Re: Where to get PIC16F876 for Protel Schematic?
June
PostPosted: Wed Dec 11, 2002 11:05 pm     Reply with quote
Dear all,
Hi, I have a circuit design using PIC16F876. I want to draw it using Protel Design System (Schematic Design) ver3.2.3. However I couldn't fine this component. Can anybody tell me where to get it? Thanks a lot...
Regards: June,
___________________________
Original Post ID: 9990
helen
PostPosted: Thu Dec 12, 2002 2:22 am     Reply with quote
hi,
try to search it using library. If u use protel just to draw schematic, why not u search for similiar chip, if the ur chip is 40 pins, get the 40pins chip, then modify it. The designing of new chips can be save in the library to be use in ur other project.
:p
I do that in case i cant get actual chip from library
Original Post ID: 9992
Pete Smith
PostPosted: Thu Dec 12, 2002 3:25 am     Reply with quote
:=Dear all,
:= Hi, I have a circuit design using PIC16F876. I want to draw it using Protel Design System (Schematic Design) ver3.2.3. However I couldn't fine this component. Can anybody tell me where to get it? Thanks a lot...
If you read the big Microchip PIC data books, you'll see that all 40 pin PICs, no matter the type, have broadly the same pinout.
The same goes for other PICs. As long as they have the same number of pins, and the package is the same, they're all compatible.
I use the 16C74 pinout when I need to use a 16F877.
Pete.
Original Post ID: 9995
Kenny
PostPosted: Thu Dec 12, 2002 8:28 am     Reply with quote
<font face="Courier New" size=-1>:=Dear all,
:=Regards: June,
It's off topic, this forum is for CCS C for pic, but I'll answer anyway.
Protel 3 precedes the 16f876 by several years so it's not surprising that you couldn't find the component. Since then there have been Protel 98, Protel 99SE and now Protel XP. The library files from a later package cannot be used, but earlier ones can sometimes be converted.
You can make a schematic component within Protel 3 and save to your own library. If you want to make a circuit board from schematic capture then you will also need to create a PCB library component. The 16f876 is a 28 pin "skinny DIP" ie. has a row spacing of 0.3 inches. You can make this by modifying an existing component and saving it to your own PCB component library.
Creating your own components is normal with Protel because the supplied libraries have many mistakes, and also because they cannot possibly cover all components.
Regards
Kenny </font>
Original Post ID: 10001
jason
PostPosted: Fri Dec 13, 2002 9:55 am     Reply with quote
Set the snap for Protel to the difference between pins and place pads in those spots. You can also place any package with the same amount of pins.
Thanks,
Original Post ID: 10031
