Set_uart_speed()
Detienne Guy
Set_uart_speed()
PostPosted: Sun Dec 01, 2002 3:18 pm     Reply with quote
I use the PIC 16F876 and CCS Compiler version 3.15.
In the projet, I use two RS232 communication with PC1 and PC2 as stream identifier.
#use rs232(baud=4800,parity=N,xmit=PIN_C0,rcv=PIN_C1,stream=PC2,errors)
#use rs232(baud=4800,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=PC1)
I wish have the possibility to change the BaudRate of PC1 in regard of the setting of
pin B1. Therefore, in te main, I write the following code :
switch (input(PIN_B1))
case 0 :
set_uart_speed (4800);
case 1 :
set_uart_speed (9600);
The Baud rate stay on 4800 Baud. Port B1 is input.
What is my error ? Thanks for your suggestions.
___________________________
Original Post ID: 9656
R.J.Hamlett
Re: Set_uart_speed()
PostPosted: Sun Dec 01, 2002 3:35 pm     Reply with quote
:=I use the PIC 16F876 and CCS Compiler version 3.15.
:=In the projet, I use two RS232 communication with PC1 and PC2 as stream identifier.
:=#use rs232(baud=4800,parity=N,xmit=PIN_C0,rcv=PIN_C1,stream=PC2,errors)
:=#use rs232(baud=4800,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=PC1)
:=I wish have the possibility to change the BaudRate of PC1 in regard of the setting of
:=pin B1. Therefore, in te main, I write the following code :
:=switch (input(PIN_B1))
:= case 0 :
:= set_uart_speed (4800);
:= break;
:= case 1 :
:= set_uart_speed (9600);
:= break;
:=The Baud rate stay on 4800 Baud. Port B1 is input.
:=What is my error ? Thanks for your suggestions.
If you are using streams, then add the stream identifier to the set_uart_speed call. As:
set_uart_speed(9600,PC1);
Original Post ID: 9659
Detienne Guy
PostPosted: Mon Dec 02, 2002 3:36 pm     Reply with quote
:=:=I use the PIC 16F876 and CCS Compiler version 3.15.
:=:=In the projet, I use two RS232 communication with PC1 and PC2 as stream identifier.
:=:=#use rs232(baud=4800,parity=N,xmit=PIN_C0,rcv=PIN_C1,stream=PC2,errors)
:=:=#use rs232(baud=4800,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=PC1)
:=:=I wish have the possibility to change the BaudRate of PC1 in regard of the setting of
:=:=pin B1. Therefore, in te main, I write the following code :
:=:=switch (input(PIN_B1))
:=:= case 0 :
:=:= set_uart_speed (4800);
:=:= break;
:=:= case 1 :
:=:= set_uart_speed (9600);
:=:= break;
:=:=The Baud rate stay on 4800 Baud. Port B1 is input.
:=:=What is my error ? Thanks for your suggestions.
:=If you are using streams, then add the stream identifier to the set_uart_speed call. As:
:=set_uart_speed(9600,PC1);
:=Best Wishes
Thanks for your help. Sorry for the question but this possibility is not provide in the reference manual.
Original Post ID: 9704
R.J.Hamlett
PostPosted: Mon Dec 02, 2002 4:03 pm     Reply with quote
:=:=:=I use the PIC 16F876 and CCS Compiler version 3.15.
:=:=:=In the projet, I use two RS232 communication with PC1 and PC2 as stream identifier.
:=:=:=#use rs232(baud=4800,parity=N,xmit=PIN_C0,rcv=PIN_C1,stream=PC2,errors)
:=:=:=#use rs232(baud=4800,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=PC1)
:=:=:=I wish have the possibility to change the BaudRate of PC1 in regard of the setting of
:=:=:=pin B1. Therefore, in te main, I write the following code :
:=:=:=switch (input(PIN_B1))
:=:=:= case 0 :
:=:=:= set_uart_speed (4800);
:=:=:= break;
:=:=:= case 1 :
:=:=:= set_uart_speed (9600);
:=:=:= break;
:=:=:=The Baud rate stay on 4800 Baud. Port B1 is input.
:=:=:=What is my error ? Thanks for your suggestions.
:=:=If you are using streams, then add the stream identifier to the set_uart_speed call. As:
:=:=set_uart_speed(9600,PC1);
:=:=Best Wishes
:=Thanks for your help. Sorry for the question but this possibility is not provide in the reference manual.
True.
Look at the 'readme' that comes with the compiler. It covers the changes from the manual. :-)
Original Post ID: 9706
