LCDBitReset = 0xF0;
struct lcd_pin_def //Struct type bitfield
int1 unused1 :1; // C0
int1 unused2 :1; // C1
int1 unused3 :1; // C2
int1 ce :1; // C3 Chip enable active low
int1 w_bar :1; // C4 Write bar active low
int1 r_bar :1; // C5 Read bar active low
int1 cd :1; // C6 Command/Data BAR 1=command 0=data
int1 reset_bar :1; // C7 Reset active low
int8 data :8; // PortD=Data bus(address=8)
struct lcd_pin_def LCD;
#byte LCD = 7 // portC address=7 on 16F887
//Prototyping
int glcd_ReadByte(void);
void glcd_WriteByte(int1 cd, int data);
void glcd_WriteByteAuto(int data);
void glcd_WriteCmd2(int16 data, int cmd);
void glcd_WriteCmd1(int data, int cmd);
void glcd_gotoxy(int x, int y, int1 text);
void glcd_init(void)
int16 counter;
set_tris_lcd(0x00); //TRIS DATA bus(PORT D),note:control bus always outputs
LCD.ce=0; //INITIAL STATES OF CONTROL PINS
LCD.w_bar=1; //
LCD.r_bar=1; //
LCD.cd=1; // command
LCD.reset_bar=0; // perform a reset
delay_us(10); // delay for a reset
LCD.reset_bar = 1; // run
// Set up the graphics and text areas
glcd_WriteCmd2(TextHome, 0x40); //TextHomeAddress Set
glcd_WriteCmd2(TextArea, 0x41); //TextArea column Set
glcd_WriteCmd2(GraphicsHome, 0x42); //GraphicHomeAddress Set
glcd_WriteCmd2(GraphicsArea, 0x43); //GraphicArea column Set
// set AddressPointer to 0
glcd_WriteCmd2(0x0000, 0x24); //Set AddressPointer to 0
// Clear all RAM of LCD (8k)
glcd_WriteByte(1, AutoModeWrite); //Set Data Auto Write
for (counter = 0; counter < 0x1fff; counter++) //0x1fff=8191 bytes
glcd_WriteByteAuto(0); // fill everything with zeros
glcd_WriteByte(1, AutoModeReset);
void glcd_WriteByte(int1 cd, int data) //Write PORTD as command or data in "Normal" mode.
int status = 0, temp = 0;
set_tris_lcd(0xff); // All inputs
LCD.ce = 1;
LCD.w_bar = 1;
LCD.r_bar= 1;
LCD.cd = 1;//defaults
while (status != 0x03) { // is LCD busy?
LCD.r_bar= 0;
LCD.ce = 0; //After 150ns read the data on D0-7
#asm nop #endasm
temp = LCD.data;
LCD.ce = 1;
LCD.r_bar = 1;
status = temp & 0x03; //Masking
set_tris_lcd(0x00); // All outputs
LCD.cd = cd; // Command/Data bar (1=command 0=data)
LCD.data = data; // Put data on data bus
LCD.ce = 0;
LCD.r_bar = 1; // not read
LCD.w_bar = 0; // write
LCD.ce = 1;
LCD.w_bar = 1; // release
void glcd_WriteByteAuto(int data) //Write PORTD as data in "Auto" mode.
int status = 0, temp = 0; // WHEN Auto mode,the status bits ARE DIFFERENT BITS THAN NORMAL MODE
LCD.ce = 1;
LCD.w_bar = 1;
LCD.r_bar = 1;
LCD.cd = 1; // defaults
while (status != 0x08) { // is LCD busy? Checking STA3!
LCD.r_bar = 0;
LCD.ce =0; //After 150ns read the data on D0-7
#asm nop #endasm
temp = LCD.data;
LCD.ce = 1;
LCD.r_bar = 1;
status = temp & 0x08; //Masking
LCD.cd = 0; // This is always data
LCD.ce = 0;
LCD.ce = 1;
glcd_WriteByte(0, data);
glcd_WriteByte(1, cmd);
glcd_WriteByte(0, data & 0xff); //masking,LSB Set
glcd_WriteByte(0, data>>8); //shift right 8bir,MSB Set
int data = 0, status = 0, temp = 0;
LCD.ce = 1;
LCD.w_bar = 1;
LCD.r_bar = 1;
#asm nop #endasm
LCD.r_bar = 0;
LCD.ce = 0;
temp = LCD.data;
LCD.ce = 1;
LCD.r_bar = 1;
LCD.cd = 0; // Command/Data bar
LCD.ce = 0;
LCD.r_bar = 0; // read
#asm nop #endasm // THIS PAUSE IS VERY NESSESARY !!!//
data = LCD.data;
LCD.r_bar = 1;
LCD.ce = 1;
LCD.cd = 1;
return data; // Return the read data
void glcd_putc(char c) {
glcd_WriteCmd1(c - 0x20, 0xc0); //c-0x20=Transfer from Ascii Code, Data Write UP.
void glcd_gotoxy(int x, int y, int1 text) { // sets memory location to screen location x, y
// location 1,1 is upper left corner;
// text = 1 (text area), text = 0 (graphics area)
int16 location, home;
int line;
if (!text) {
home = GraphicsHome;
line = GraphicsArea;
else {
home = TextHome;
line = TextArea;
location = home + (((int16)y - 1) * line) + x - 1;
glcd_WriteCmd2(location, 0x24);
Void clear_screen(void){ //very simular to the glcd_init(void)
int16 counter;
// set address to 0
unsigned int8 i; //General Purpouse variable
// glcd_pixel8(x,y,px8) sets 8 pixels in line.
void glcd_pixel8(unsigned int8 x, unsigned int8 y, int8 pixel8){
unsigned int8 x_H;
x_H = (x / 8);
glcd_gotoxy(x_H+1,y,0);
glcd_WriteCmd1(pixel8,0xc0); //Write data and increament
// glcd_pixel(x,y,c) sets pixel x,y with c color
void glcd_pixel(unsigned int8 x, unsigned int8 y, int1 c){
unsigned int8 x_H;
unsigned int8 x_L=0;
x_H = (x / 8);
x_L = 7 - (x - 8*x_H);
if(c){
glcd_WriteCmd1(1,(LCDBitSet|x_L));
} else {
glcd_WriteCmd1(1,(LCDBitReset|x_L));
// glcd_line(x0,y0, x1,y1, c) puts line from (x0, y0) to (x1, y1) with c color
//#separate
void glcd_line(signed int16 x0, signed int16 y0,
signed int16 x1, signed int16 y1 , int1 c){
int16 x;
int16 y;
unsigned int16 n;
int1 m_case;
x=abs(x1-x0);
y=abs(y1-y0);
if (y > x){
n=(y1-y0);
m_case=1;
} else {
n=(x1-x0);
m_case=0;
for(i=0 ; i<=n ; i++){
if (m_case){
y=i + y0;
x=(y*(x1-x0))/(y1-y0) + x0;
} else {
x=i + x0;
y=(x*(y1-y0))/(x1-x0) + y0;
glcd_pixel(x, y,c);
// glcd_square(x0,y0,x1,y1, c) sets square
void glcd_square( unsigned int8 x0, unsigned int8 y0,
unsigned int8 x1, unsigned int8 y1 , int1 c){
glcd_line(x0,y0, x1,y0, c);
glcd_line(x1,y0, x1,y1, c);
glcd_line(x0,y1, x1,y1, c);
glcd_line(x0,y0, x0,y1, c);
// glcd_box(x0,y0,x1,y1, c)
void glcd_box( unsigned int8 x0, unsigned int8 y0,
unsigned int8 x;
unsigned int8 y;
for(y=y0; y<=y1;y++){
for(x=x0; x<=x1;x++){
if((!(x%8)) && ((x1-x)>8)){
glcd_pixel8(x,y,0xFF*c); //Same time to write 8 pixel
x +=7 ;
} else {
glcd_pixel(x,y,c);
//glcd_image8 (*Pic, x, y, size_x, size_y)
void glcd_image8(int8 *pic_px, unsigned int8 x, unsigned int8 y,
unsigned int8 size_x, unsigned int8 size_y){
unsigned int8 px_y;
unsigned int8 px_x;
unsigned int8 px=0;
for(px_y=y; px_y<(y+size_y); px_y++){
for(px_x=x; px_x<(x+size_x); px_x+=8){
glcd_pixel8(px_x, px_y, *(pic_px+px));
px+=1;
240*64dots full image data for using Bitmap2LCD.exe(Basic Edition V1.5b) from a Bitmap file.
ƒf[ƒ^ƒTƒCƒY‚ª368ƒoƒCƒgˆÈ“à‚Ȃ̂ł»‚êˆÈã‚Ì”z—ñ‚͂ł«‚È‚¢B240ƒoƒCƒg~‚W”z—ñ‚ʼn摜ƒf[ƒ^ƒe[ƒuƒ‹‚ð\¬B
ˆÈ‰º‚̃Cƒ[ƒWƒf[ƒ^‚Íu‰t»Þ—¿‚ÌŠî–{‚ƂȂé"5CB"‚̉»ŠwŽ®v‚Å‚·B
int8 const g_image1[240]={
0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x0F , 0xFF , 0xFF , 0xC0,
0x00 , 0x00 , 0x00 , 0x00 , 0x01 , 0xFF , 0xFF , 0xF8,
0x00 , 0x00 , 0x1F , 0xFF , 0xFF , 0xE0 , 0x00 , 0x00,
0x00 , 0x00 , 0x03 , 0xFF , 0xFF , 0xFC , 0x00 , 0x00,
0x30 , 0x00 , 0x00 , 0x30 , 0x00 , 0x00 , 0x00 , 0x00,
0x06 , 0x00 , 0x00 , 0x06 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x20 , 0x00,
0x00 , 0x18 , 0x00 , 0x00 , 0x00 , 0x00 , 0x0C , 0xFF,
0xFF , 0xE7 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x60 , 0x00 , 0x00 , 0x18,
0x00 , 0x00 , 0x00 , 0x00 , 0x0C , 0x3F , 0xFF , 0xC3,
0x00 , 0x00 , 0xC8 , 0x00 , 0x00 , 0x4C , 0x00 , 0x00,
0x00 , 0x00 , 0x18 , 0x00 , 0x00 , 0x03 , 0x80 , 0x00,
int8 const g_image2[240]={
0x98 , 0x00 , 0x00 , 0x6C , 0x00 , 0x00 , 0x00 , 0x00,
0x18 , 0x00 , 0x00 , 0x01 , 0x80 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x01 , 0xB0 , 0x00,
0x00 , 0x26 , 0x00 , 0x00 , 0x00 , 0x00 , 0x30 , 0x00,
0x00 , 0x00 , 0xC0 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x03 , 0x20 , 0x00 , 0x00 , 0x36,
0x00 , 0x00 , 0x00 , 0x00 , 0x20 , 0x00 , 0x00 , 0x00,
0xA0 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x03 , 0x60 , 0x00 , 0x00 , 0x13 , 0x00 , 0x00,
0x00 , 0x00 , 0x60 , 0x00 , 0x00 , 0x00 , 0x60 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x06,
0x40 , 0x00 , 0x00 , 0x19 , 0x00 , 0x00 , 0x00 , 0x00,
0xC0 , 0x00 , 0x00 , 0x00 , 0x70 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x06 , 0xC0 , 0x00,
0x00 , 0x09 , 0x80 , 0x00 , 0x00 , 0x00 , 0x80 , 0x00,
0x00 , 0x00 , 0x30 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x0C , 0x80 , 0x00 , 0x00 , 0x0C,
0x80 , 0x00 , 0x00 , 0x01 , 0x80 , 0x00 , 0x00 , 0x00,
0x38 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x3C , 0x38 , 0x1F , 0x00 , 0x00,
0x00 , 0x1D , 0x00 , 0x00 , 0x00 , 0x04 , 0xC0 , 0x00,
0x00 , 0x03 , 0x00 , 0x00 , 0x00 , 0x00 , 0x18 , 0x00,
0x00 , 0x00 , 0x3E , 0x00 , 0x07 , 0x07 , 0x00 , 0x00
int8 const g_image3[240]={
0x00 , 0x3C , 0x38 , 0x7F , 0xC0 , 0x00 , 0x00 , 0x1B,
0x00 , 0x00 , 0x00 , 0x02 , 0x40 , 0x00 , 0x00 , 0x03,
0x00 , 0x00 , 0x00 , 0x00 , 0x0C , 0x00 , 0x00 , 0x00,
0xFF , 0x80 , 0x07 , 0x07 , 0x00 , 0x00 , 0x00 , 0x3E,
0x38 , 0xFF , 0xC0 , 0x00 , 0x00 , 0x32 , 0x00 , 0x00,
0x00 , 0x03 , 0x60 , 0x00 , 0x00 , 0x06 , 0x00 , 0x00,
0x00 , 0x00 , 0x0E , 0x00 , 0x00 , 0x01 , 0xFF , 0x80,
0x07 , 0x07 , 0x00 , 0x00 , 0x00 , 0x3E , 0x38 , 0xE1,
0xE0 , 0x00 , 0x00 , 0x76 , 0x00 , 0x00 , 0x00 , 0x01,
0x30 , 0x00 , 0x00 , 0x0E , 0x00 , 0x00 , 0x00 , 0x00,
0x06 , 0x00 , 0x00 , 0x01 , 0xC3 , 0xC0 , 0x07 , 0x07,
0x00 , 0x00 , 0x00 , 0x3F , 0x39 , 0xC0 , 0xC0 , 0x00,
0x00 , 0x64 , 0x00 , 0x00 , 0x00 , 0x01 , 0xB0 , 0x00,
0x00 , 0x1C , 0x00 , 0x00 , 0x00 , 0x00 , 0x07 , 0x00,
0x00 , 0x03 , 0x81 , 0x80 , 0x07 , 0x07 , 0x00 , 0x00,
0x00 , 0x3B , 0x39 , 0xC0 , 0x00 , 0x00 , 0x00 , 0xEC,
0x00 , 0x00 , 0x00 , 0x00 , 0x98 , 0x00 , 0x00 , 0x18,
0x00 , 0x00 , 0x00 , 0x00 , 0x03 , 0x00 , 0x00 , 0x03,
0x80 , 0x00 , 0x07 , 0xFF , 0x00 , 0x00 , 0x00 , 0x3B,
0xB9 , 0xC0 , 0x0F , 0xFF , 0xFF , 0xC8 , 0x00 , 0x00,
0x00 , 0x00 , 0xCF , 0xFF , 0xFF , 0xF8 , 0x00 , 0x00,
0x00 , 0x00 , 0x01 , 0xFF , 0xFF , 0xFB , 0x80 , 0x03,
0xC7 , 0xFF , 0x0C , 0x30 , 0x00 , 0x39 , 0xB9 , 0xC0,
0x0F , 0xFF , 0xFF , 0xC0 , 0x00 , 0x00 , 0x00 , 0x00,
0x4F , 0xFF , 0xFF , 0xF0 , 0x00 , 0x00 , 0x00 , 0x00,
0x01 , 0xFF , 0xFF , 0xFB , 0x80 , 0x03 , 0x07 , 0xFF,
0x1C , 0x70 , 0x00 , 0x39 , 0xF9 , 0xC0 , 0x00 , 0x00,
0x00 , 0xC0 , 0x00 , 0x00 , 0x00 , 0x00 , 0x0C , 0x00,
0x00 , 0x3B , 0x00 , 0x00 , 0x00 , 0x00 , 0x09 , 0x80,
0x00 , 0x03 , 0x80 , 0x06 , 0x07 , 0x07 , 0x3C , 0xF0
int8 const g_image4[240]={
0x00 , 0x38 , 0xF9 , 0xC0 , 0xC0 , 0x00 , 0x00 , 0x60,
0x00 , 0x00 , 0x00 , 0x00 , 0x1C , 0x00 , 0x00 , 0x19,
0x80 , 0x00 , 0x00 , 0x00 , 0x1B , 0x00 , 0x00 , 0x03,
0x81 , 0x87 , 0x87 , 0x07 , 0x2C , 0xB0 , 0x00 , 0x38,
0xF8 , 0xE1 , 0xE0 , 0x00 , 0x00 , 0x60 , 0x00 , 0x00,
0x00 , 0x00 , 0x18 , 0x00 , 0x00 , 0x0D , 0x80 , 0x00,
0x00 , 0x00 , 0x33 , 0x00 , 0x00 , 0x01 , 0xC3 , 0xC4,
0xC7 , 0x07 , 0x0C , 0x30 , 0x00 , 0x38 , 0x78 , 0xFF,
0xC0 , 0x00 , 0x00 , 0x30 , 0x00 , 0x00 , 0x00 , 0x00,
0x38 , 0x00 , 0x00 , 0x0C , 0xC0 , 0x00 , 0x00 , 0x00,
0x66 , 0x00 , 0x00 , 0x01 , 0xFF , 0x80 , 0xC7 , 0x07,
0x0C , 0x30 , 0x00 , 0x38 , 0x78 , 0x7F , 0xC0 , 0x00,
0x00 , 0x30 , 0x00 , 0x00 , 0x00 , 0x00 , 0x30 , 0x00,
0x00 , 0x06 , 0xC0 , 0x00 , 0x00 , 0x00 , 0x4E , 0x00,
0x00 , 0x00 , 0xFF , 0x86 , 0xC7 , 0x07 , 0x0C , 0x30,
0x00 , 0x38 , 0x38 , 0x1F , 0x00 , 0x00 , 0x00 , 0x18,
0x00 , 0x00 , 0x00 , 0x00 , 0x60 , 0x00 , 0x00 , 0x02,
0x60 , 0x00 , 0x00 , 0x00 , 0xCC , 0x00 , 0x00 , 0x00,
0x3E , 0x03 , 0x87 , 0x07 , 0x0C , 0x30 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x0C , 0x00 , 0x00,
0x00 , 0x00 , 0xE0 , 0x00 , 0x00 , 0x03 , 0x20 , 0x00,
0x00 , 0x01 , 0x98 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x0C , 0x00 , 0x00 , 0x00 , 0x00,
0xC0 , 0x00 , 0x00 , 0x01 , 0xB0 , 0x00 , 0x00 , 0x01,
0xB8 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x06 , 0x00 , 0x00 , 0x00 , 0x01 , 0xC0 , 0x00,
0x00 , 0x00 , 0x98 , 0x00 , 0x00 , 0x03 , 0x30 , 0x00,
int8 const g_image5[240]={
0x00 , 0x00 , 0x00 , 0x01 , 0x80 , 0x00 , 0x00 , 0x00,
0xD8 , 0x00 , 0x00 , 0x03 , 0x60 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x03 , 0x00 , 0x00,
0x00 , 0x03 , 0x00 , 0x00 , 0x00 , 0x00 , 0x6C , 0x00,
0x00 , 0x06 , 0x60 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x03 , 0x00 , 0x00 , 0x00 , 0x03,
0x00 , 0x00 , 0x00 , 0x00 , 0x24 , 0x00 , 0x00 , 0x06,
0xC0 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x01 , 0x80 , 0x00 , 0x00 , 0x06 , 0x00 , 0x00,
0x00 , 0x00 , 0x36 , 0x00 , 0x00 , 0x0C , 0xC0 , 0x00,
0xC0 , 0x00 , 0x00 , 0x0C , 0x00 , 0x00 , 0x00 , 0x00,
0x12 , 0x00 , 0x00 , 0x09 , 0x80 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0xC0 , 0x00,
0x00 , 0x0C , 0x00 , 0x00 , 0x00 , 0x00 , 0x09 , 0x00,
0x00 , 0x19 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x63 , 0xFF , 0xFE , 0x18,
0x00 , 0x00 , 0x00 , 0x00 , 0x0D , 0x00 , 0x00 , 0x13,
0x00 , 0x00 , 0x67 , 0xFF , 0xFF , 0x18 , 0x00 , 0x00,
0x00 , 0x00 , 0x04 , 0x00 , 0x00 , 0x06 , 0x00 , 0x00,
int8 const g_image6[240]={
0x07 , 0xFF , 0xFF , 0xFE , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x1F , 0xFF,
0xFF , 0xE0 , 0x00 , 0x00 , 0x00 , 0x00 , 0x03 , 0xFF,
0xFF , 0xFC , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
0x00 , 0x00 , 0x00 , 0x00 , 0x1F , 0xFF , 0xFF , 0xC0,
0x00 , 0x00 , 0x00 , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF,
0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF,
0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0x00
int8 const g_image7[240]={
0x00 , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF,
0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0x00 , 0x00 , 0xF8,
0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xE3,
0xFF , 0xFC , 0x79 , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF,
0xFF , 0xFF , 0xF1 , 0xFE , 0x7F , 0xF8 , 0xFF , 0xFF,
0xFF , 0xFF , 0xF1 , 0x00 , 0x00 , 0xF0 , 0xFF , 0xFF,
0xFF , 0xFF , 0xFF , 0xE7 , 0xFF , 0xF3 , 0xFF , 0xF8,
0x79 , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF,
0xF9 , 0xFE , 0x7F , 0xFC , 0xFF , 0xFF , 0xFF , 0xFF,
0xF9 , 0x00 , 0x00 , 0xF0 , 0xFF , 0xFF , 0xFF , 0xFF,
0xFF , 0xE7 , 0xFF , 0xF3 , 0xFF , 0xF8 , 0x79 , 0xFF,
0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xF9 , 0xFF,
0xFF , 0xFC , 0xFF , 0xFF , 0xFF , 0xFF , 0xF9 , 0x00,
0x00 , 0xE4 , 0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xE7,
0xFF , 0xF3 , 0xFF , 0xF2 , 0x7F , 0xFF , 0xFF , 0xFF,
0xFF , 0xFF , 0xFF , 0xFF , 0xF9 , 0xFF , 0xFF , 0xFC,
0xFF , 0xFF , 0xFF , 0xFF , 0xF9 , 0x00 , 0x00 , 0xE4,
0xFF , 0xF8 , 0x0F , 0x87 , 0x01 , 0x81 , 0x0C , 0x33,
0xFF , 0xF2 , 0x7F , 0xFF , 0xFC , 0x00 , 0xC3 , 0x07,
0x01 , 0xF0 , 0x78 , 0x1C , 0x60 , 0x3C , 0x0F , 0x87,
0x01 , 0x86 , 0x19 , 0x00 , 0x00 , 0xCC , 0xE0 , 0x1C,
0x67 , 0x33 , 0x8C , 0xE7 , 0x9E , 0x73 , 0x00 , 0xE6,
0x7F , 0xC0 , 0x39 , 0x89 , 0xE6 , 0x73 , 0x8C , 0xE7,
0x38 , 0xCE , 0x71 , 0x9C , 0x67 , 0x33 , 0x8C , 0xCF,
0x39 , 0x00 , 0x00 , 0xCC , 0xFF , 0xFC , 0xF2 , 0x79,
0x9C , 0xE7 , 0xCC , 0xF3 , 0xFF , 0xE6 , 0x7F , 0xFF,
0xF3 , 0xCC , 0xCF , 0xF3 , 0x9C , 0xCF , 0x99 , 0xE6,
0x73 , 0xCC , 0xE6 , 0x79 , 0x9C , 0xE6 , 0x79 , 0x00
int8 const g_image8[240]={
0x00 , 0x9C , 0xFF , 0xFC , 0xF2 , 0x01 , 0x9C , 0xE7,
0xCC , 0xF3 , 0xFF , 0xCE , 0x7F , 0xFF , 0xF3 , 0xFC,
0xCF , 0xC3 , 0x9C , 0xCF , 0x99 , 0xE6 , 0x73 , 0xCC,
0xE6 , 0x01 , 0x9C , 0xE6 , 0x79 , 0x00 , 0x00 , 0x80,
0x3F , 0xFC , 0xF2 , 0x7F , 0x9C , 0xE7 , 0xE1 , 0xF3,
0xFF , 0xC0 , 0x1F , 0xFF , 0xF3 , 0xFE , 0x1F , 0x13,
0x9C , 0xCF , 0x99 , 0xE6 , 0x73 , 0xCC , 0xE6 , 0x7F,
0x9C , 0xF0 , 0xF9 , 0x00 , 0x00 , 0xFC , 0xFF , 0xFC,
0xF2 , 0x7F , 0x9C , 0xE7 , 0xE1 , 0xF3 , 0xFF , 0xFE,
0x7F , 0xFF , 0xF3 , 0xFE , 0x1E , 0x73 , 0x9C , 0xCF,
0x99 , 0xE6 , 0x73 , 0xCC , 0xE6 , 0x7F , 0x9C , 0xF0,
0xF9 , 0x00 , 0x00 , 0xFC , 0xFF , 0xFC , 0x67 , 0x39,
0x9C , 0xE4 , 0xF3 , 0xF3 , 0xFF , 0xFE , 0x7F , 0xFF,
0xF9 , 0xCF , 0x3E , 0x63 , 0x9C , 0xE7 , 0x38 , 0xCE,
0x71 , 0x9C , 0xE7 , 0x39 , 0x9C , 0xF9 , 0xF9 , 0x00,
0x00 , 0xF0 , 0x3F , 0xFC , 0x0F , 0x83 , 0x08 , 0x71,
0xF3 , 0xE1 , 0xFF , 0xF8 , 0x1F , 0xFF , 0xFC , 0x1F,
0x3F , 0x01 , 0x08 , 0x70 , 0x78 , 0x1C , 0x30 , 0x38,
0x43 , 0x83 , 0x08 , 0x79 , 0xF0 , 0x00 , 0x00 , 0xFF,
0xFF , 0xFC , 0xFF , 0xFF , 0xFF , 0xFF , 0x07 , 0xFF,
0xFF , 0xFF , 0xFF , 0xFF , 0xFF , 0xF0 , 0x7F , 0xFF,
0xFF , 0xFF , 0xFF , 0xFF , 0xF3 , 0xFF , 0xFF , 0xFF,
0xFF , 0x83 , 0xFF , 0x00 , 0x00 , 0xFF , 0xFF , 0xF8,
0x7F , 0xFF , 0xFF , 0xFF , 0x8F , 0xFF , 0xFF , 0xFF,
0xFF , 0xFF , 0xFF , 0xF8 , 0xFF , 0xFF , 0xFF , 0xFF,
0xFF , 0xFF , 0xE1 , 0xFF , 0xFF , 0xFF , 0xFF , 0xC7,
0xFF , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
void image_drawing(void) // Free image file drawing
int n;
for (n=0; n<240 ; n++) //ÅãˆÊ‚Ì240*64dots•ª‚ð•`‰æ
glcd_WriteCmd1(g_image1[n],0xc0); //Write data and increament(TSXBINƒf[ƒ^‚ªƒ|ƒWƒlƒK‹t“]¨ƒf[ƒ^‚ð•â”j
}n=0;
for (n=0; n<240 ; n++) //2’i–Ú•`‰æ
glcd_WriteCmd1(g_image2[n],0xc0);
}n=0;
for (n=0; n<240 ; n++) //3’i–Ú•`
glcd_WriteCmd1(g_image3[n],0xc0);
}n=0;
for (n=0; n<240 ; n++) //4’i–Ú•`‰æ
glcd_WriteCmd1(g_image4[n],0xc0);
}n=0;
for (n=0; n<240 ; n++) //5’i–Ú•`‰æ
glcd_WriteCmd1(g_image5[n],0xc0);
}n=0;
for (n=0; n<240 ; n++) //6’i–Ú•`‰æ
glcd_WriteCmd1(g_image6[n],0xc0);
}n=0;
for (n=0; n<240 ; n++) //7’i–Ú•`‰æ
glcd_WriteCmd1(g_image7[n],0xc0);
}n=0;
for (n=0; n<240 ; n++) //8’i–Ú•`‰æ
glcd_WriteCmd1(g_image8[n],0xc0);
//// Defines a 5x7 font
const int8 FONT[51][5] ={0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
0x00, 0x00, 0x5F, 0x00, 0x00, // !
0x00, 0x03, 0x00, 0x03, 0x00, // "
0x14, 0x3E, 0x14, 0x3E, 0x14, // #
0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
0x43, 0x33, 0x08, 0x66, 0x61, // %
0x36, 0x49, 0x55, 0x22, 0x50, // &
0x00, 0x05, 0x03, 0x00, 0x00, // '
0x00, 0x1C, 0x22, 0x41, 0x00, // (
0x00, 0x41, 0x22, 0x1C, 0x00, // )
0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x50, 0x30, 0x00, 0x00, // ,
0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x60, 0x60, 0x00, 0x00, // .
0x20, 0x10, 0x08, 0x04, 0x02, // /
0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x00, 0x04, 0x02, 0x7F, 0x00, // 1
0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x22, 0x41, 0x49, 0x49, 0x36, // 3
0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x3E, 0x49, 0x49, 0x49, 0x32, // 6
0x01, 0x01, 0x71, 0x09, 0x07, // 7
0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x26, 0x49, 0x49, 0x49, 0x3E, // 9
0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x56, 0x36, 0x00, 0x00, // ;
0x08, 0x14, 0x22, 0x41, 0x00, // <
0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x41, 0x22, 0x14, 0x08, // >
0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x3E, 0x41, 0x59, 0x55, 0x5E, // @
0x7E, 0x09, 0x09, 0x09, 0x7E, // A
0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x7F, 0x41, 0x41, 0x41, 0x3E, // D
0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x3E, 0x41, 0x41, 0x49, 0x3A, // G
0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x30, 0x40, 0x40, 0x40, 0x3F, // J
0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x7F, 0x02, 0x04, 0x08, 0x7F, // N
0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
0x7F, 0x09, 0x09, 0x09, 0x76};// R
const int8 FONT2[44][5]={0x26, 0x49, 0x49, 0x49, 0x32, // S
0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x7F, 0x20, 0x10, 0x20, 0x7F, // W
0x41, 0x22, 0x1C, 0x22, 0x41, // X
0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x7F, 0x41, 0x00, 0x00, // [
0x02, 0x04, 0x08, 0x10, 0x20, // \
0x00, 0x00, 0x41, 0x7F, 0x00, // ]
0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x01, 0x02, 0x04, 0x00, // `
0x20, 0x54, 0x54, 0x54, 0x78, // a
0x7F, 0x44, 0x44, 0x44, 0x38, // b
0x38, 0x44, 0x44, 0x44, 0x44, // c
0x38, 0x44, 0x44, 0x44, 0x7F, // d
0x38, 0x54, 0x54, 0x54, 0x18, // e
0x04, 0x04, 0x7E, 0x05, 0x05, // f
0x08, 0x54, 0x54, 0x54, 0x3C, // g
0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x20, 0x40, 0x44, 0x3D, 0x00, // j
0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x7C, 0x04, 0x78, 0x04, 0x78, // m
0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x38, 0x44, 0x44, 0x44, 0x38, // o
0x7C, 0x14, 0x14, 0x14, 0x08, // p
0x08, 0x14, 0x14, 0x14, 0x7C, // q
0x00, 0x7C, 0x08, 0x04, 0x04, // r
0x48, 0x54, 0x54, 0x54, 0x20, // s
0x04, 0x04, 0x3F, 0x44, 0x44, // t
0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x44, 0x28, 0x10, 0x28, 0x44, // x
0x0C, 0x50, 0x50, 0x50, 0x3C, // y
0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x00, 0x08, 0x36, 0x41, 0x41, // {
0x00, 0x00, 0x7F, 0x00, 0x00, // |
0x41, 0x41, 0x36, 0x08, 0x00, // }
0x02, 0x01, 0x02, 0x04, 0x02};// ~
void glcd_text57(int16 x, int16 y, char* textptr, int8 size, int1 color)
int8 j, k, l, m; // Loop counters
int8 pixelData[5]; // Stores character data
for(; *textptr != '\0'; ++textptr, ++x)// Loop through the passed string
if(*textptr < 'S') // Checks if the letter is in the first font array
memcpy(pixelData, FONT[*textptr - ' '], 5);
else if(*textptr <= '~') // Check if the letter is in the second font array
memcpy(pixelData, FONT2[*textptr - 'S'], 5);
memcpy(pixelData, FONT[0], 5); // Default to space
// Handles newline and carriage returns
switch(*textptr)
case '\n':
y += 7*size + 1;
continue;
case '\r':
x = 0;
continue;
if(x+5*size >= 240) // Performs character wrapping
x = 0; // Set x at far left position
y += 7*size + 1; // Set y at next position down
for(j=0; j<5; ++j, x+=size) // Loop through character byte data
for(k=0; k < 7; ++k) // Loop through the vertical pixels
if(bit_test(pixelData[j], k)) // Check if the pixel should be set
for(l=0; l < size; ++l) // These two loops change the
{ // character's size
for(m=0; m < size; ++m)
glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
// Purpose: Draw a bar (wide line) on a graphic LCD
// Inputs: (x1, y1) - the start coordinate
// (x2, y2) - the end coordinate
// width - The number of pixels wide
// color - ON or OFF
void glcd_bar(int x1, int y1, int x2, int y2, int width, int1 color)
signed int x, y, addx, addy, j;
signed long P, dx, dy, c1, c2;
int i;
dx = abs((signed int)(x2 - x1));
dy = abs((signed int)(y2 - y1));
x = x1;
y = y1;
c1 = -dx*x1 - dy*y1;
c2 = -dx*x2 - dy*y2;
if(x1 > x2)
addx = -1;
c1 = -dx*x2 - dy*y2;
c2 = -dx*x1 - dy*y1;
addx = 1;
if(y1 > y2)
addy = -1;
addy = 1;
if(dx >= dy)
P = 2*dy - dx;
for(i=0; i<=dx; ++i)
for(j=-(width/2); j<width/2+width%2; ++j)
if(dx*x+dy*(y+j)+c1 >= 0 && dx*x+dy*(y+j)+c2 <=0)
glcd_pixel(x, y+j, color);
if(P < 0)
P += 2*dy;
x += addx;
P += 2*dy - 2*dx;
x += addx;
y += addy;
P = 2*dx - dy;
for(i=0; i<=dy; ++i)
if(P < 0)
P += 2*dx;
y += addy;
P += 2*dx - 2*dy;
x += addx;
y += addy;
glcd_pixel(x+j, y, color);
// Purpose: Draw a circle on a graphic LCD
// Inputs: (x,y) - the center of the circle
// radius - the radius of the circle
// fill - YES or NO
void glcd_circle(int x, int y, int radius, int1 fill, int1 color)
signed int a, b, P;
a = 0;
b = radius;
P = 1 - radius;
do
if(fill)
glcd_line(x-a, y+b, x+a, y+b, color);
glcd_line(x-a, y-b, x+a, y-b, color);
glcd_line(x-b, y+a, x+b, y+a, color);
glcd_line(x-b, y-a, x+b, y-a, color);
glcd_pixel(a+x, b+y, color);
glcd_pixel(b+x, a+y, color);
glcd_pixel(x-a, b+y, color);
glcd_pixel(x-b, a+y, color);
glcd_pixel(b+x, y-a, color);
glcd_pixel(a+x, y-b, color);
glcd_pixel(x-a, y-b, color);
glcd_pixel(x-b, y-a, color);
if(P < 0)
P+= 3 + 2*a++;
P+= 5 + 2*(a++ - b--);
} while(a <= b);
// @brief Draws a segment of a circle
// @param x, y: center
// radius
// Startwinkel, Endwinkel. 0=unten, 90 = rechts
// Set show1 to 1 to draw pixel, set to 0 to hide pixel.
// @return none
void glcd_circle_segment(int x, int y, int radius, int winkel_start, int winkel_end, unsigned char show)
int x_kreis, y_kreis;
float winkel;
#define DEGREE 2*3.14159265/360
for (winkel = (float)winkel_start; winkel <= winkel_end; winkel += .9)
x_kreis = (int) (sin (winkel * DEGREE) * radius);
y_kreis = (int) (cos (winkel * DEGREE) * radius);
glcd_pixel(x + x_kreis, y + y_kreis, show);
@brief Draws a circle
In Anlehnung an Bresenham (http://groups.google.de/group/maus.mathe/browse_thread/thread/8a44a51d3f43c23d/ oder
http://groups.google.de/group/maus.lang.tpascal/browse_thread/thread/38f9e6d81de037f4/) wird nur 1/4 Kreis berechnet und
die anderen 3/4 gespiegelt => schnell, da ohne floats
@param x, y: center
radius
@return none
void glcd_Losange(int x, int y, int radius, unsigned char show)
int xc = 0;
int yc ;
int p ;
yc=radius;
p = 3 - (radius<<1);
while (xc <= yc)
glcd_pixel(x + xc, y + yc, show);
glcd_pixel(x + xc, y - yc, show);
glcd_pixel(x - xc, y + yc, show);
glcd_pixel(x - xc, y - yc, show);
glcd_pixel(x + yc, y + xc, show);
glcd_pixel(x + yc, y - xc, show);
glcd_pixel(x - yc, y + xc, show);
glcd_pixel(x - yc, y - xc, show);
if (p < 0)
p += (xc++ << 2) + 6;
p += ((xc++ - yc--)<<2) + 10;
void glcd_Losange_half(int x, int y, int radius, unsigned char show)
int xc = 0;
int yc ;
int p ;
yc=radius;
while (xc <= yc)
// glcd_pixel(x + xc, y + yc, show);
// glcd_pixel(x - xc, y + yc, show);
// glcd_pixel(x + yc, y + xc, show);
// glcd_pixel(x - yc, y + xc, show);
if (p < 0)
