interrupt int_rda not working
Jasen
PostPosted: Sat Mar 23, 2013 2:23 pm     Reply with quote
I create a simply program to test rda interrupt, but for some reason the interrupt is not working. When send a TX data expect a message back “Interrupt in execution”, but no message is send back. Look at the program below.
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#int_rda
void serial_isr(){
printf("interrupt in execution");
getc();
Main{
Enable_interrupt (Global);
Enable_interrupt (int_rda);}
When(true){
jayanthd
Re: interrupt int_rda not working
PostPosted: Sat Mar 23, 2013 3:15 pm     Reply with quote
How are you sending data to UART? Only if you send some data like say 'A' serial interrupt occurs and printf is executed.
Mike Walne
PostPosted: Sat Mar 23, 2013 3:23 pm     Reply with quote
Several things:-
1) Can you get an LED flasher to work?
2) Add errors to your #use RS232.
3) Where does your code go after the enable rda interrrupt?
4) Does your code ever reach the when statement?
5) Is "when" a valid 'C' word?
6) Have you carefully examined your {} brackets?
7) Does your code compile without errors?
8) Printing inside an ISR is a VERY bad idea.
9) Is this real or simulation?
10) .......................
Mike
PostPosted: Sat Mar 23, 2013 4:11 pm     Reply with quote
Try a more simple #int_rda test program like this one:
http://www.ccsinfo.com/forum/viewtopic.php?t=37380&start=3
Notice it has the ERRORS parameter in #use rs232() and it only sends
one character in #int_rda. It quickly gets out of the interrupt routine.
PostPosted: Sun Mar 24, 2013 1:34 am     Reply with quote
Keyword for a loop is 'while', not 'when'....
So code as posted will not compile.
Mike Walne
PostPosted: Sun Mar 24, 2013 4:25 am     Reply with quote
There several reasons why your code won't compile.
My advice on {} brackets (for what it's worth).
Always locate each closing } directly below its opening { with clear space between.
That way you can more easily see your code structure.
Your code now becomes:-
#include <16F877.h>
#int_rda
void serial_isr()
   getc();
Main
When(true)
It should now be obvious what's wrong with the structure.
I've not altered the sense of your code.
The only editing I've done is to manipulate white space and linefeeds.
It still won't either compile or work for the reasons that were there before.
The compiler complains about things it can't handle, and effectively tells you where to look for errors.
Mike
