Line 82: Error #118: Invalid conversion from LONG INT to INT
kuosda
PostPosted: Fri Dec 06, 2002 1:38 am     Reply with quote
I transfered version 1.03 from 16F877 to 18F452, I use PCWH v3.110. Make the follwing changes:
In file p16web.c
change or add address of timer1 register
16F877
//#byte TIMER_1_HIGH= 0x0f
18F452
#byte TIMER_1_HIGH= 0xfcf
#bit RD16 = 0xfcd.7 // this bit is new in 18F452 in register T1CON and controls read/write operations of timer1
change addresses of port a-c
16F877
//#byte PORTA = 5 // Main I/O ports
//#byte PORTB = 6
//#byte PORTC = 7
18F452
#byte PORTA = 0xf80 // Main I/O ports
#byte PORTB = 0xf81
#byte PORTC = 0xf82
add the RD16 = 0; command after the setup_timer_1() command in main()
setup_timer_1(TIMER1_SET); // Init timer
RD16 = 0; // new bit in 18F452, enables register read/write in two 8 bit operations
In file p16_eth.h
change address of port d-e
16F877
//#byte PORTD = 8
//#byte PORTE = 9
18F452
#byte PORTD = 0xf83
#byte PORTE = 0xf84
Error????
___________________________
Original Post ID: 9814
nilsener
Re: Line 82: Error #118: Invalid conversion from LONG INT to
PostPosted: Fri Dec 06, 2002 4:07 am     Reply with quote
You have posted only the changes to make in v1.03 when transfering to 18F452, please post the complete sourcecode and mark line 82.
regards nilsener
:=I transfered version 1.03 from 16F877 to 18F452, I use PCWH v3.110. Make the follwing changes:
:=In file p16web.c
:=change or add address of timer1 register
:=16F877
:=//#byte TIMER_1_HIGH= 0x0f
:=18F452
:=#byte TIMER_1_HIGH= 0xfcf
:=#bit RD16 = 0xfcd.7 // this bit is new in 18F452 in register T1CON and controls read/write operations of timer1
:=change addresses of port a-c
:=16F877
:=//#byte PORTA = 5 // Main I/O ports
:=//#byte PORTB = 6
:=//#byte PORTC = 7
:=18F452
:=#byte PORTA = 0xf80 // Main I/O ports
:=#byte PORTB = 0xf81
:=#byte PORTC = 0xf82
:=add the RD16 = 0; command after the setup_timer_1() command in main()
:=setup_timer_1(TIMER1_SET); // Init timer
:=RD16 = 0; // new bit in 18F452, enables register read/write in two 8 bit operations
:=In file p16_eth.h
:=change address of port d-e
:=16F877
:=//#byte PORTD = 8
:=//#byte PORTE = 9
:=18F452
:=#byte PORTD = 0xf83
:=#byte PORTE = 0xf84
:=Error????
:=Line 82: Error #118: Invalid conversion from LONG INT to INT
Original Post ID: 9820
kuosda
PostPosted: Fri Dec 06, 2002 4:50 am     Reply with quote
I use PCWH v3.128
p16_ip.h Line 82:
line 82: get_lword(remip.l) && // Sender's IP addr
Thank you!
Original Post ID: 9822
