Can't write and read eeprom with address larger 512
tienchuan
PostPosted: Wed Jul 31, 2013 7:01 am     Reply with quote
Hi all.
I'm have a problem when try to write and read again with address large 512
( i'm using Serial EEPROM AT24C04A 4KB, interface I2C of ATMEL). The results output terminal are failed.
In my project i'm using driver for this EEPROM (2404.c) to control it, and
PIC18F4680
CCS C ver 4.140, and there is code:
   for(i=0;i<=20;i++)
      write_ext_eeprom(i+512,'K');
   for(i=0;i<=20;i++)
      putc(read_ext_eeprom(i+512));
In this driver ( 2404.c) of CCS C, I find this define
#define EEPROM_SIZE    512
but it never used for this driver?
Pls show me way to solve this problem?
Thanks.
Begin Begin Begin !!!
drh
PostPosted: Wed Jul 31, 2013 8:27 am     Reply with quote
That should be 4Kb (bits), not 4KB (bytes). That part will hold 512 bytes. Read the data sheet.
David
PostPosted: Wed Jul 31, 2013 9:33 am     Reply with quote
First sentence in the datasheet:
The AT24C02A/04A provides 2048/4096 bits of serial electrically
erasable and programmable read-only memory (EEPROM)
organized as 256/512 words of 8 bits each
tienchuan
PostPosted: Tue Aug 06, 2013 8:39 pm     Reply with quote
In driver for this EEPROM ( AT24C04) of CCS C (ver 4.140)
void write_ext_eeprom(long int address, BYTE data) {
   while(!ext_eeprom_ready());
   i2c_start();
   i2c_write((0xa0|(BYTE)(address>>7))&0xfe);
   i2c_write(address);
   i2c_write(data);
   i2c_stop();
I don't known why
pls show me it?
thanks
oxo
PostPosted: Wed Aug 07, 2013 1:11 am     Reply with quote
pls show me it?
thanks
It's the device address and the R/W bit. Figure 10 in the datasheet
PostPosted: Wed Aug 07, 2013 2:14 am     Reply with quote
On the 'EEPROM_SIZE' define, this is available for _you_ to use. All the EEPROM drivers #define this, so that you can write your code to be 'generic', and for instance loop through the whole EEPROM, with:
for (count=0;count<EEPROM_SIZE, count++)
etc..
For whichever EEPROM you have selected.
It is just like the 'limits'h' defines, for maths, where there are the sizes of each type of variable etc., defined.
