ocnarf
| USART PIC16F873 |
Posted: Sun Jul 28, 2013 6:29 pm |
I want to communicate two pics using USART. The code is quite simple but it doesn't work. I think the problem is in the configuration.
The receiver PIC should show in a LCD.
The simulation works perfect but in the real life it doesn't happen.
please help. (Sorry for my english)
The transmitter code is:
| Code: | #include <16F873.h>
#include "C:\GSM\EjemploLibro\LCDTx.c"
#device adc=8
#FUSES XT //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES RESERVED //Used to set the reserved FUSE bits
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
int valor;
lcd_init();
while(1){
for (valor=0;valor<=10;valor++) {
putc(valor);
printf(lcd_putc,"\fEnviando=%1d",valor);
The receiver code is:
#include "C:\GSM\EjemploLibro\LCDRx.c"
#device adc=8
#BYTE TRISA=0X85
#BYTE PORTA=0X05
int valor;
#int_RDA
void RDA_isr(void)
valor=getc();
enable_interrupts(INT_RDA);
bit_clear(TRISA,0);
lcd_init();
enable_interrupts(int_RDA);
for(;;) {
lcd_gotoxy(1,1);
printf(lcd_putc,"Recibiendo=%1d",valor);
Joined: 01 Jul 2010 Posts: 9624 Location: Greensville,Ontario
Posted: Sun Jul 28, 2013 6:49 pm |
Some comments
1) LCDs take time to 'initialize'. Normally I delay 500ms before and after doing the LCD_init() function. The first delay allows the LCD module to stabilize and init to 8 bit mode, the second,allows it time to reconfigure to 4bit mode before you send any data to display. Some LCD modules may react faster but ,heck, I can wait 1 second to be sure it's OK.
2) Why do you do this ?
bit_clear(TRISA,0);
What is the purpose? It's not necessary in normal CCS C.
3) Do you have MAX232 type devices between the PICs?
4) The 'numbers' 0-9 in your transmit program are really 'control characters' and not displayable numbers.'7' is aka 'bell','8' is 'backspace'.
Try using 48-57 ( 1-9) or 65-74(A-J).
hth
jay |
ocnarf
Posted: Sun Jul 28, 2013 8:17 pm |
Hi Temtronic,
1) The LCD works well, I can read:
"Recibiendo=0"
But the number doesnt increase. The simulation does increase.
2) I really dont know why the line:
bit_clear(TRISA,0);
I copied the program from a book and I really dont understand that line.
3) I dont have MAX232, I direct connect Tx-Rx.
4) If I put valor++; nothing change, still doesnt work.
Thanks.. |
asmboy
Posted: Mon Jul 29, 2013 8:08 pm |
| Quote: |
this is not a real circuit is it ?
it is a simulation which proves NOTHING !!!
proteus /isis right ?
huge waste of time |
Sergeant82d
Joined: 01 Nov 2009 Posts: 55 Location: Central Oklahoma
| Re: USART PIC16F873 |
Posted: Mon Jul 29, 2013 11:06 pm |
| ocnarf wrote: |
The simulation works perfect but in the real life it doesnt happen.
| asmboy wrote: |
He appears to be doing both a simulation and a real circuit. Very helpful at times, regardless of how poorly most "commercial" simulations (proteus/isis) perform. |
Posted: Tue Jul 30, 2013 4:54 am |
Back to the basics:
- ALWAYS post your compiler version number. It might be you are using an old compiler version where this problem has long been solved.
- | Code: | | setup_spi(SPI_SS_DISABLED); | This is a wrong line from the CCS Code Wizard and creates an invalid configuration with unknown side effects. Correct is:Fix this in both your master and slave program.
| Quote: | bit_clear(TRISA,0);
I copied the program from a book and I really dont understand that line. |
Get rid of this line, it is not needed.
Then also remove these lines: | Code: | #BYTE TRISA=0X85
#BYTE PORTA=0X05 |
Declare variables directly at the function start, that is directly after the '{' character. Now you have it in the middle of your program and sometimes the CCS compiler has problems with this. Try to stick with traditional old style C programming to create less problems for yourself.
| Quote: |
3) I dont have MAX232, I direct connect Tx-Rx. | For a quick test project this is possible, but keep your connecting wires short. 1 - 2 meter maximum at 9600 baud.
| Quote: | | 4) If I put valor++; nothing change, still doesnt work. | That is not what Jay told you to do. The problem is in that the values below 32 have special meanings. We don't know the details of your display, but you are having a lot of potential failure risks here: just imagine there is a control code for sending the LCD to sleep mode. Read Jay's post again and use one of the ranges he recommends. It is only a tiny change to your original program.
One other improvement to your program: ALWAYS add 'ERRORS' to your #use rs232 lines. This will make the CCS compiler to add error clearing code for the UART. Without this the UART will stop working on receiver buffer overflow (that is just after 3 characters without reading the UART fast enough).
Make the changes to your program and post the new versions here. |
ocnarf
Posted: Wed Jul 31, 2013 5:04 pm |
Now its working. The problem was the LCD in the transmitter program. Physically I didn't put the LCD and the PIC crashed.
Thanks everyone. |
