How to I convert a 16 bit number to two 8 bit?
Michael Sheedy
PostPosted: Mon Nov 05, 2001 7:09 pm     Reply with quote
I am using a 16F872 10 bit ADC. I am storing the 10 bit number into a 16 bit register. How do I break the 16 bit number into 2 8 bit numbers so I can individually manipulate each byte?
Thanks in advance
Michael
___________________________
Original Post ID: 958
Justin Dobbs
Re: How to I convert a 16 bit number to two 8 bit?
PostPosted: Mon Nov 05, 2001 9:46 pm     Reply with quote
Michael,
int16 big_number;
int8 high_byte;
int8 low_byte;
big_number=get_reading();
low_byte=big_number & 0xff;
high_byte=big_number>>8;
not sure if this is more efficient or not:
low_byte=big_number&0xff;
big_number>>=8;
high_byte=big_number;
Justin Dobbs
:=I am using a 16F872 10 bit ADC. I am storing the 10 bit number into a 16 bit register. How do I break the 16 bit number into 2 8 bit numbers so I can individually manipulate each byte?
Original Post ID: 963
Tomi
PostPosted: Tue Nov 06, 2001 3:01 am     Reply with quote
Without arithmetics you can use the #byte directive:
int16 value;
#byte valueL = value
#byte valueH = value+1
Usage (example):
putchar(valueL); // send over RS232
putchar(valueH);
:=Thanks in advance
:=Michael
Original Post ID: 967
