Internal Oscillator 12F615
billy
PostPosted: Sun Aug 18, 2013 11:13 pm     Reply with quote
Good day,
I am new with the software and a student. Embarassed I need some advice on the setup of the internal oscillator. How do I know if the internal oscillator are running when using the PIC12F615? I have done the setup, but it seems that my processor is not running.
See my code:
#include <12F615.h>
#device adc=10
#FUSES IOSC8 //INTOSC speed 8 MHz
#use delay(clock=8000000)
setup_adc_ports(sAN3|VSS_Vref);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_16,255,1);
Hope somebody can assist me.
Billy.
stinky
PostPosted: Sun Aug 18, 2013 11:46 pm     Reply with quote
How do you know it's not working?
billy
PostPosted: Mon Aug 19, 2013 12:44 am     Reply with quote
Stinky,
My code is quite simple. made an output high for LED. After programming the pic, put in my development board. LED is not on when powering up.
If I simulate the program in proteus, the program is working.
PostPosted: Mon Aug 19, 2013 1:12 am     Reply with quote
The point is that what you post does not show the LED code.
Anyway some comments inline:
#include <12F615.h>
#device adc=10
#define LED PIN_xx //Select to suit your LED
   //Read the data sheet. Is this a legal ADC clock at this CPU clock....
   do
      output_toggle(LED);
   } while (TRUE);
//This shows flashing an LED
//Things that would stop it working:
//1) Choosing pin A3 for the LED - this is _input only_.
//2) Not having a suitable current limiting resistor on the LED
//If the LED is wired directly, it'll short out the PIC, odds are it'll reset
//and nothing will apparently happen.
//3) Choosing pin A4 for the LED. This is AN3, which you are setting
//as an analog input.
Read the inline comments.
