joseph20480
| Read the input of MCP23S17 - Pic24f |
Posted: Wed Sep 12, 2012 12:56 pm |
HI,
I'm working on a library for my project and i have a problem...
I'm trying to set the 16 I/O in input mode, and read them but nothing (Mode output no problem).
CCS : 4.128 / Pic 24Fj64GA104
Register and pinout :
//-- MCP23S17 --
#pin_select SCK1OUT = PIN_C5 // Clock
#pin_select SDI1 = PIN_C3 // Data input
#pin_select SDO1 = PIN_c4 // Data output
#define mcp_clk pin_c5
#define mcp_sdi pin_c3
#define mcp_sdo pin_c4
#define mcp_cs pin_a4
#define write_mode 0x40
#define read_mode 0x41
#define IOCON_reg 0x0A
#define IODIR_reg 0x00 // Direction register [ 1=input / 0=output ]
#define IPOL_reg 0x02 // Input polarity [ 0= same / 1=opposite ]
#define GPPU_reg 0x0c // Pull up resistor register [ 1=pullup enable / 0=pullup disable ]
#define GPIO_reg 0x12 // General purpose IO register
#define OLAT_reg 0x14 // Output latch register [ 1=logic_high / 0=logic_low ]
#define GPINTEN_reg 0x04 // Interrupt register [ 1=enable / 0=disable]
My init function
void mcp_init()
setup_spi(SPI_MASTER |SPI_L_TO_H | SPI_CLK_DIV_6); // Spi n°1 - Max 10Mhz
mcp_write(IOCON_reg,0x40,0x40); // config registre mode de communiquation
// PortA & PortB en output
//mcp_write(IODIR_reg,0x00,0x00);
//mcp_write(OLAT_reg,0x00,0x00);
//mcp_write(GPPU_reg,0x00,0x00);
//mcp_write(GPIO_reg,0xff,0xff);
// PortA & PortB en input
mcp_write(IODIR_reg,0xFF,0xFF); // PortA et PortB en entrees
mcp_write(IPOL_reg,0x00,0x00); // valeur identique a l'etat de l'input
mcp_write(GPINTEN_reg,0x00,0x00); // Pas d'interruption
My Write / read function
void mcp_write(int8 adresse,int8 data_1,int8 data_2)
output_low(mcp_cs);
spi_write(write_mode);
spi_write(adresse);
spi_write(data_1);
spi_write(data_2);
output_high(mcp_cs);
void mcp_read(int8 adresse)
int8 data1;
int8 data2;
output_low(mcp_cs);
spi_write(read_mode);
spi_write(adresse);
data1=spi_read(0);
data2=spi_read(0);
For read my input, I call the the function mcp_read() with GPIO_reg parameter.
If someone sees a terrible mistake !? |
