wdt in PIC
z3ngew
wdt in PIC
PostPosted: Thu May 16, 2013 3:05 pm     Reply with quote
Hello everyone,
Can watch dog timer which is implemented in the pic hardware be used as a regular timer, and if yes, please provide code snippet if possible?
Thanks in advance,
z3ngew
Gabriel
PostPosted: Thu May 16, 2013 3:10 pm     Reply with quote
why not just use a regular timer? 0,1,2,3,... depending on pic..
CCS PCM 5.078 & CCS PCH 5.093
z3ngew
PostPosted: Thu May 16, 2013 3:18 pm     Reply with quote
well, i am planning to use the other timers to make an interrupt multitasking system that will enable me to operate more that one RC servo motor at the same time, but not with the same behavior, so i was wondering if wdt can be used like regular timer, it would be helpful for me,
thanks, Smile
PostPosted: Thu May 16, 2013 3:25 pm     Reply with quote
Watchdog timer capabilities vary widely, depending on the PIC. Always
post your PIC.
z3ngew
PostPosted: Thu May 16, 2013 3:30 pm     Reply with quote
I'm using PIC18F452
newguy
PostPosted: Thu May 16, 2013 3:31 pm     Reply with quote
The biggest problem with the watchdog is that it isn't a precise timing source.
The second is that a watchdog expiry causes a processor reset. Relying on that is very poor coding practice.
asmboy
PostPosted: Thu May 16, 2013 4:52 pm     Reply with quote
rc pulse position servos right ??
Unless you are doing something that requires sub usec control
one timer, a 16 mhz crystal and some clever code ought to do the trick.
have you searched HERE using
RC servo
as the search term ???
PostPosted: Thu May 16, 2013 5:24 pm     Reply with quote
Even the 'ancient' 16C84 can handle 8 'rc servos' and a serial interface at 9600 baud.
