Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
PIC24FJ256DA206 short circuit after trying to program
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
muiratinas
PostPosted: Mon Jan 14, 2013 9:32 am     Reply with quote
I'm trying to do a project with PIC24FJ256DA206.
I have a simple PCB to just ICSP programming needs and all others are reserved for future use pins.
(http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Dev/Android/IOIO-v15.pdf)
When i connect to my Load-n-Go, trying to detect my PIC, it gives error, then when i test short circuit test, it gives fault between VDD and VSS pins.
After 4-5 hours later, the circuit turns normal open circuit.
And if i try to program chip, again it gives an error and turns to short circuit.
I tried it with 3 board and pic additionaly.
What am i doing wrong?
(And extra note; In scheme, i'm not soldering usb side of the pcb)
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
